Spacers are bad m'kay!
Discussion in '4Runners' started by TK-422, Aug 19, 2019.
  1. Sep 15, 2019 at 5:47 PM
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    Glad to hear that you pulled off the road at just the right time, that could have been a really bad day!! Thanks for sharing as well, as to no one's surprise, you were quick to be called out for using cheap, non-hub-centric spacers.
    I really want to throw some spacer's on my wife's 16 4R, but it's these kind of stories that prevent me from doing so. I do know to use hub centric, but that risk of failure just for looks is always in the back of my mind. There's also a different accountability when modding the wife's vehicle, haha.
    TK-422[OP] likes this.
  2. Sep 16, 2019 at 2:15 AM
    TK-422
    TK-422 [OP] Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    I have a set of 4 blue Spidertrax hubcentric spacers sitting right next to me but is has been way too hot to install them.
    It's supposed to get under 100* next week but I am also going to replace all the studs just to be safe.
    I can't deal with the sunken in look of the wheels in the standard position after having spacers installed.
    I love the look of the stock rims so I don't want to buy aftermarket ones.
    It would also be a complete waste since I only put about 3K miles on it per year since I have a work vehicle.
    The tires have about 5k miles on them and are like new.
    Crikeymike likes this.
  3. Sep 16, 2019 at 2:53 AM
    TK-422
    So Cal - SCV
    2015 4Runner TEP
    I ordered 8 more rear studs and 14 front studs so I would have extras in case I had problem ones.
    It came to about 80 dollars.
  4. Sep 17, 2019 at 5:47 PM
    daltondrose
    daltondrose Well-Known Member
    Dalton
    Forest Grove, OR
    2019 Tacoma TRD Pro Voodoo Blue, 2008 FJ MT Sand Storm / White
    • Victory 4x4 front Strike Bumper • Warn Winch Zeon 10 Synthetic • White Knuckle Offroad Rock Rails • Prinsu Full Rack System front and rear • ARB On Board Twin Air Compressor • Nitro 5:29 gears w ARB Air Lockers • 315 70/17 BFG KM3 • 17” Wheels KMC XD with Matching Spare • Decked Storage System • SnugTop Canopy with Windoors • Expedition One Rear Bumper with Dual Swing Outs • Baja Designs Rock Lights • Switch Pros SP 9100 • Victory 4x4 LED Light Bar • Front Baja Designs Driving Lights • Rear Baja Designs Flood Lights • Body Mount Chop (installed by Accessory Outfitters in Aloha, OR) • OME Rear LEAF Springs (soon Deaver Stage III w/ Archive Hammer Hanger) • Ride Rite Airbag System with Daystar airbag free floating cradle • Tailgate panel, Black Mountain Hatch • Tacoma Bed Stiffeners, Chaos Fab • Spindle Gusset, Chaos Fab • ICON 2.5 (58735c FR / 57805P RR) Suspension
    The best $80 you can spend!
    TK-422[QUOTED][OP] likes this.
  5. Oct 13, 2019 at 12:01 AM
    TK-422
    So Cal - SCV
    2015 4Runner TEP
    I finally got everything swapped out including new pads although I didn't really need them. Then I went to test drive it and I got what sounded like metal to metal squealing. I had inspected all the drums/rotors discs and shoes and could not determine exactly what it was. Today I threw a couple of gopros under the 4Runner and it's on the right rear. About a minute in it starts and 1.5 it really starts making noise.
    Now I'm convinced the rear rotor/drum is warped causing the osculating sound. I ordered a new set. I will find out Monday if I'm right.
    You can see recent wear on the bottom of the shoe. Hopefully that's it because I can't find any other wear.
  6. Oct 17, 2019 at 1:34 AM
    TK-422
    So Cal - SCV
    2015 4Runner TEP
    The osculating sound is gone with the new brake drum/discs but the caliper is sticking. I have a brand new one sitting in the garage because I was expecting it. I will swap it Friday then bleed the brakes. It was fun explaining to my wife about helping me with pump, hold and release.
    Pbird74 likes this.
  7. Feb 3, 2020 at 1:26 AM
    TK-422
    So Cal - SCV
    2015 4Runner TEP
    Time for a final update. This went on way too long but it is finally fixed.
    Luckily I have a paid work vehicle so the 4Runner is only for weekend use and we have a RAV4 so I did not have to fix it in any time frame.
    When I replaced the wheel studs I had the caliper sitting off to the side. At one point I had to press the brake to put the transmission in neutral.
    This caused the piston to pop out all the way. I placed it back in but it caused the caliper to drag from then on.
    I had already purchased a replacement full caliper but had not changed it out yet.
    The faulty caliper was dragging and causing a lot of noise. I finally changed it and bled the brakes.
    With a couple of test drives it made a worse noise than before that at first I thought was due to rust on the drum/disc. but it only got worse.
    After multiple times removing and re-installing everything I finally narrowed it down to the new brake caliper mount that was badly manufactured
    and was rubbing against the brake rotor. I installed the original caliper mount with the new caliper and it is now working as it should.
    #1 whenever a caliper is not on the rotor use a 5" clamp with a piece of steel to keep it from moving if you have to press the brake petal.
    #2 don't expect a new part to actually fit as expected.
    Driving my 4Runner tonight was great after all that bullshit.
  8. Feb 3, 2020 at 2:10 AM
    Kevin8se7en
    Kevin8se7en Well-Known Member
    2017 Inferno OR
    Good on you for pulling over right away.
