Sound insulating a 2004 Tacoma, reg cab . . .
Discussion in '1st Gen. Tacomas (1995-2004)' started by Aron9000, Mar 15, 2018.
  1. Mar 15, 2018 at 4:21 AM
    Aron9000
    Aron9000 [OP] Well-Known Member
    Aaron
    2004 Tacoma 2wd stripper
    Uh, a tool box
    Well how much material do I need???? Its a 2004 Tacoma, Reg cab, 5 speed, no option type of truck. I want to run sound insulation under the carpet, up the firewall, all around the trans tunnel, up the back of the cab wall, on the doors(I plan to replace the door speakers as well), basically if there is a surface besides the a-pillar, dash and roof, I want to sound insulate it. I plan to pull the one piece bench seat out, carpet out, door panels off.
    Any recommendations on material would also be appreciated.
  2. Mar 15, 2018 at 4:48 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    For my double cab, I used 4 Rolls of Frost King, available at Home Depot. I did floors, doors, back wall, as well as roof. I put it on the outside skin of door as well as on the surface right beneath the plastic panel. Worth the effort, really cut down road noise, especially since I have mud terrain tires. You need to have a j-roller ($7 on Amazon)
  3. Mar 15, 2018 at 10:07 AM
    95GLH
    95GLH 4WD Noob
    Nick
    Westminster, MD
    1995 Tacoma SR5 4x4, the bottom bitch. 2018 Tacoma 4x4 DCSB OR, wife's truck.
    95 - Rust 2018 - '19 Pro grille, Westin HDX drop steps, Spidertrax 1.5" spacers
  4. Mar 15, 2018 at 11:40 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    I used this (below link) in my double cab. As stated above, make sure you get a roller.
    Let it sit out in the sun and it will be much easier to work with. I applied to the outer skin of the doors and along the transmission tunnel. I also used two rolls of the Frost King (Home Depot).
    Make sure you purchase some plastic door clips to have on hand if you remove the door panels. No matter how careful I was, I had some break just from old age.
    https://www.amazon.com/gp/product/B01KZ5X7KO/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
