Some minor engine problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by RattleTractor, Nov 5, 2009.
  1. Nov 5, 2009 at 8:48 AM
    RattleTractor
    RattleTractor [OP] Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    So...
    Driving home from UVM (I live ~20 mins away) I stopped at a red light for a short bit. When I put the truck in gear and went to accelerate, the truck started shaking and the CEL came on immediately. I guessed there was a cylinder out of commission so i went to a parts store and ran the code.
    It came back as cylinder 2 misfire, so i bought new plugs, drove home, and installed them.
    That did solve the problem for the rest of the day, however, now when the truck warms up and idles it does so erratically, going from ~800-500 and back. When I am trying to accelerate from lower RPMs, the truck also pauses and jumps as if to catch back up. I reset the CEL and it has not come back on since.
    I noticed that the wires were worn out a little as well, so i have purchased those and am going to install them when they arrive. The rotor and dst cap seemed ok, but will need replacing sometime soon.
    My question is: will that fix this problem or is there something else I am missing?
    Thanks for reading...sry it was long
  2. Nov 5, 2009 at 8:49 AM
    98tacoma27
    Ben
    Not Beech Creek
    It sounds like you are on the right track. I would replace the cap, rotor and wires as you said you plan on doing. Just make sure that the plugs were gapped properly also.
  3. Nov 5, 2009 at 8:50 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What He said ^^^^^
  4. Nov 5, 2009 at 8:51 AM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    Yep. Replace all of those items. I have the same vintage truck and more than once it has done exactly what you mentioned. The cap, rotor, and wires wear out in these things about every 50,000 miles.
  5. Nov 5, 2009 at 8:54 AM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    Most likely its your wires. With your wires worn out the spark is going to the engine instead of the plug.
  6. Nov 5, 2009 at 8:55 AM
    bobwilson1977
    KaliFORN-I-A
    Get the Toyota wires too. I've bought 2 aftermarket sets ( autolite and some other brand) and they sucked. The boots break too easily. The Toyota ones are a lot more durable.
  7. Nov 5, 2009 at 8:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2!
  8. Nov 5, 2009 at 9:02 AM
    98tacoma27
    Ben
    Not Beech Creek
    x3 I had an autolite set on my 93 22re that didn't last a year. The number 3 wire was grounding out on the head.
  9. Nov 5, 2009 at 10:55 AM
    RattleTractor
    Harry
    VT
    Thanks guys.
    Since Denso is OEM for toyota, i bought those.
  10. Nov 5, 2009 at 10:58 AM
    RattleTractor
    Harry
    VT
    I double and triple checked my gapping skills, but they are probably not absolutely perfect. I got it as close as possible.
    On a side note, I also noticed that the old plugs did not show anything beyond normal wear (no overheating, deposits, etc) so it is probably not anything internal. Just seems to be the spark trying to get to the cylinder.
    sry for th double post.
  11. Nov 5, 2009 at 11:01 AM
    98tacoma27
    Ben
    Not Beech Creek
    It's possible you have a crack or bad insulation on the wire. You can check it at night by watching for a spark where there shouldn't be one.
  12. Nov 5, 2009 at 11:06 AM
    RattleTractor
    Harry
    VT
    did that and didnt see any, however, when i inspected the wires as each plug was pulled, i noticed serious damage on wire 3 and minor damage on 1. That's why i am replacing them.
  13. Nov 5, 2009 at 11:28 AM
    98tacoma27
    Ben
    Not Beech Creek
    Sometimes you have to move/wiggle them. My luck though, I always get the zapped.
  14. Nov 5, 2009 at 5:09 PM
    RattleTractor
    Harry
    VT
    so i will install the wires when they arrive tomorrow, but if it doesnt solve it ill come back here and ask for suggestions again...
  15. Nov 5, 2009 at 5:23 PM
    98tacoma27
    Ben
    Not Beech Creek
  16. Nov 10, 2009 at 8:04 PM
    RattleTractor
    Harry
    VT
    Ok, so the wires came today (FINALLY...couldnt drive her all last week and the weekend, I hated it). I replaced all four in the parking lot with a Leatherman and socket wrench by pulling off the distributor cap to access the clips that hold the wire ends onto the cap.
    And...She runs like a charm again!!
    thanks for the help guys.
  17. Nov 10, 2009 at 8:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :woot:
    Good to hear! Thanks for the update.
  18. Nov 11, 2009 at 7:15 AM
    98tacoma27
    Ben
    Not Beech Creek
  19. Nov 11, 2009 at 7:48 AM
    RattleTractor
    Harry
    VT
    Wow, thats a lot of fanfare. I appreciate the support.
  20. Nov 11, 2009 at 11:34 AM
    98tacoma27
    Ben
    Not Beech Creek
    I hate to see a first gen down brotha!
