Sounds like marbles behind timing cover
Discussion in '1st Gen. Tacomas (1995-2004)' started by BluCallrBallr, Nov 20, 2018.
  1. Nov 20, 2018 at 2:40 AM
    BluCallrBallr
    BluCallrBallr [OP] Member
    2003 Tacoma TRD
    I have a well seasoned 03 double cab with the 3.4. 250k miles. Long story short, I've noticed a few new sounds for a few weeks gradually increasing in sound & frequency. While waiting in drive thru at InNOut last night the noises stopped for a minute then it sounded like marbles bouncing in engine block. It runs fine, shifts normal. Checked flexplate no damage, noticed small amount of coolant on what I assume is weephole. But it doesn't leak enough to puddle or run hot at all. It's been about 125k since pump & timing belt replaced. Is it possible my water pump is functioning half ass despite being in several pieces inside motor? Is it common for pumps to go out in such a dramatic fashion? I'm at a loss on what else is making the noise. There is no pattern, revs don't change sound nor shifts. I found the awesome link & steps for replacement put together by other members. I'm mechanicly inclined enough to my rebuild 4-stroke dirt bike motor top & bottom. Regaurdless of my lack of confidence I have no choice but to give it go myself. Any advice or insight would be greatly appreciated.
  2. Nov 20, 2018 at 5:49 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    if it's been 125k since you last replaced the timing belt, I would replace it as soon as possible, because timing belts must be replaced at around 90k intervals
    Can't say the culprit for sure is the timing belt, because a worn belt won't sound like marbles (if you had a timing chain, yes), but it definitely wouldn't hurt to replace it
  3. Nov 20, 2018 at 6:19 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    Water pump bearings would be my guess, change it and t belt asap
  4. Nov 20, 2018 at 6:46 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
  5. Nov 20, 2018 at 6:48 AM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    I would Do a timing belt/WP kit asap.
  6. Nov 20, 2018 at 7:16 AM
    JMB711
    JMB711 Well-Known Member
    2000 Tacoma
    None
    If you can rock the pump shaft its time for a new pump.
  7. Nov 20, 2018 at 7:44 AM
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    If its loud, most likely your water pump. When I was new to wrenching I thought an engine was destroyed because of the noises a water pump was making. I'd also replace all your idlers when doing the timing belt as the bearings in one of those could make some significant noise as well.
    BluCallrBallr[OP] likes this.
  8. Dec 9, 2018 at 5:15 PM
    MitochondriaMan
    MitochondriaMan Well-Known Member
    MitoMan
    Florida, USA
    04 3.4 TRD 4WD
    Tundra hyper-silver double 5-spokes with 265-70-17 BFG All-Terrains. Compact Cobra CB in the ashtray slot. Cut a small hole in the plastic and mounted the antenna to the drivers side windshield wiper mount using an old Harley Davidson blinker bracket. 1 1/4" drywall screw is holding door handle together nicely.
    Tensioner went out? It doesn't take much slack for a belt to start slapping the plastic.
    Maybe last tb swap didn't get a new tensioner?
  9. Dec 9, 2018 at 5:43 PM
    FirstTimeFirstGen
    David
    Pacifica
    OP has posted once since March 2017. Chances are we will never know....
  10. Dec 9, 2018 at 5:50 PM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    This thead was started by OP Nov 20 2018.
  11. Dec 9, 2018 at 5:52 PM
    FirstTimeFirstGen
    David
    Pacifica
    Correct, but he only has one post since he joined the forum in March 2017.
    BluCallrBallr [OP] New Member
    Start a Conversation
  12. Dec 9, 2018 at 5:55 PM
    mwrohde
    Sugar Hill, GA
    And this is it. You could be right, but there's no evidence, yet, that says this person asks questions then doesn't follow up.
  13. Dec 10, 2018 at 8:14 PM
    BluCallrBallr
    2003 Tacoma TRD
    Update on my marbles... Tore it down, water pump was the culprit for all the noise. The shaft bearing gave up the ghost. For having 90k on timing belt it looked relatively decent. Tensioners were close to service limit. I went with the recommended kit from Asin $330. I can't say enough about that write up the members put together. Between that and a couple YouTube videos I slowly but surely got it together. Only hiccup was every plastic piece I touched broke. But she's back in action 251000 miles young. I want to thank everyone for their input. The process would still be on going without that tutorial. No more freezing my ass off riding my motorcycle to work. For that I am grateful. Happy holidays
  14. Dec 11, 2018 at 5:57 AM
    FirstTimeFirstGen
    David
    Pacifica
    Wow. I really didnt expect an update. I guess my overly pessimistic ass was wrong.
    Thank you for the update and happy to hear you got her done!
  15. Dec 11, 2018 at 10:54 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    woo hoo! glad you got 'er fixed!
    I did my timing belt a couple years ago, and was rather hesitant at first. I had done timing chain and head gasket work on my old 22r-te 4runner before, but the Taco was my daily driver, and it HAD to be done before the weekend was over.
    I probably obsessed over the same videos and write-ups you did, and they were a godsend.
  16. Dec 22, 2018 at 7:51 AM
    JMB711
    2000 Tacoma
    None
    Just replaced my idlers $16 apiece at Rockauto.
  17. Dec 22, 2018 at 10:24 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I would almost be willing to bet the W/P was original and not changed with first belt change.
    I've come to believe it's ridiculous to change a timing belt that often (on schedule) unless it takes 10 yrs. to reach that mileage.
    150K would be my target change.
    FirstTimeFirstGen likes this.
