some advice...
Discussion in '1st Gen. Tacomas (1995-2004)' started by zigzagg321, Mar 24, 2009.
  1. Mar 24, 2009 at 9:04 PM
    zigzagg321
    zigzagg321 [OP] T100
    Ohio
    96 T100 SR5
    sliding rear window
    I honestly tried to use the search function on this forum... I got no where with it... its kinda hit or miss...
    so hope this question hasnt been asked a million times but...
    I have a 96 4x4 2.7L 5spd with 168k on it... unknown service history..
    check engine light is on, fault for oxygen sensor heating... guess it needs an o2 sensor??
    do I have r12 a/c or r134a?
    what maintenance should I do now that is or was due around 168k?
    Thanks for the help.
  2. Mar 24, 2009 at 9:13 PM
    tarheelfan_08
    tarheelfan_08 Carolina Alliance
    Justin
    North Carolina
    2010 White 4x4 Double Cab Tacoma Short Bed
    Chrome Grill, Chrome accessories(door handles and mirror covers), LEER Super White Cover, Mirrors with Turn Signals, Window Vent Visors, Step Rails, WeatherTech Digital Floor Mats, Mini Maglight Holder, Chrome Bull Bar
    change oil and spark plugs, engine cleaning, under body cleaning, tire pressure check and rotation! And maybe even seafoam it!
  3. Mar 24, 2009 at 9:39 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Your A/C uses R-134a. R-12 was banned around '94 or so.
    If you don't have a service history, it wouldn't be a bad idea to take a good look at all of your wearable parts. Check the belt for cracks, inspect your ball joints, check your plug wires & pull a spark plug or two so you can have an idea of how recently they were changed and if they need to be replaced. It also wouldn't hurt anything to change your front and rear differential oil with that many miles on your truck.
  4. Mar 28, 2009 at 9:11 PM
    zigzagg321
    Ohio
    96 T100 SR5
    sliding rear window
    cleared the fault, next day, same fault again. I replaced the coolant temp sensor. seems to have fixed the issue.
  5. Mar 28, 2009 at 9:38 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    What was the exact code?
  6. Mar 29, 2009 at 5:19 AM
    Ry1984
    Ry1984 Well-Known Member
    From Texas, Now Miami FL
    01' ExtCab SR5 2.7 4x4
    K&N FIPK, Billy 5100 all around, 881's in the front, Toytec AAL
    as far as maintenance, i would definitely change out every fluid, and spark plugs. switch your gear case to mobil 1 if its not in there already to, expensive but def worth it IMO
  7. Mar 29, 2009 at 7:03 AM
    zigzagg321
    Ohio
    96 T100 SR5
    sliding rear window
    just yesterday, I did trans fluid and rear diff fluid, use valvoline synthetic 75-90. I also put new cap, rotor, plugs and plug wires on. I did both o2 sensors the day before that.
    My transfer case fill plug head is rounded, and I didnt have an 12mm allen socket to do the front diff.
  8. Mar 29, 2009 at 7:08 AM
    zigzagg321
    Ohio
    96 T100 SR5
    sliding rear window
    p0125
  9. Mar 29, 2009 at 8:49 AM
    humanoid
    humanoid bite me
    Sunny SoCal
  10. Mar 29, 2009 at 8:59 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It's unlikely you'd have problems with the timing chain, but I'd have someone look at it. Chains stretch over time and can get sloppy and loose. Sometimes the extra slop can cause other problems.
  11. Mar 29, 2009 at 10:32 AM
    zigzagg321
    Ohio
    96 T100 SR5
    sliding rear window
    I replaced the coolant temp sensor, and the check engine light has not come back, and the truck is running better, aka...entering closed loop mode.
