Sound system issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dieselfxr1, Sep 20, 2019.
  1. Sep 20, 2019 at 7:52 AM
    Dieselfxr1
    Dieselfxr1 [OP] Active Member
    2018 Black TRD Sport Dbl cab
    None yet
    Recently starting having problems with my system! I have the PAC Amp Pro AP4-TY12 and a JL500 amp driving front, rear door speakers and a sub! The right front door speaker has barely any sound coming out, just voice, but faint! The rear door speakers cut out for a second or two as I’m listening!!! This is very annoying to me! All my connections are good. I’m wondering if the issue is with the digital processor or the amp? I did set the gains with a meter so I kind of ruled that out? Thoughts please!!! Thanks
  2. Sep 20, 2019 at 7:57 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Why are you yelling?
    Mtn Mike likes this.
  3. Sep 20, 2019 at 7:57 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Check the impedance of the speakers. Drowning how everything is wired also make sure your amp can handle the impedance. Also check the wiring just to be sure if that all checks out. If you have an old speaker maybe run that on the channel and see what happens. Maybe sure the amp has a good ground. Also make sure it’s running at the proper voltage. If that’s all good make sure it’s not clipping and going into protect or something. JL is quality stuff so when it’s going into protect you shouldn’t get any sound. So I doubt it’s that but worth the check.
  4. Sep 20, 2019 at 9:02 AM
    Dieselfxr1
    None yet
    I actually need to find some time to dedicate to this issue! I just started the process! Thanks for the information, I’ll try that!
    P.S. I don’t understand why GreyBaldTaco asked why I’m yelling???
  5. Sep 20, 2019 at 9:10 AM
    GreyBaldTaco
    2019 F150 5.0
    All the exclamation points.
