Some Advice for my setup
Discussion in 'Arizona' started by adicted, Aug 20, 2013.
  1. Aug 20, 2013 at 1:21 PM
    adicted
    adicted [OP] Active Member
    Travis
    Arizona
    So I'm really close to getting my 2013DCLB TRD Sport with Tow Package....I am a big hunter and fisherman and pull a flatbed every once in a while and a 18ft skeeter bass boat. I will be putting a topper on the back also. I want to be able to goo offroading with some 285 muds on there and get good clearance but not over 3 inches so I keep my warranty. So for a simple setup that will keep my rear end from sagging hooked up to the boat can I do Bilstein 5100 with stock springs and in the back do OME Leaf Spring Kit cs047R and will that give me a level look with 2.85s and not sag with the boat hooked up. The boat is about 2800 total weight with trailer....
    What do you think?
  2. Aug 20, 2013 at 1:25 PM
    tn2012taco
    tn2012taco Well-Known Member
    Nathan
    Nashville, TN
    '12 PreRunnin Trooper
    Plasti-dipped wheels, Bilstein 5100's @ 1.75, 1 in. block in rear, CB in center console, 12V outlet in console, weathertechs, N-FAB wheel-to-wheel 3in. tube, Action packer cheap toolbox, Spidertraxx 1.25" spacers, Kensun 5000K in fogs, K&N drop-in filter, foglight anytime mod, Anytime Panty-dropper mod.
    I guess I'll answer this one. From what I've seen on here, if I was in your situation I'd do an add-a-leaf, that'll raise your rear about an inch and a half, and keep it from sagging as much. The ride is a bit more stiff though. The front, I'd go with the Bilstein 5100s and set them at 1.75. I'm not sure that the 285s will fit perfectly with no rubbing, but you should be able to cram them under there with minimal issues.
  3. Aug 20, 2013 at 1:26 PM
    Large
    Large Red
    I always suggest dakars in the rear, although I am biased. Why not full OME front to back? Lifting your truck won't void any warranty..
  4. Aug 20, 2013 at 1:27 PM
    tn2012taco
    Nathan
    Nashville, TN
    Of course I'm always thinking about lifts on a budget. Gotta love college. :rolleyes:
  5. Aug 20, 2013 at 2:11 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    This.
    Its what im running (minus the leafs, they are Icon progressives) and I couldn't be happier.
  6. Aug 23, 2013 at 12:49 AM
    cytocycle
    cytocycle Well-Known Member
    Scottsdale, Arizona
    Expedition Build - 2012 TRD Off-Road
    4.88, Radflo 2.5" Resi,ARB Front Bumper with fogs, TJM 9,000 synthetic rope winch with Pro-Link, AllPro Bolt on Sliders with fill plates, Asfir Aluminum Front Skid, Mid Skid, Gas Skid, Transfer Skid, AllPro Shackle flip kit with Timbern, CBI HC rear Bumper, Rigid Mesh Grill with 20" LED bar, White Sport Grill Opening, ARB Dual Compressors and 2 gallons of air tanks for air tools, Dakar Leaf Pack+2,front sway bar delete, Camburg UCA's, Stainless Steel Brake Lines on all wheels fixed mushy brakes, UltraGuage
    Best Value and best ride... add a leave will fail sooner and it doesn't ride as nice... Love my Dakars... OME just works! and it's doesn't kill your budget.
  7. Aug 23, 2013 at 7:53 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    For a budget lift, OME is the way to go.
    Also... Lifts do not void warranty. Manguseen-Moss act. They will void your suspension warranty (obviously)... and if they can prove the lift caused pre-mature failure of something else (ie, drive-shaft) you will be denied. Otherwise, they must cover it by law.
  8. Aug 23, 2013 at 7:57 AM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Dakars are far superior for load carrying in an off-road application. I've had over a thousand *(1000) pounds in the bed and couldn't have been any more satisfied with the handling.
  9. Aug 23, 2013 at 8:10 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Tongue weight is what's going to affect your sagging while towing so, hard to say what you need. Personally I love my All-Pro leaf pack, but it's closer to the 4" mark when they're fresh.
  10. Aug 23, 2013 at 9:39 AM
    cytocycle
    Scottsdale, Arizona
    I think the point everyone is saying is add-leaf won't last that long and won't ride as well as replacing the whole pack, the Toyota stock leafs are so weak, mine completely flattened brand new with a Buell Blast motorcycle in the bed.. it's like 350lbs or so..
  11. Aug 23, 2013 at 10:43 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    The stock leafs are a joke and belong on like, a nissan leaf, not a truck
  12. Aug 23, 2013 at 3:02 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Love my Icon pack!! :D
