spacer and bilstein 5100s?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by persianboy1769, Dec 1, 2009.
  1. Dec 1, 2009 at 11:27 AM
    persianboy1769
    persianboy1769 [OP] Member
    josh
    chino hills
    Procomp 3" spacers with aal, procomp rims with 265/70/17 nitto terra grapplers, 6k hid headlights 3k foglights with yellow film, Flowmaster muffler, k&n intake
    I have a 2009 tacoma and have procomp 2.5" lift spacers. I ordered bilstein 5100s that adjust to 2.5" lift. What is the difference if I take the spacer out and lift with the shock vs leaving the spacer in and keeping the shock at 0"? Will there be less stress on the shock if I leave it at 0" and keep the spacer? I'm also getting a shrockworks bumper and skid plate which weigh about 130lbs so I was leaning towards lifting the shock only 1" and keeping the spacer to keep the same height even with the sag from the extra weight. Thanks for reading.
  2. Dec 1, 2009 at 11:39 AM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Don't leave the spacer and use the shock for lift as well. Ditch the spacer and use the shocks for lift. Also, you might want to think about saving up for some adjustable coilovers since you will adding weight.
  3. Dec 1, 2009 at 11:42 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    ^yup yup. maybe instead of coilovers get a set of ome springs like 885's or 886's which will probably save you some money since you already ordered 5100's. then the stiffer springs will accomodate the added weight without using spacers, not a favorite of most people.
  4. Dec 1, 2009 at 11:43 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    +1 on the upgraded coilovers- Either the OME 886 coils or any of the adjustable ones.
  5. Dec 1, 2009 at 11:55 AM
    persianboy1769
    josh
    chino hills
    Ok thanks. What's the difference from 5100 shocks and new springs vs. Coilovers besides it being one unit?
  6. Dec 1, 2009 at 11:56 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Most coilovers are rebuildable. Also, they would be adjustable allowing you to set whichever height you want. Also allows you to compensate for taco lean.
  7. Dec 1, 2009 at 11:58 AM
    08pretaco
    az
    you can also use a 1/2" spacer to accomodate the laco lean if you dont go the coilover route
  8. Dec 1, 2009 at 12:00 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    X2^
    coilovers are expensive but will give u a better ride too IMO
  9. Dec 1, 2009 at 12:08 PM
    08pretaco
    az
    oh i dont doubt c/o give better ride thats why im changing to some lol. it all depends how much money you want to spend
  10. Dec 1, 2009 at 12:10 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Yea they can get expensive. Only downside. Lol. You have some spindles to install correct?
  11. Dec 1, 2009 at 12:17 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I got 5100's all around and OME 885's up front. Love the ride it gives!!;)
  12. Dec 1, 2009 at 12:23 PM
    persianboy1769
    josh
    chino hills
    Ya I wanted camburg c/o but there too much for right now maybe down the road when I get some more money. For now bilsteins sound like the best route for me. Firefighter what size tires are you running?
  13. Dec 1, 2009 at 12:25 PM
    persianboy1769
    josh
    chino hills
    And what are the shocks set to? 2.5"?
  14. Dec 1, 2009 at 12:28 PM
    08pretaco
    az
    yes sir hoping to get those and the c/o installed towards the beginning of this month so that i can enjoy them during xmas break
  15. Dec 1, 2009 at 12:30 PM
    08pretaco
    az
    shocks set at zero to be safe when you use 885's. otherwise your extending your travel to far risking breaking the shock and ruining the joints
  16. Dec 1, 2009 at 12:33 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    This is all semantics...but it's my pet peeve....Even the STOCK suspension is a coilspring over shock assembly (coilover for short).
    Being "adjustable" does not make something a coilover....It makes it an adjustable coilover. My full OME suspension (885s with the OME shocks in front) are coilovers.
    The real differences between the 5100s with the stock springs, the OME lift, and the Toytec lift is the spring length and spring rates. Longer or stiffer springs cause lift, as does compressing a stock spring further than normal.
  17. Dec 1, 2009 at 12:38 PM
    jonny
    jonny Betty White Edition Heep ZJ
    always thought the same in the back of my head
    :laugh:
  18. Dec 1, 2009 at 1:03 PM
    08pretaco
    az
    if youd like it can change it to aftermarket c/o's for you :)
  19. Dec 1, 2009 at 3:42 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Naw....Just want folks to know the right terminology so when they are shopping for/deciding on parts to buy they don't bypass options or get confused.
  20. Dec 2, 2009 at 3:17 PM
    blendedfamily
    blendedfamily Well-Known Member
    'Burque(sucks)
    Ok -- total noob question, but I've sought out lots of info and simply don't feel educated enough to make a decision to lift my truck.
    Option: Billy's with AAL, 2.5 up front and 2.5 kit in the back to make the truck level, or 2.5/1/5 for current rake...
    Option: OME or Toytec kit which will replace both the shock and springs in the front end, and leaf's.
    Either option will need replacement of the UCA's to correct alignment issues, assuming I'm lifting into the 3" range, right?
    I was told by a total fab yodder that I could shackle the back and add spacers up front, which would be the cheapest option for doing some moderate wheeling, and would be better in the rear end for articulation. After discussing this with someone else, they said they've never heard of shackles in the back.
    What do I do!! Lookin for an affordable way to gain about 2.5" of lift. The truck will be used for moderate wheeling and daily driving. I'd rather go with the safest, most comprehensive way of lifting the truck, cuz like everybody else, I don't want it to break and have to redo it.
    Sorry for the horribly long and lame post, but I cant find a direct answer anywhere... And, I'm not sure if these simple questions have been answered in another forum.
