Soooo many transmission fluid questions....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toots, Jul 24, 2020.
  1. Jul 24, 2020 at 9:39 AM
    Toots
    Toots [OP] New Member
    Nigel
    2010 Tacoma
    So many questions, & so little time...
    1. Should I change/flush it, or just leave it alone?
    2. Why is ATF type WS so hard to find?
    3. Can any other type be substituted for type WS?
    (2010 V6 5-speed, 245,000 km, no issues)
    Thank you
    Rambo MARINE Recon likes this.
  2. Jul 24, 2020 at 10:05 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Fluid exchange, not a power flush.
    Use Valvoline Maxlife.
    Lots of threads on here to help and guide you.
    Micbt25 likes this.
  3. Jul 24, 2020 at 1:13 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    1. I’d at least do a drain and fill.
    I would not do a flush unless it is done PROPERLY.
    2. It’s not hard to find here in the U.S.
    I saw it setting on the self at the dealer here in East Tn just last week?
    I don’t recommend mixing, so I’d use WS for a drain and fill.
    If you go full “flush” there are better options.
    3. Yes, see below.
    https://www.tacomaworld.com/threads...a-ws-atf-automaitc-transmission-fluid.373083/
    https://www.tacomaworld.com/threads...e-get-it-out-of-your-transmission-now.331521/
  4. Jul 24, 2020 at 2:34 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Question is where are you located.
    Think of it this way, you have 245k km on it. If you can get the proper toyota WS fluid from a toyota dealer even at 2x the cost of the valvoline maxlife id personally go with the proper fluid considering it has gone that long so far without issue. That stated if its hard to get ahold of the maxlife is great fluid.
    Proper way to do it is laid out in the DIY thats stickied, drain pan, fill with fresh, then turn the truck on and pump out 2ish quarts at a time filling the trans in between each 2 quart pumped out.
    RoughRder likes this.
  5. Jul 24, 2020 at 9:35 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Like others have already said. Drain and Fill, but NO Flush!! :thumbsup:
    I've always like Toyota ATF Type WS. But that's just my personal preference.
  6. Jul 24, 2020 at 10:13 PM
    ardrummer292
    ardrummer292 500k or bust
    Austin
    Virginia Beach, VA
    2015 DCLB V6 A/T 4x4 1D6
    Overbuilt daily driver
    Following in case a consensus is reached about drain-and-fill vs. occasional full flush. I have both in my maintenance tracker, at 60k miles and 120k miles respectively.
  7. Jul 25, 2020 at 6:08 AM
    centurion
    centurion Well-Known Member
    Northern New Jersey
    2006 Tacoma TRD Sport,double cab, 4X4, auto, speedway blue
    Air-Raid air filter, de-badged,custom grill,hood and tailgate struts
    Drain and fill only gets 3 quarts, you can flush using the trans own pump, the procedure is more involved and will use 12 quarts but it's the better way to go. The sticky by gearcruncher is amazing and contains everything you would need to know about your trans. You can get toyota atf ws on Amazon.
  8. Jul 25, 2020 at 8:14 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    If you are in the U. S. Toyota ATF WS is usually all over ebay. I've bought a lot of it there.
    People talk a lot about Maxlife and I'm sure it's good, but Walmarts Dex-VI is also rated WS. I have been running it for years in one of my WS-required Toyota cars.
  9. Aug 7, 2020 at 3:45 PM
    SpyderMan
    SpyderMan Well-Known Member
    Morgan Hill, CA
    05 TRD
    I recall buying mine at the dealership since I have one close by.
  10. Aug 7, 2020 at 3:47 PM
    SpyderMan
    Morgan Hill, CA
    05 TRD
    Had a drain and fill done by a local service station and still had rough shifting. Added a little more fluid and it went away after a few miles.
  11. Aug 8, 2020 at 7:51 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This only ^
  12. Aug 8, 2020 at 9:22 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Drain and fill. I’ve used Maxlife before. Now I use Amsoil blue cap. My first change I disconnected the return line and used a longer hose. Measure how much comes out of the pan. Take a gallon jug and measure a half a qrt less what came out of the pan. 4 qrts out of the pan measure 3.5 qrts on the jug.
    Fill the pan with 4 qrts. Start the truck with the return hose in the jug. Fill the jug to 3.5 qrt mark. Turn off the truck and fill with 4 qrts. Repeat till the fluid is new. Put the transmission into temp check mode.
