Spacers and 5100's ??????
Discussion in 'Suspension' started by fltacoma08, Jan 3, 2008.
  1. Jan 3, 2008 at 1:02 PM
    fltacoma08
    fltacoma08 [OP] New Member
    Has anyone tried like say a 2" spacer and the 5100's for additional lift? I was thinking of 2" spacers and 5100's for a 4" lift. If so, the post are appreciated.
  2. Jan 3, 2008 at 1:16 PM
    rick
    rick `
    it wont work. you can't use spacers with the bilsteins unless lowest (stock) setting is used. and then you can only lift 3 inches.
  3. Jan 3, 2008 at 1:26 PM
    fltacoma08
    Does any other manufacture make a shock of this sort that is adustable like 5100's? How about a 2" coil with 2" spacer and if this will work how bad would the ride be. What I am trying to do is run 33's and clear with no scrub and of course at a cheap price.
  4. Jan 3, 2008 at 3:08 PM
    rick
    rick `
    i have not seen anyone with a 4" lift on their taco. suck it up and go with a fabtech 6" lift. look into a body lift
