Someone please measure stock height driveshaft/pinion angles on 2016+ crew?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dal3_gribble, Aug 28, 2019.
  1. Aug 28, 2019 at 12:24 PM
    dal3_gribble
    dal3_gribble [OP] Well-Known Member
    Crew Cab SB TRD Offroad
    I've searched, I can't find it for 3rd gens. I am about to go the dealer and ask them to let me crawl under their truck but I figured I would ask for help here first. We really need stock height driveshaft angle measurements so anyone that lifts the rear knows how to get the driveshaft/pinion angles back to stock angles. This will really help everyone know what angle of shims and carrier bearing drop they need to get rid of vibration after lifting. If you ever lift the back over an inch, you'll probably be dealing with vibrations. There's no sense trying to get the angles right by blindly bolting drops and shims in.
    Folks with extra cabs can do the measurement as well, but I'm not sure they have the 2 piece driveshaft which is the source of all of this vibration. I'm pretty sure SR5/TRD OR/TRD Sport crews will all have similar driveshaft angles.
    Here's what we need. Someone needs to have the harbor freight angle measurement tool (hopefully) 63615_I.jpg
    Then follow these steps from a good Gen 2 thread-
    https://www.tacomaworld.com/threads/drive-shaft-vibrations-solved-step-by-step.244535/#post-5856724
    1. Buy yourself an angle finder. I got mine at a local Harbor Freight for around $40. You absolutely cannot, ever, figure this stuff out without one.
    2. Measure your current driveshaft angles. You’ll use (4) points to measure from, to get (3) measurement numbers.
    a. Zero your angle gauge against the back of the transfer case, up to the right (under the truck facing forward) against that nice flat place with the two holes.
    b. Measure your first driveshaft angle by placing the gauge underneath the first driveshaft, keeping clear of any mud, stickers, etc. My gauge is magnetic so I flipped it over and hung it upside down. I messed with it a bit to get it perfectly in line with the driveshaft and perfectly underneath (by perfectly I mean I randomly wiggled it around until it came up with the most consistent number). This is your first measurement of three, write it down somewhere, and represents the angle of the first shaft as it comes out of your transfer case.
    c. Take your next measurement underneath the rear (second half) of your driveshaft, after the carrier bearing. I took mine next to the rear differential, again keeping clear of stickers, weights, etc, and wiggling it until I had a consistent reading. This is your second of three measurements, write it down, and represents the angle of your rear half driveshaft as it relates again to the transfer case.
    d. For the third and final measurement, you’ll need to re-calibrate your angle gauge. On mine, I left the gauge where it was, hanging by its magnets under the rear driveshaft, and pressed and released the Calibrate button a few times until the gauge, when hanging under the rear driveshaft, read zero. Then locate the nice flat area up against your rear axle housing, next to the rear differential case. Make sure it’s fairly free of mud etc. then place your gauge (after zero-ing it out on the rear driveshaft) up against this flat part of your rear axle. I found a nice spot just above the molded line (in red) and next to the diff housing bolts (tip of arrow). This is your third and final measurement, write it down also, and represents the angle at which your rear driveshaft comes out of your rear differential.
    Here's an illustration of the steps.
    Someone, please help, it will help the community here I think. The more datapoints, the better!
  2. Aug 28, 2019 at 12:30 PM
    dal3_gribble
    Here are my before/after measurements. Unfortunately I don't have stock height measurements. I got the vibes MUCH, MUCH better, but there is still a little bit.
    Here in the black, you can see the driveshaft angles after adding 1.5" rear add-a-leafs and 1" blocks, the angles, and results. There were pretty bad vibrations from 20-40MPH; enough to really annoy me. Then, in the blue, you can see the angles after 2.5 deg. shims and 2 carrier bearing drop shims (~6mm). It's much better and livable but there are still some vibes there.
    I've seen Gen 2 stock measurements; there's about 2-3 degree angle between shafts, and 2-3 degree angle between the second shaft and diff input. So, mine is pretty close to what the Gen 2 stock angles are at this point. Without knowing what Gen 3s measurments were, that's what I targeted. I am thinking the Gen 3s geometry may be different which is why stock angles will help.
  3. Aug 28, 2019 at 12:34 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I have a magnetic digital and might be able to do this over the weekend... if your timeline allows the delay.
    Stock 2018 OR DCSB
    dal3_gribble[OP] likes this.
  4. Aug 28, 2019 at 12:47 PM
    dal3_gribble
    Also, lifted guys, if you put your measurements here, we'll have one place to start comparing results; we should end up with a pretty good idea of x lift = y adjustment references for everyone.
    Here's a template. Basically we need your setup (lift, corrections in place, and level of vibrations/speeds), and angles. Please update and add new posts with new angles as you make changes too and what those results are.
  5. Aug 28, 2019 at 2:26 PM
    littlefish
    littlefish Buzz, your girlfriend...
    Hudson Valley NY
    2016 TRD Off-Road DCSB
    The one who dies with the most stuff wins.
    On my phone so I can’t input into the template, but my angles before and after:
    Stock:
    First angle 4.3°
    Second angle: 4.7°
    Diff input: 3.4°
    After with OME medium duty Dakar pack yielding 1.75” (23.75” hub center to fender) of lift:
    First angle: 3.4°
    Second angel: 2.0°
    Diff input: 0.8°
    I did not install any shims. I did however install the CB drop. I can confidently say I have had zero vibes at all with these measurements.
