spacer lift q?
Discussion in 'Suspension' started by krisjw101, Jul 21, 2009.
  1. Jul 21, 2009 at 10:47 PM
    krisjw101
    krisjw101 [OP] Well-Known Member
    Kris
    Spokane,WA
    09 Tacoma 4x4
    Autobot in my rear window
    just to clear this up in my head, can you still have the alignment issues, shaking, and cv joint issues with a spacer lift? and would you still want aftermarket uca's with a 3" or lest spacer lift?????
  2. Jul 21, 2009 at 10:55 PM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    Spacer is the cheapest and one of the worst lifts you can put on. If you are really on a budget, it will work, but in my opinion, you should save up and get better lift components. Even Bilstein 5100's would be better
  3. Jul 22, 2009 at 12:36 AM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    You will need an aftermarket UCA if you go with a 3" spacer and want to correct your alignment issues.
  4. Jul 22, 2009 at 1:27 AM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    yes, if you lift your truck, regardless of what method of lift you use you will need to have it aligned. aftermarket uca's will help bring alignment specs close to ideal.
    take it from a guy who knows this from experience, please please please spend the extra $50 and get the ome coils and aal from toytec instead of the spacer lift. you will hate it once you get it!
  5. Jul 22, 2009 at 2:55 AM
    Kenny650
    Kenny650 Well-Known Member
    x2
  6. Jul 22, 2009 at 9:56 AM
    krisjw101
    Kris
    Spokane,WA
    09 Tacoma 4x4
    If you were to get a lift and uca's that are a reasonable price, what would you get. if possible will you send links so i can look at them and read about them.
  7. Jul 22, 2009 at 11:51 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    If you run the Bilstein 5100s in the front. You can get 2.5" of lift. To match that you will need an block or aal in the rear that lifts 1.5" As far as the UCA goes. It is not required. The UCA corrects the Caster angle. This keeps the vehicle going nice and straight down the road instead of wandering, but does NOT wear the tires. When you lift your truck the caster becomes low. A lot of people run their stock arms and are just fine though.
  8. Jul 22, 2009 at 12:04 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Go w/ suspension rather than spacer..I wish I would've...just get the Billy 5100s, thats what i'm doing, then you can get the adj. COs down the road :)
