Soy coated wiring
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 8tac0ma8, Jun 28, 2022.
  1. Jun 28, 2022 at 1:30 PM
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
  2. Jun 28, 2022 at 1:38 PM
    IcePlant
    IcePlant Well-Known Member
    Vince
    2017 BLACK TACOMA TRD SPORT DCLB 4X4
    -King 3" Lift -Leitner ACS Forged Bed Rack -TRD Pro Stainless Steel Cat Back Exhaust -TRex/ZRoadz Light Bar Grille
    I have a 2017 Tacoma, live in Illinois and park in garage. Just recently, at the beginning of the month, a mouse chewed some wires in my engine. I know for sure they chewed the knock sensor wiring and possibly more...I haven't begun the repair process yet, but it's not going to be fun.
    I've been working on cleaning up around and inside my garage to make it less appealing for the mice.
    For now, I'm using several bars of Irish spring soap around the engine bay and mouse traps until I finish organizing the garage, then I'll replace the harness...
    Never thought it would happen to me. I would just say keep your parking area clean and clear and don't let the truck sit too long. Once I fix my truck, I might drop peppermint essential oil around the engine bay once in a while.
  3. Jun 28, 2022 at 3:16 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Peppermint oil soaked cotton balls works, but doesn't last very long. Found it needs reapplying every 3 weeks. My hot pepper spray lasts longer.
  4. Jun 28, 2022 at 5:48 PM
    Jsmitty21
    Jsmitty21 New Member
    2019 Tacoma SR5 Double Cab Long Bed Magnetic Gray
    None - yet
    Had the same prob with my atv. Moth balls seemed to do the trick - no more problem.
    zoo truck likes this.
  5. Jun 28, 2022 at 6:10 PM
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
  6. Jul 7, 2022 at 11:48 AM
    IcePlant
    Vince
    I just had mice chew my knock sensor wire harness. I repaired it and took a video, let me know what you think. Thanks! https://youtu.be/SVtMoHSo_cQ
    davidstacoma likes this.
  7. Jul 7, 2022 at 2:34 PM
    Mikeh80
    Mikeh80 Well-Known Member
    OHIO
    2022 TRD OR DCLB
    Used cat litter is best for obvious reasons.
    S2KON2[QUOTED] likes this.
  8. Jul 7, 2022 at 4:14 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  9. Jul 7, 2022 at 4:36 PM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
  10. Jul 7, 2022 at 5:58 PM
    rainsux
    rainsux Well-Known Member
    2021 Tacoma Off Road
    None.
    Mouse Blocker Pro (tm) is available in 120V and 12V flavors.
    It solved my mouse problem in the hangar. The motion-triggered security camera no longer logs their hangar parties.
    https://mouseblocker.com/
    It also keeps the neighbors’ free-ranging dogs far, far away.
  11. Jul 7, 2022 at 8:52 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    I asked my dealer and they said that Toyota has been using soy insulated wiring since 2006. They said that by 2016, all mfgs had switched over. They also said it was due to a worldwide attempt to reduce petroleum usage. So they're lying to me?
    davidstacoma, AxisCab and Taco Tyrant like this.
  12. Jul 8, 2022 at 3:02 AM
    RLMoody
    RLMoody Well-Known Member
    2017 Toyota Tacoma SR
    I was told that at the Ford dealership as well about the soy-based wiring by our service manager. In 2018 before I quit it was still being used in the Fords. It is a serious problem from what I saw there. I'm not sure if insurance covered the repairs but I often saw complete harness's being replaced. When I asked why they said that often they would find other areas of the harness damaged as well. It also made the dealership a lot of money. Every week I saw at least one car come in with damage. We had a Fusion show up with a nest of those little buggers in the air cleaner.
  13. Jul 8, 2022 at 3:13 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Use the hillbilly mouse/rodent trap but instead of water, use old antifreeze IF it's in a area where animals like dogs or other ''good'' critters are. Antifreeze doesn't allow them to decay as fast and can be disposed of as needed like you normally would.
  14. Jul 8, 2022 at 3:30 AM
    rainsux
    None.
    Yazaki manufactures wiring harnesses for MANY auto companies. I know the prior VP that ran their NA and Europe business. I will inquire about this soy vs. not-soy debate … his reply:
    “Wire insulation is mostly variants of PVC, with modifiers for high temp applications, and some additives to make it less attractive to rodents.
    There are some soy based plastics used in vehicle applications but not as far as I know in wire insulation.”
  15. Jul 8, 2022 at 2:49 PM
    #35
    RLMoody
    DJinTN
    I saw the dead mice. I saw the damage from chewed up wiring to foam engine covers being swiss cheesed. It is actually pretty gross having to try to clean up the damage these mice are doing.
    The service manager, service advisors and mechanics have all told me Ford was using soy-based wiring. Fake News? Where have I heard that before?
  16. Jul 8, 2022 at 3:55 PM
    #36
    AxisCab
    Dave
    I am equal parts disappointed, and relieved
  17. Jul 8, 2022 at 4:10 PM
    #37
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Well, assuming this poster is not lying about his credentials, can we finally put this fucking soy wire thing to bed!
    Let me help by proposing a new and exciting topic; oil change frequency at 5,000 or 10,000 miles? Discuss!
    hiPSI likes this.
  18. Jul 8, 2022 at 4:18 PM
    #38
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    i had this problem with motorcycles and boats and equipment, etc.. rats love chewing wiring up, even if it has no soy. LoL
    rats usually only make homes in things that don't move every day.
    if you're truck moves every day, they are not likely to make it their home.
  19. Jul 8, 2022 at 5:19 PM
    #39
    RTweet
    RTweet Well-Known Member
    Oregon
    2021 White TRD Pro, MT
  20. Jul 8, 2022 at 5:33 PM
    #40
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
