Solving manual trans whining sound.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Caslon, Aug 19, 2021.
  1. Aug 19, 2021 at 6:56 PM
    Caslon
    Caslon [OP] Well-Known Member
    2003 Base Cab. 2 whl drive. 5 speed
    I replaced my 106k 2003 manual 5 speed transmission 4x2 with some off brand 75/90 trans oil. Two months on the gearbox is making a whining sound now. It goes down as engine deacelerates between shifting. I wish I had used OEM equivalent. It starts to whine after driving awhile and the gearbox heats up. What’s my best course of action? I chose Castrol GTX Manual Transmission fluid as it meets OEM specs. $14 qt. Drain and fill, drive awhile, drain and fill, drive awhile, drain and fill? No shifting problems, no drop in mpg. Can’t stand that whine tho. Did I just answer my own question? I’m hesitant to use Sea Foam Trans product. I just want all the old out and fresh in and see if the whine goes away. Gawd, I hope it does.
    Fun fact I just read. Only 15% of US sold vehicles now have manual transmissions, while in Europe 80% still have manual transmissions. Must be the roads over there?
    JudoJohn and HierAnarchy like this.
  2. Aug 19, 2021 at 7:12 PM
    Dirty Dude
    Dirty Dude Well-Known Member
    2004 Tacoma SR5 Xtra cab 5-lug
    Dirt, miles, and wear.
    If the oil was directly responsible for the noise, it wouldn't have taken two months to start. Draining what you have would at the very least be an opportunity to see if there's any metal in it.
    JudoJohn likes this.
  3. Aug 19, 2021 at 7:30 PM
    Caslon
    There were tiny metal fragments in the diff, none in the trans. It may have been less than two months after the fluid change that the whining started. I’m thinking the 1/3 you can’t completely drain out mixed unfavorably with the new off the wall brand. I’ve read that can occur. I’m sorry I can’t remember what brand I bought on this,most likely, first transmission oil change. It was a no name and likely not an OEM equivalent. The Castrol GTX is, in all respects. It specifically states for manual transmissions, GL 5.
  4. Aug 19, 2021 at 7:48 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    In a manual transmission you don't leave very much behind when draining, definitely not 1/3.
    Have you rechecked the level since you changed the transmission oil?
    If there is truly a problem no "mechanic in a can" (Seafoam, etc.) will fix it, save your money.
  5. Aug 19, 2021 at 7:59 PM
    HierAnarchy
    HierAnarchy Active Member
    2000 Tacoma 4WD Xtra Cab, 2.7L
    Bilstein 5100 (all), OME 880 springs, Deaver J59 leafs. 265-75-15 All-season. Else: All stock.
    I'm sorry you're experiencing this. I sincerely hope you find a fix.
    I think you'd be smart to flush it.
  6. Aug 19, 2021 at 8:00 PM
    Caslon
    HierAnarchy[QUOTED] likes this.
  7. Aug 19, 2021 at 8:05 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    There are a lot of GL5 75W90 oils that meet OEM specs and claim GL4 compatibility but are not safe for the brass synchros in the transmission.
    Redline MT90 is frequently recommend and is brass safe. There is also an AMSOIL equivalent but I don't know which off the top of my head.
    ireymon and HierAnarchy like this.
  8. Aug 19, 2021 at 8:06 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    it's not the roads that are reason for Europeans driving manual transmissions more. They aren't as lazy as Americans are.
    HierAnarchy likes this.
  9. Aug 19, 2021 at 8:15 PM
    Caslon
    Yes, I considered both those brands. $20+ a quart. At $14 a quart with Castrol’s trans fluid specifically stated for manual transmissions, I’m reasonably confident it’s an OEM equivalent. Better than that no name 75/90 for $8.99 that’s in there at the present.
    To get out all whatever mixed with the original fluid, I may drain and fill, drain and fill.
    Of course I’ll change out the fluid and see if that instantly fixes the whining sound, I’m suggesting it may take doing that 2 or 3 times before the trans has pure OEM type fluid in it.
    Thanks for the input.
  10. Aug 19, 2021 at 8:26 PM
    Wulf
    rock raisin
    good luck!
