spacer kit
Discussion in 'Street Trucks' started by pinktaco808, Oct 14, 2010.
  1. Nov 18, 2010 at 12:42 PM
    #41
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    still trying to find pics of when he moved his arms up
  2. Nov 29, 2010 at 8:45 PM
    #42
    pinktaco808
    what happened
  3. Dec 10, 2010 at 1:06 PM
    #43
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    nothing yet. still trying to get my audio together (sold my Blazer), thinking about selling one of my bikes to get some rims. Not sure yet. All in all, I do think it is possible to do the spacer, and the camber won't be that brutal.
  4. Dec 10, 2010 at 5:51 PM
    #44
    pinktaco808
    do you know the bolt size and what the original length???? there a hardware store by my house that sells grade 8 bolts that why
  5. Dec 11, 2010 at 8:46 AM
    #45
    07TacoRidah
    no sorry. I may have sometime after the holidays to do the drop but not really sure yet.
  6. Dec 11, 2010 at 2:51 PM
    #46
    pinktaco808
    let me know so that i too can do it thanks man happy holidays
  7. Jan 14, 2011 at 6:53 PM
    #47
    pinktaco808
    any updates man
  8. Jan 15, 2011 at 7:27 AM
    #48
    INTHABLOOD
    INTHABLOOD Active Member
    florida
    06 tacoma...2021 tacoma ...1988 4runner
    2006 tacoma...doored with 2016+ skins and tundra v8 1988 4runner lowered on 2wd chassis with 2tr-fe 2021 tacoma 4 door
    heres my redrilled upper arm mounts i also had to scalp the tops off the mounts to give my uppers room to travel ...its been like this for 5 years and 30k miles now the mounts are not bent or twisted so id say its plenty strong ....hope this helps :cool:
  9. Jan 15, 2011 at 3:12 PM
    #49
    pinktaco808
    scalp the tops off the mounts to give my uppers room to travel??? are you talking about on the inside where the arms meet the corner of the frame???
  10. Mar 18, 2011 at 1:36 AM
    #50
    07TacoRidah
    he's talking about the pocket where the spring sits. since it comes up to an l at the top, the arm won't have much room to swing, ergo why he had to "scalp" it for clearance. I don't know why this was done by Toyota but on the 5 lug models, the uca's are on the sides of the frame, and with the 6 lug models, the uca's are on top of the frame.
  11. Mar 18, 2011 at 7:47 AM
    #51
    pinktaco808
    what you talking about im still lost lol
  12. Mar 18, 2011 at 11:15 AM
    #52
    07TacoRidah
    circled in red.
  13. Mar 18, 2011 at 2:39 PM
    #53
    pinktaco808
    oic now, he cut the top part out
  14. Mar 18, 2011 at 2:48 PM
    #54
    07TacoRidah
    yup, other wise not even the greese zerk would be able to move within the space that is left IF you were to raise the uca bolt holes up an 1" or so.
  15. Mar 18, 2011 at 4:19 PM
    #55
    pinktaco808
    is that from center to center, from edge bolt to center,bolt edge to bolt edge???
  16. Mar 19, 2011 at 10:07 AM
    #56
    07TacoRidah
    center to center
  17. Mar 19, 2011 at 5:50 PM
    #57
    pinktaco808
    thanks brotha
  18. Mar 19, 2011 at 9:22 PM
    #58
    07TacoRidah
    be sure to only cut off the top of the uca bracket. the other guy is bagged, so he doesn't have to worry about his strut. your making room for the uca to travel when need be v. the other guys taco in which he has control over the over all travel of the uca/lca in a sense.
  19. Mar 20, 2011 at 9:24 PM
    #59
    pinktaco808
    ok man, did you finish yours???
  20. Mar 20, 2011 at 11:03 PM
    #60
    07TacoRidah
    haven't even started :( got most of the drama going on in my house done with, just a ticket left and I'm back to usual doing projects.
