[Solved] Tom Wood Drive shaft Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by oakcity, Sep 19, 2020.
  1. Sep 19, 2020 at 8:18 AM
    oakcity
    oakcity [OP] Well-Known Member
    Jesse
    Raleigh, North Carolina
    2009 Grey Tacoma AC 4x4
    Money Pit
    I watched the Tacoma Beast video and that’s basically the only install video for our Tacoma’s with the Tom Wood shaft but the sliding piece goes to the back is this correct? On the rear diff? Pic for reference sorry if I’m not naming it correctly.
    TerraKop likes this.
  2. Sep 19, 2020 at 8:20 AM
    tcjacado
    tcjacado Well-Known Member
  3. Sep 19, 2020 at 8:22 AM
    oakcity
    Jesse
    Money Pit
  4. Sep 19, 2020 at 8:24 AM
    tcjacado
    I think all the videos I linked are on tacomas.
  5. Sep 19, 2020 at 8:24 AM
    oakcity
    Jesse
    Money Pit
    Gotcha cool I thought it went to the back but wanted to double double check never can be too sure lol
  6. Sep 19, 2020 at 8:27 AM
    tcjacado
  7. Sep 19, 2020 at 8:30 AM
    oakcity
    Jesse
    Money Pit
  8. Sep 19, 2020 at 8:33 AM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    You are correct it goes to the back.
    MTopp, BassAckwards and oakcity[OP] like this.
  9. Sep 19, 2020 at 8:43 AM
    oakcity
    Jesse
    Money Pit
    Got it thanks! I understand now why it goes to the back for the rear end flex etc
    MTopp and nagorb[QUOTED] like this.
  10. Sep 19, 2020 at 9:27 AM
    bhigbee
    bhigbee Well-Known Member
    Barney
    Hayden Id
    Wrecked 07 DCSB
    35s, flatbed, rhino liner paint, SOS front bumper, JD Fab lca pivot, JD Fab inner fenders and some other stuff.
    Make sure your u-jounts are timed right.
    MTopp likes this.
  11. Sep 19, 2020 at 9:57 AM
    oakcity
    Jesse
    Money Pit
    Huh? I have the instructions for this and it’s a bolt in application it doesn’t say anything about timing?
  12. Sep 19, 2020 at 10:03 AM
    oakcity
    Jesse
    Money Pit
    You must be talking about the front DS I’m doing the back
  13. Sep 19, 2020 at 11:37 AM
    Muddinfun
    Muddinfun Well-Known Member
    The driveshaft will come assembled and balanced. Don’t pull the slip yoke apart and you won’t have a problem.
    MTopp and bhigbee like this.
  14. Sep 19, 2020 at 12:10 PM
    bhigbee
    Barney
    Hayden Id
    Wrecked 07 DCSB
    Just make sure the u-joints are facing the same way. The yokes should be pointed in the same direction. If you haven't slid it apart you should be fine.
  15. Sep 19, 2020 at 12:38 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This ^ right here.
    Muddinfun[QUOTED] likes this.
  16. Sep 19, 2020 at 1:37 PM
    oakcity
    Jesse
    Money Pit
    Yep all is well it’s in and all vibrations have gone away ahhhhh now I can rest lol
    tcjacado, Muddinfun and DiscoYaker like this.
