Spacer Sizes?? Revtek, Daystar, etc.
Discussion in 'Suspension' started by canuck_tacoma, Mar 21, 2009.
  1. Mar 21, 2009 at 8:14 PM
    canuck_tacoma
    canuck_tacoma [OP] Well-Known Member
    BC, Canada
    SR5 4X4 Tacoma Access Cab
    1.5" Eibach Front Coil Lift, Rear TSB, 265/75/16 BFG A/T's
    I just got the Daystar 1" top spacer installed and it lifted me about 2 inch's.
    I know some spacer lifts combine top spacers and preload spacers. I was just curious about other spacer lifts and the actual size of the spacers.
    Reason for this, is I am concerned about the maximimum size of top spacer that can be installed before there are problems with the strut being too long. I am pretty sure the Daystar 1" spacer is probably ok. Just checking to see how tall other manufactures are making their Top Spacer.
    Yes it looks pretty good with the rear TSB, I now have 36.5 in the front and 37.25" in the back. I may add a TSB AAL to give me more "rake".
  2. Mar 21, 2009 at 8:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Manufactures make them up to 1.5" giveing a 3" lift. 1" is about the max, and even then, its possible you could wear out your ball joints quickly.
  3. Mar 22, 2009 at 9:53 AM
    canuck_tacoma
    BC, Canada
    Thanks Chris. I wouldn't want to go bigger than the 1" spacer I put in. I actually would have gone with the 0.75" spacer if I had known about it.
    I guess some OME Springs would have been a better route to go. I will ride with these for awhile and see how it feels. It's mostly a Mall Crawler anyway, though I do like to explore some service roads.