  6. Aug 28, 2019 at 3:06 PM
    dal3_gribble
    Thanks! That is different than the second gen. Second gen stock: first angle 5.6° Second angle 3.4° diff input 1.8°. I've been targeting 2nd gen without having a 3rd gen stock reference assuming it would get me close.
    Based on what you posted, it looks like the 3rd gen wants the first/second shaft angles closer together. That explains why the CB drop did it for you and why it didn't work for 2nd gens too well. Excellent!
  7. Aug 28, 2019 at 3:15 PM
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    I have a manual angle finder ill check my 2016 DCSB TRD OR at some point in the next day or so. would like to record it for myself as well.. you may also want to check that your rear end is in line with the output of the driveshaft (hold a straightedge up to it along the driveshaft.)
    compound angles can make vibes in a driveshaft much worse.. I was also of the opinion that because our trucks have no tracbar, or anti wrap bar the pinion angle changes depending on load, speed, and wear and tear on the leafs, and bushings.. just something to think about.
  8. Aug 28, 2019 at 3:19 PM
    RushT
    North Texas
    Lacking an angle finder, there are free iPhone apps. Just need to measure all 4 and take the primary as a reference and do the math. Easy peasy.
  9. Aug 28, 2019 at 3:20 PM
    KY_Rob
    KY_Rob Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    I didn’t follow your directions exactly, and only took 2 measurements (fore and aft of the carrier bearing), using the driveway underneath the driveshaft as 0° reference.
    Fore angle: 7.45°
    Aft angle: 5.90°
    Angle difference: 1.55°
  10. Sep 11, 2019 at 9:53 PM
    Stagarm
    Stagarm Well-Known Member
    Trev
    Fj
    Me behind the wheel
    Used digital angle finder from Lowe’s.
    Measurements taking when I was fight to fix my vibration after installing HD Dakar’s.
    My 2013 Tacoma when it was stock.
    TC- 2.3* down
    1st shaft 7.9* down
    2nd shaft 5.7* down
    Pinion 5.2* up
    Drove over to my buddies house who has a 2015 4wd Tacoma sport. Bone stock.
    Measured his driveline angles. Almost the same. He says he has not vibes.
    TC- 2.5* down
    1st shaft 8.0* down
    2nd shaft 5.5* down
    Pinion 5* up
    Drove over to my parents house and measured their 2007 4wd Tacoma bone stock. Again another Tacoma with no vibes.
    TC- 2.9* down
    1st shaft 8.0* down
    2nd shaft 5.5* down
    Pinion 5* up
    All three trucks with stockrearsuspension. All measurements with a Johnson level magnetic digital angle locator. Took measurements off the flat part of the Tc outputshaft, flat part of the pinion output shaft.
    wi_taco likes this.
  11. Sep 11, 2019 at 9:56 PM
    Stagarm
    Trev
    Fj
    Me behind the wheel
    Measure both sides of the joint. Add if opposite angles. subtract is similar.
  12. Nov 11, 2019 at 5:55 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    I’m gonna try to bring this thread back to life, it could potentially yield some good info
    tcjacado likes this.
  13. May 17, 2020 at 4:44 PM
    cdoghump
    cdoghump Well-Known Member
    Amarillo, TX
    17' TRD OR DCSB 4x4
    I need the info too!!
  14. May 17, 2020 at 4:51 PM
    cdoghump
    Amarillo, TX
    17' TRD OR DCSB 4x4
    Did you have any luck elsewhere?
  15. May 17, 2020 at 4:59 PM
    Anchovy
    TRD Ferguson
  16. May 17, 2020 at 8:09 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    What good are stock angles to a lifted truck?
    The front of the driveshaft goes up and angles increase. Measuring and canceling your lifted working angles is what needs to happen. You'll never achieve stock angles on a lifted truck.
  17. Jun 16, 2020 at 2:02 PM
    Stagarm
    Trev
    Fj
    Me behind the wheel
    TC- 2.3* down
    1st shaft 7.9* down
    2nd shaft 5.7* down
    Pinion 5.2* up
    TC- 2.5* down
    1st shaft 8.0* down
    2nd shaft 5.5* down
    Pinion 5* up
    TC- 2.9* down
    1st shaft 8.0* down
    2nd shaft 5.5* down
    Pinion 5* up
    All three trucks with stock rear suspension. All measurements with a Johnson level magnetic digital angle locator. Took measurements off the flat part of the Tc outputshaft, flat part of the pinion output shaft.
  18. Jun 16, 2020 at 3:00 PM
    splitbolt
    NW Arkansas
    What are your actual 'working angles' for each u-joint?
    Correct me if I'm wrong; I'm assuming your pinion angle is an 'up' measurement.
    So you should have:
    A=3.7
    B=2.3
    C=-8.9
    The equation is:
    A+B+C=0
    You have:
    (3.7)+(2.3)+(-8.9)=-2.9
    I'd try a 4-5 degree shim.
    Couple other things to consider:
    -slipjoint extends with lift; less bearing surface in the slip joint can cause vibes
    -up/down is only one dimension of the true working angle; left/right is the other.
  19. Jun 16, 2020 at 4:17 PM
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    A. 2.6
    B. 3.5
    C. 1.89
    6112 front on 6/5 clips
    5160 rear with Dakar mediums and 2.5 degree spacer. No carrier drop and no vibrations.
  20. Jun 16, 2020 at 4:19 PM
    Pilsner
    18 TRDOR
    Except A to B angle would be improved by carrier drop and B to C would be improved with shims. Shims won't change much A to B as they rotatetrotate axle not the shaft.
