Something is Leaking...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Maj0rMalfunct10n, Feb 9, 2012.
  1. Feb 13, 2012 at 1:06 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    and always remember a little bit of oil goes a long way covering almost everything along the way
  2. Feb 13, 2012 at 1:32 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I was thinking the same thing. Seems pretty obvious; check out the arc or oil slung up above the shaft.
  3. Feb 13, 2012 at 1:42 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    This is a known problem with the PreRunners, here is the TSB : http://www.tacomaworld.com/forum/2nd-gen-tacomas/45728-new-tsb.html
    The pan is lower than the leak so you shouldn't lose much fluid unless you're parking on an incline.
  4. Feb 13, 2012 at 3:11 PM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    Thats just the shaft seal. If you know how to do them they are really easy. If not have a shop do it. Its a $15 seal.
  5. Feb 17, 2012 at 8:24 AM
    Wired
    Wired Member
    Chino Hills
    06 PreRunner TRD Sport
    Don't smell burning. I can't seem to pinpoint where its coming from exactly. But it is around the knuckles, not a lot but I see it. There aren't much grit around there though.
  6. Feb 17, 2012 at 8:26 AM
    Wired
    Wired Member
    Chino Hills
    If its really just the seal. I'd be very glad. I am hoping you're right on the money. I am not handy with this. Will probably take it into a shop if indeed its the seal.
  7. Feb 17, 2012 at 8:27 AM
    Wired
    Wired Member
    Chino Hills
    You are dead on. I am parked on an incline driveway (almost 25 degrees). I noticed its a very slow leak. Slow but I'm concerned it is indeed leaking and its already affecting the tranny.
    After checking out the TSB, I am hoping it is indeed the same problem with mine. I'll get an update once I take it in to the dealer to get this looked at.
    Thanks for the finding and sharing about the TSB.
  8. Feb 17, 2012 at 8:46 AM
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    So what happened to the op's problem? I know the guy who posted the tranny leak got his issue resolved
  9. Feb 17, 2012 at 9:50 AM
    Wired
    Wired Member
    Chino Hills
    Ok. The dealer got back to me on replacing the A750E Transmission Extension Housing Seal. They said its gonna be $338 and they'll include a transmission service. Which in my mind is YIKES! Because they charge $179 for the transmission service but if I got this done together, he was gonna give me a break. Really, I see the only labor comes from replacing the seal. If i didn't want the tranny service, he said it was going to be $288. And the cost of that part number 90311-40034 is only $8.50.
    So I went and found this youtube video on changing tranny fluid. http://www.youtube.com/watch?v=Sdq30go2V7w
    It's not as tough as I had imagine. Just kinda tough getting the new fluid in such a tight area.
  10. Feb 17, 2012 at 12:24 PM
    maxamillion2345
    maxamillion2345 Well-Known Member
    Max
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Just use a pump. Changing the seal on that would be easy. DIY save a fortune.
  11. Feb 17, 2012 at 12:29 PM
    maxamillion2345
    Max
    Nevada
    Cummins, tons, 40s
    Pull the drive shaft. Pull the seal. Tap the new seal in using a socket of appropriate size. Use feeler gauge to make sure it's seated correctly. Reinstall everything. Follow the video and refill your tranny.
  12. Feb 17, 2012 at 6:18 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    According to the Toyota FSM, you should slightly overfill the transmission and pull the overflow plug while the engine is idling and replace when the fluid slows to a trickle - and yes it makes a difference (maybe by 300-500 ml)
    The proper level must be achieved while the fluid is circulating around the system, not when its settled in the ATF pan with the engine off.
  13. Feb 17, 2012 at 6:28 PM
    Fortech
    CANADA
    After watching the video a few more times the dude in the video has the right idea, but some misinformation also regarding the proper level, verifying the proper level, and the total capacity of the transmission.
    I did a DIY write up awhile back of the same procedure strictly following the Toyota Factory Service Manual. For something as expensive as an automatic transmission, you want to ensure you're doing it correctly. i tried it both ways, and yes it does make a difference !!
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/63851-how-drain-refill-automatic-transmission.html
  14. Sep 1, 2019 at 9:14 PM
    Heyitssteve0331
    Heyitssteve0331 Active Member
    07 taco
    Procomp leveling kit,carven exhaust,headlights,full JL Audio system
    I have a similar leak I though it was coming from the rack and pinion but the fluid is still topped off it’s a clear liquid that’s on my drive way I can’t figure out where it’s coming from.
  15. Sep 2, 2019 at 6:58 AM
    #35
    Taco-mama
    Taco-mama Well-Known Member
    2015 DCSB Prerunner
    What's it taste like???
  16. Sep 2, 2019 at 10:13 AM
    #36
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Chicken and kelbasa respectively. :rofl:
  17. Sep 2, 2019 at 10:19 AM
    #37
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
  18. Sep 2, 2019 at 10:24 AM
    #38
    Heyitssteve0331
    07 taco
    Coolant