  11. Aug 19, 2021 at 8:53 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I have trouble believing that adding fresh 75w90 gear oil (regardless of brand) caused a whine. That is, unless that was the very first oil change in it's 106K life.
    If you are cruising along at 40 mph (or so) and it is whining away, what happens to the whine if you put the trans into neutral and let out the clutch and coast along? Does the whine go away?
    Wulf likes this.
  12. Aug 19, 2021 at 9:40 PM
    Caslon
    In between shifting 1 to 3 gears, the trans whining goes down between shifts. I’m hoping it’s just a bad mix of original and whatever 75/90 forgettable brand I bought. I don’t want to hear I’ve done permanent damage, gulp.
  13. Aug 20, 2021 at 7:23 AM
    ireymon
    ireymon Unknown Member
    Kenneth
    Winston-Salem, NC
    99 X-Cab 5 lug 5 speed
    Hyundai wheels, dings & dents...
    Link to the Castrol GTX manual trans fluid you used? I am not finding anything from Castrol that fits that description. The manual calls for GL4 so if that Castrol stuff is GL5, probably need to replace it promptly.
    Hows the fluid level? Do you have enough fluid in the trans? If it's low, it can whine. On Amazon, the MT90 works out to $16/bottle if you buy 4 or they're $19 each. You'll need almost 3 to drain and refill so you can spend $57 and get 3 or spend $64 and have an extra one.
    Also, with a manual trans, you don't need to do the drain/fill/repeat thing. It only needs it one time. It's not like an auto trans where you have a bunch of fluid stuck in the torque convertor, lines and cooler that you don't get when you drain. I'd hate for you to spend 2-3x more than you need to buying all that fluid!
    RustyGreen, Wulf and HierAnarchy like this.
  14. Aug 20, 2021 at 7:39 AM
    HierAnarchy
    These packets of wisdom is what makes the forum.
  15. Aug 20, 2021 at 8:16 AM
    gearcruncher
    Canadain bumper technician
  16. Aug 20, 2021 at 2:02 PM
    Caslon
    The mechanic doesn’t think it’s the bearings, thank goodness. Just now got him to change trans and diff with the Castrol GTX. Fingers crossed.
    Edit: Unfortunately the whine is still there. Trans mechanic didn’t feel it was any thing of real concern and to just live with it. He doubts using Redline or Amsoil fluid would make any difference.
  17. Aug 20, 2021 at 5:15 PM
    Dirty Dude
    On the GL4 vs GL5 thing, the owner's manual says GL4 or GL5, at least for 2004 and I'm pretty confident '01-04 are the same. Blocker rings don't mesh with anything in steady-state driving so there's nothing to cause a whine. I really doubt the oil had anything to do with it.
    My 5-speed whines a bit although I seldom notice. No metal came out and it has good synthetic GL5, so I'm not going to worry about it. Now the rear end when it was losing the carrier bearings, that was shedding flakes of bearing race.
  18. Aug 21, 2021 at 10:29 AM
    Taco_Chad
    Taco_Chad Active Member
    Chad
    1998 Toyota Tacoma SR5
    The viscosity specifications on 75W-90 are VERY wide range
    Also, cheaper brands will usually use low quality viscosity index improvers which shear down quickly (makes the fluid thin within few thousand miles)
    Tough to say much on the Castrol transmission fluid without the full product name
    I run Castrol Vecton 15W-40 CK-4 in my transmission and transfer case.
    Much quieter, no grinding even in 5th gear from slow speed.
    None of the additives which corrodes brass synchros
  19. Aug 21, 2021 at 12:48 PM
    Caslon
    Oreilly’s had the most specs. Scroll down to “Applications for Your Vehicle”, then “Show all details’” Their site said it didn’t match my 2003, but Castrol says it does. Anyone tried an additive such as Liqui Moly or one of the many others? I have my doubts about them quieting the whine. Not that expensive, $10.
    https://www.oreillyauto.com/detail/...ear-oil-75w-90-1-quart/casp/syntrax7590?pos=8
  20. Aug 21, 2021 at 1:22 PM
    Dirty Dude
