Spacer help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sambojee, Mar 28, 2011.
  1. Mar 28, 2011 at 3:09 PM
    sambojee
    sambojee [OP] Well-Known Member
    Sam
    Iowa
    2011 TRD OffRoad
    Bilstein 5100 all around set at 2.5. 1.5 AAL in the rear. 265/75/16 Hancook Dynapro MTs on Black Moto Metal 951s. Black badges. Aftermarket grill. TRD seat covers.
    Ive got an 06 Tacoma and just got the 5100s installed and set at 2.5 but they r kinda close to my UCAs and so now i think i should order these http://www.performance4trucks.com/W...t_s=107&t_pt=7576&t_pl=102769&t_pn=SPIWHS-007 r these good wheel spacers to take some offroad aduse? do i need to buy new lugs with these too ir can i use my old one? is 1.25 safe enought to run? i dont want my wheel falling off after a day on the trail then im driving back home and my wheels fall off at 70 mph.Thanks guys
  2. Mar 28, 2011 at 5:40 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    They are awesome...i have them on my truck with no problems...I use them all the time on the freeway about 30% of my driving is done on the freeway 75-80 mph...you still retain your stock lugs but they give you another set to bolt on the spacer to original studs on the rotors...you wont regret them there a top notch spacer and very durable....you just have to check on them every 6,000 mi or so whenever you rotate your tires if you do
