Sound Problem in Stock Radio with Satellite Radio
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jabrackin, May 17, 2011.
  1. May 17, 2011 at 4:39 PM
    jabrackin
    jabrackin [OP] Well-Known Member
    Knoxville, TN
    2008 TRD OffRoad
    My sound that I get while on FM is a lot louder compared to XM sound. Is there something that can be done? You almost have to turn the volume all the way up to hear the sound.
  2. May 18, 2011 at 6:04 AM
    tombiosis
    tombiosis Well-Known Member
    T
    Ottawa Canada
    2016 TRD offroad access
    2016 Tacoma Access Cab, Super White, TRD Off Road package,//OEM Running Boards//TriFold2.0 Tonneau Cover//FJ Cruiser TRD SE Black TrailTeams replca wheels!
    Make sure the volume is all the way up on the sat unit. usually they re-set everytime you turn off the vehicle, so you have to crank it up on each use.
    Big pain when you switch back to CD or regular tuner as you could blast your head off with volume!
  3. Jul 26, 2011 at 4:37 PM
    ddmag52
    ddmag52 Well-Known Member
    2011 magnetic gray trd sport
    Fog light mod.
    Mine to.
  4. Jul 26, 2011 at 6:11 PM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    Sounds like you need to add an inline amplifier to boost the volume.
  5. Jul 26, 2011 at 6:29 PM
    AstroMike
    AstroMike Member
    11 Access 4cyl SR5 4X4 Auto
    Had the same problem when using the AUX input. The Sound Shocker passive inline amp from PHPaudio.com did the trick. Instead of having to turn the volume up to 45 to hear anything, I can now listen normally at 25-30.
  6. Jul 26, 2011 at 6:54 PM
    ddmag52
    Fog light mod.
    so this will work in a factory stereo?
  7. Jul 26, 2011 at 7:02 PM
    AstroMike
    AstroMike Member
    Sorry, misread your initial description. The Sound Shocker is for connection through the AUX plug.
