Spacer lift resulted in a clunk
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EvToyRig, Sep 25, 2008.
  1. Sep 25, 2008 at 9:52 PM
    EvToyRig
    EvToyRig [OP] Member
    Mesa Arizona
    06 OffRoad 285/70/17 BFG KM2
    17x9 DC1 Dick Cepek Wheels 3" lift 285/70/17
    Anyone notice a light "clunk" from the front end on their yoters after installing a lift? Just lifted the bad SSA and its either upon light breakage at slow speeds or reverse backing out of the garage I notice a new and unique sound I can't find. Tightened everything I could think of and the only thing left on my list is the alignment.
    PS - I wouldn't sell the truck for a smart car anyday. But I would try to run one over given the (safe & unoccupied) opportunity.
  2. Sep 26, 2008 at 10:43 AM
    Jay_bruce
    Jay_bruce Active Member
    Southern Illinois
    07 Double Cab, TRD 4x4
    5100's up front @ 1.75, LT285 75R Nittos on 16" MB Predator rims.
    Hey,
    Just had that exact same noise. Does it only seem to happen when moving forward or backwards at slow speeds as you brake?
    If so, then I might have your fix-
    Jay
  3. Sep 26, 2008 at 11:34 AM
    EvToyRig
    Mesa Arizona
    Jay, exactly. What's your thoughts pm me. Much appreciated.
  4. Sep 26, 2008 at 11:43 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    got the same clunk whats up with it!!!???
  5. Sep 26, 2008 at 11:47 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    same here, i get it when i go from backing up to going forward out of a parking space. sounds like one of my tires is rubbing on plastic...but I know they are not since I have done some trimming.
  6. Sep 26, 2008 at 11:50 AM
    Dark Knight
    Jeff
    NC/SC
    mine does it when i move forward and let off the gas at slow speed
  7. Sep 26, 2008 at 11:50 AM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    Sounds like a driveshaft clunk to me. Remedy with rear axle shims, dropping the carrier bearing slightly, or if you have the $, a 1 piece driveshaft.
  8. Sep 26, 2008 at 11:55 AM
    Dark Knight
    Jeff
    NC/SC
    yes it is definitely the drive shaft i'm hearing. so which is better the shims or carrier bearing drop, both from Toytech
  9. Sep 26, 2008 at 11:57 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Maybe do both if possible do 1 at a time and list your finding here for future members.
  10. Sep 26, 2008 at 12:00 PM
    Justin626
    Justin626 Well-Known Member
    Palmer, Alaska
    2007 4x4 TRD Sport DC Super White
    Toytec 3" w/ AAL, N-Fab Nerf Bars, Lightforce 170mm Strikers, N-Fab Light Bar, Metra Ipod Adapter, Scosche Auto Start
    Shims worked for me. Easy install!:D You can get them from Toytec.
  11. Sep 26, 2008 at 12:01 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    I have an improvised carrier bearing drop on my 1st gen. It consists of 2-3 washers added to the 2 bolts that hold up the bearing/driveshaft. It helped. I have no experience with the shims.
  12. Sep 26, 2008 at 12:04 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    I installed the shims along with the carrier bearing shims. No troubles here but can't say which one is responsible or if both are needed.
  13. Sep 26, 2008 at 12:05 PM
    Pacostacos
    Pacostacos New Member
    I have this as well and I haven't been able to locate it.. It's a metal on metal clank sound from the front end when lightly tapping the brakes going forward and backward. I also hear a rattle from the front end when going over small bumps.
    I have an 06 prerunner and had the spacer lift installed for about a month with no clanks or rattles at all.. But once I replaced the spacers with 5100s and AAL, I started getting the noise in the front.
  14. Sep 26, 2008 at 12:05 PM
    Dark Knight
    Jeff
    NC/SC
    both routes are cheap so i think i might go for the carrier bearing first and see what happens, gona be 2 weeks i'll let yall know
  15. Sep 26, 2008 at 1:08 PM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Having the same issue, since they are an easy fix, I will do the job myself. What are the Toytec part #'s for the both of them (shims and carrier bearing drop). Will order Monday.
  16. Sep 26, 2008 at 1:13 PM
    Dark Knight
    Jeff
    NC/SC
  17. Sep 26, 2008 at 1:21 PM
    bvalistic
    bvalistic Well-Known Member
    long beach ca
    trd sport
    does this pertain to 4x2 or 4x4?? if it is for both will this be a must have or buy when you're planning to lift the truck or already lifted the truck since alot of you guys are experiencing the "sound" ??
  18. Sep 26, 2008 at 1:24 PM
    Jay_bruce
    Southern Illinois
    Here is what the problem and solution was for me.
    Have your front brakes checked. Seems like when the brake pads wear, a small piece of the caliper loosens (towards the inside). My mechanic replaced my pads and resurfaced my fronts and the noise is gone.
    I was freaked that this was a major problem from my 5100 lift, but that was not the case.
  19. Sep 26, 2008 at 1:26 PM
    Dark Knight
    Jeff
    NC/SC
    any 6 lug, use it when lifting but not a must.
  20. Sep 26, 2008 at 1:26 PM
    Dark Knight
    Jeff
    NC/SC
    Thats probably a good idea to get my breaks checked. I'm at 57000 on original breaks.
