[Solved] Growling Bearing Noise (2.7L) 2TR-FE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaZL, Dec 13, 2018.
  1. Dec 13, 2018 at 11:06 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    how about the serpentine belt pulleys? they go bad
  2. Dec 13, 2018 at 11:11 AM
    TacomaZL
    TacomaZL [OP] Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    I thought that too, but bearings don't making a ton of noise some times and no noise others, unless the amount of load they are experiencing is changing...
    The alternators load would change based on how much the battery needs to be fully charged. Once it is charged, the alt doesnt meed to work as hard...so it gets quiet.
    I mean, I am open to auggestions, but I am pretty sure the alternator is the case. Suddenly sounding like you have a supercharger seems to be a common observation for alts that are on their last leg....thats what mine sounds like.
    Again, open to suggestions. But thats my thought process.
  3. Dec 13, 2018 at 11:18 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Next time you hear the whining noise, unplug the field connector from the back of the alternator. if the noise goes away then it's for sure a bad alternator.
    BassAckwards and BillsSR5 like this.
  4. Dec 13, 2018 at 11:22 AM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    Go to Harbor Freight and drop 6 bucks on a mechanics stethoscope, run the engine when the noise is present an then pinpoint it.
    You can also take the belt off and spin all the pulleys to see if one has more resistance or is rougher then the others.
    ovrlndkull, blu92in99 and BillsSR5 like this.
  5. Dec 13, 2018 at 11:23 AM
    BillsSR5
    bill
    2014 SR5
    I would check the alternator with a volt meter to absolutely be sure its the alternator https://youtu.be/LGB6ZEjGm7Q
  6. Dec 13, 2018 at 11:28 AM
    BillsSR5
    bill
    2014 SR5
    and with a coupon get a free voltmeter https://www.hfqpdb.com/best_coupon/7+FUNCTION+DIGITAL+MULTIMETER
  7. Dec 13, 2018 at 11:32 AM
    TacomaZL
    Illinois
    With the engine still running?
  8. Dec 13, 2018 at 11:34 AM
    96carboard
    96carboard Well-Known Member
    His alternator will pass the voltmeter test. The problem he's complaining about is a NOISE, not a lack of charging.
  9. Dec 13, 2018 at 11:37 AM
    96carboard
    Yeah. Won't hurt anything. Just won't charge while its unplugged.
    But don't plug it back in while running.
    If its making a noise, have you tried pouring oil into it? You can hose it with something like ATF. If it makes the noise go away, then keep driving it. If it doesn't, then its probably not the alternator.
  10. Dec 13, 2018 at 11:39 AM
    BillsSR5
    bill
    2014 SR5
    https://i.gifer.com/C7cd.gif
  11. Dec 13, 2018 at 11:40 AM
    TacomaZL
    Illinois
    WTF
    PatHenry52, cryptolime and BillsSR5 like this.
  12. Dec 13, 2018 at 11:41 AM
    TacomaZL
    Illinois
    I hope you don't carry that philosophy over to parenting...
  13. Dec 13, 2018 at 11:45 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yep.
    Alot of times that whining noise is the magnetic field getting fucked up inside the alt. Removing that connector takes the magnetism away and removes the load
  14. Dec 13, 2018 at 11:50 AM
    96carboard
    Care to explain that absurdity?
  15. Dec 13, 2018 at 11:52 AM
    #35
    TacomaZL
    Illinois
    I thought you were joking...
    Dumping ATF into an alternator sounds like a really bad idea...
    cryptolime, BillsSR5 and b_r_o like this.
  16. Dec 13, 2018 at 11:52 AM
    #36
    BillsSR5
    bill
    2014 SR5
  17. Dec 13, 2018 at 11:59 AM
    #37
    96carboard
    So what do you think that oil is going to do to a noisy mechanical device that is regularly bathed in salty road sludge?
  18. Dec 13, 2018 at 12:00 PM
    #38
    TacomaZL
    Illinois
    Worsen the problem...
  19. Dec 13, 2018 at 12:00 PM
    #39
    96carboard
    Think about that for another minute or two and when you come up with a better answer, add your next reply.
  20. Dec 13, 2018 at 12:01 PM
    #40
    BillsSR5
    bill
    2014 SR5