  13. Aug 8, 2020 at 9:54 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    1. If you flush with the 12V pump DIY method, it should be fine. You'll have to add more fluid through the fill port after the process, then check the level per this guide. If you take it to a shop, a flush may be more stressful to the transmission depending on the equipment they use.
    2. WS despite its name, is effectively a Toyota proprietary standard.
    3. If you choose to do a drain & fill (i.e. new fluid mixing with old), stick with Toyota WS from the dealer. If you choose to do a flush, aftermarket brands like Valvoline Max-Life can work.
    How much longer are you planning to keep the truck? Are you in Canuckistan? The frame warranty lasts until 2022 if you did the CRC campaign earlier.
  14. Aug 8, 2020 at 2:18 PM
    737mechanic
    737mechanic Member
    Dallas Tx
    2011 Tacoma 4X4 Access Cab
    Stay away from Toyota WS ATF, Go with Valvoline Maxlife. I found a document years ago put out by ATRA where they say Toyota WS fluid isn't any good and they recommended switching to Valvoline Maxlife for longer life.
    If you decide to stick with Toyota WS fluid make sure you change it every 30,000 miles. If you switch to Maxlife you can go 100,000 before you change the fluid.
    WS fluid is not Synthetic.
    gearcruncher likes this.
  15. Aug 8, 2020 at 2:30 PM
    gearcruncher
    Canadain bumper technician
    If I had my choice of fluids when dropping the pan and filter , then flushing if the contamination was low in the pan , I would run Lubeguard full synthetic .
    WS is semi synthetic .
    Lubeguard fully synthetic fluid was introduced in 2019 .
    Good stuff !!!
    https://www.lubegard.com/products/atf/
    1rooster and Daves300 like this.
  16. Aug 8, 2020 at 2:42 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    there are at least a dozen different types o Transmission Fluids
    they All are NOT the same
    Stuff in at the factory is usually really good stuff
    they should sell the same at mark up
    many Marques have ' NO Touch ' auto trans
    normal conditions the owner need NOT bother
    crank
    put n gear
    drive !!!
    if Ur driving is High Cycle
    if U tow a lot
    Hi heat
    it is well to have a level o concern
    6 speed ........8........10 .......lock up
    dual clutch trans are very complicated
    draining/flushing in drive could present issues
    1st person anecdotal some1 will say they have done it
    will do it .............. no issues
    there again some wont be that lucky
    im in the camp
    check if ok leave alone
    good luck
  17. Aug 10, 2020 at 5:53 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    I just had a local mechanic drain and fill my trans with Toyota fluid and the tranny so smooth now . 119,000 mi on the truck , I don’t think it’s been touched before. I’d def do the same thing again
    Lukass likes this.
  18. Aug 10, 2020 at 6:17 PM
    Daves300
    Daves300 TTC#0333
    Texas
    2007 FJ
  19. Aug 10, 2020 at 6:23 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    if you don't run Royal purple or AMSOIL ATF your transmission will automatically grenade within 5 minutes
  20. Aug 11, 2020 at 6:59 AM
    Tah-koh-mah
    Tah-koh-mah Well-Known Member
    2012 Tacoma TRD-Off Road
    I have a Tundra with original Toyota WS atf going on 300k without a single transmission problem. We beat the crap out of it too. I like to stay away from anything that claims to be "universal" ATF fluid whether it's synthetic, dino, liquid gold, unicorn blood, or mermaid secretions, doesn't matter to me. I know people who have problems with maxlife and went back to Toyota WS and problems went away. I had a Sienna van that drove great until I switched to valvoline maxlife and in about a month developed a shudder that I could not figure out how to fix. I switched back to Toyota WS and it went away, drove smooth as butter. Same thing with a 4runner my uncle had, he switched to maxlife at 100k for about a year and noticed it just wouldn't shift the same, would sometimes slip from 2nd to 3rd but he drove it like that until he told me about it. I asked him to switch back to Toyota WS and he tried that and it fixed all his problems, it's now going on 370k without a single problem since, and he beats the hell out of that thing. Again, use what you want and believe what you want. I'm just here telling you my experiences with it, and I got more stories, but I gotta go work. Toyota transmissions can be a fickle bitch so I would use the oem fluid designed for it. Just my 2 cents.
    Chiloquin_Car_Care and BillsSR5 like this.
