Something is Wet in my rear wheel.
Discussion in '1st Gen. Tacomas (1995-2004)' started by emglishe30, Sep 7, 2009.
  1. Sep 10, 2009 at 9:51 AM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    x2 but I didn't do the diff breather.
  2. Sep 10, 2009 at 9:40 PM
    Sheepdog
    Sheepdog Well-Known Member
    Gary
    San Diego, CA
    Black 2002 Tacoma Xtra Cab, 4x4, TRD, SR5
    Eibach/Bilsteins, Beefed shackles, Bushwacker Cut-Outs, Custom roll bar, TG Sliders, Elite Front Bumper, XRC8 Winch
    I had the VERY sam problem, only on BOTH sides. You have two seals on either side. The inner seal is easily replaceable, the outter seal requires you to change the bearings when you replace the seal. I went and picked up two inner seals, two outer seals, and two bearings. It's cheap and easy to replace, just tedious. After replacing the seals and bearings, you should redo your axel fluid, in case it's low due to the leaking, and put additive in the diff for your locker.
  3. Sep 11, 2009 at 4:45 AM
    Ktaco
    Ktaco Well-Known Member
    New Brunswick, Canada
    03 Black 4x4 TRD SR5 Xtra cab.
    Grey wire mod, Deck plate mod, diff breather mod. K&N air filter. Toytec coilovers. AAL. Custom rear lift shackles. diff drop. Centerforce clutch. Superwinch LP8500 with custom "behind bumper" mount. Winch solenoid relocation with in cab winch control. 33x12x15 Duratracs. Aisin manual hub swap.
    Unless the bearings are bad then you just need to worry about the inner seals. The outer seals just act as a barrier for mud, dirt, etc. They won't stop oil from passing through.
