Spacers to Spindles/5100's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ARob34, Jul 30, 2016.
Spindle or coilover
  1. MaxTrac 4 inch spindles
    4 vote(s)
    50.0%
  2. 5100's all around and 885's
    4 vote(s)
    50.0%
  1. Jul 30, 2016 at 6:29 PM
    ARob34
    ARob34 [OP] New Member
    Adam
    2007 White Double Cab
    Hello Tacomaworld,
    I am currently running the rough country 3 inch lift kit on my double cab long bed. Spacers in the front and blocks in the rear. As you all may be able to guess, the ride is absolutely awful. I would like to upgrade my lift eventually (when my wallet allows me to) and I am trying to weigh my options. I would like to upgrade to 5100's all the way around along with 885's and AAL in the rear (seems to be a popular option). However, seeing as I am 2wd, I have recently been leaning toward a 4 inch MaxTrac spindle lift. My question is, If i were to go with the spindle lift, remove the spacers, and swap the block for an AAL, would there be any damage to the coils or struts after removing the spacers? Also, would the ride quality become noticeably better? And finally, with the spindles and stock struts/coils in the front, would i regret not going with the 5100's and 885's as far as ride quality is concerned? First post by the way so bear with me :D
  2. Jul 31, 2016 at 6:06 AM
    ClemsonMGM
    ClemsonMGM Even Firemen Need Heroes...
    Workin the pole!
    12 Ram 2500
    Do the spindles, then get 5100s and leave them at 0 for a nice ride.. With 4" in the front you may need more than just an add a leaf in the rear to level.
  3. Jul 31, 2016 at 10:27 AM
    ARob34
    Adam
    What options would I be looking at for the back then? Sticking with blocks?
  4. Jul 31, 2016 at 11:40 AM
    ClemsonMGM
    Workin the pole!
    12 Ram 2500
    The cheap way would be add a leaf plus blocks... The best way would be a new leaf pack. Either way your probly gonna need longer brake lines too.
  5. Jul 31, 2016 at 11:47 AM
    Tacoma Off Course
    Tacoma Off Course Well-Known Member
    Austin
    Houston, KS
    2005 DCSB Prerunner SR5
    Stuff
    You probably haven't seen this yet but this thread may be interesting to you.
    https://www.tacomaworld.com/threads/maxtrac-spindle-lift-for-2nd-gen-prerunners.203889/
    I am currently running the spindles with billies set at 0 and 885 coils so you can actually do both :rolleyes: lol
    But it is quite a bit of lift. I would recommend the spindles any day as they are great and if you go with billies at 0 it will be a nice ride. You can't really go wrong with either direction.
  6. Oct 3, 2016 at 1:09 PM
    ICrazyChrisI
    ICrazyChrisI Well-Known Member
    San Diego, CA
    2016 TRD Off Road DCSB
    Did your spindle lift push your front wheels out? I checked out your build page and didn't see that you added spacers in the rear to compensate for the front.
  7. Oct 9, 2016 at 11:00 AM
    Tacoma Off Course
    Austin
    Houston, KS
    Stuff
    It pushed them out probably about an inch or so (not too ridiculous). I didn't add wheel spacers in the rear and I never notice much of a difference.
