Spare tire fell from mount
Discussion in '1st Gen. Tacomas (1995-2004)' started by ugmold, Oct 6, 2012.
  1. Oct 6, 2012 at 9:13 AM
    ugmold
    ugmold [OP] Well-Known Member
    So I just went to Toyota to get a new gas cap in the hopes my engine light for samll leak would go away and my spare tire fell from it's mount. I'm lucky I noticed it in the rearview trying to catch up to me...bizarre, I thought someone wheeled a tire at me. Luckily I had just gotten off the highway, could have been a disaster.
    Quick look and nothing looks broken?
    Most likely that dangling thing is rusted beyond capability.
    Is there a better replacement?
    Thanks as always,
    -Ugmold
  2. Oct 6, 2012 at 9:17 AM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Damn! Yeah the cable looks like shit. I'd post a WTB ad. I'm sure there's plenty of people here that don't use theirs anymore. I would've sent mine to you if I hadn't given it away last week. :facepalm:
    Or just look for an aftermarket tire carrier.
  3. Oct 6, 2012 at 9:18 AM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
  4. Oct 6, 2012 at 9:19 AM
    Tacoma Mike
    Southern Maine
    You can just throw it in the bed... :) hehehehe
    I don't know of another that would fit in there besides stock.
    Shouldn't try to repair it.
  5. Oct 6, 2012 at 9:19 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    It's not really the cable as much as the piece that holds the rim completely rusted until it bent. That's crazy.
  6. Oct 6, 2012 at 9:20 AM
    ugmold
    Just took a close look, that holder is trash indeed, folded it with my fingers. How do you replace that?
    -Forrest
  7. Oct 6, 2012 at 9:21 AM
    scocar
    scocar hypotenoper
    Wow, it kinds looks like the whole plate that goes through the wheel hub has just rusted to oblivion. But like Jonathan says, post a WTB on the site and someone who relocated theirs for serious offroading may be able to sell (or give) you one cheap.
  8. Oct 6, 2012 at 9:22 AM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Cable "assembly"/winch/crane/whatever:D
    If you're looking for an OEM replacement, it's kind of a PITA because the bolts are on top of the crossmember so you'll probably have to remove the bed to get to it.
  9. Oct 6, 2012 at 9:25 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Wow man, that is an insane amount of rust. You live in New England or something?
  10. Oct 6, 2012 at 9:44 AM
    ugmold
    I live in Mass, and I also surf, so it is down at the Beach on Stormy Days.
    Looks awful to replace.
  11. Oct 6, 2012 at 9:55 AM
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    Looks like 4 bolts holding it there? I'd spray it down with some penetrating oil for a couple days if your thinking of replacing it. I bodyboard alot so my truck gets all the sand and salt blast from the wind cutting across the island here :( Though I'm a puss and only go during warm water hehe :D
    http://www.car-part.com/
    Spare Tire Carrier I think is what you need, looks like they run around $75 or so.
  12. Oct 6, 2012 at 10:12 AM
    ugmold
    I just sprayed it down with PB. The bolts on top are right against the bed, if they are not rotted, I nay be able to use them again.
  13. Oct 6, 2012 at 10:17 AM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    I would think you could cut that cable at the end where it's crimped and put a new plate up there and re-crimp the cable. I bet if you try to reel that cable down it will be pretty rusty inside too so some penetrating lube could help that.
  14. Oct 6, 2012 at 10:54 AM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Doesn't look easy. I'm wondering how the cable is attached at the other end... if it can be removed easily enough, maybe you could slip a new plate onto the cable? :notsure:
  15. Oct 6, 2012 at 10:55 AM
    ugmold
    So the Cable looks fine and everything is good except that piece.
    If I cut it off. I have a 2 Bars of aluminum, 3/8 thick 9 inches long. Cut the first to fit the hole to center the rim. the second to be longer goes underneath to hold the rim. Only problem is getting the cable to go thru....? If I could take that spring thing apart, I don't want to cut it off.
  16. Oct 6, 2012 at 11:30 AM
    pippen
    Pippen
    Eastern NC
    04 PreRunner Ext.
    If you had to, you could make a hole in the aluminum plate large enough for the end of the wire thingy to go through then make a notch on one side of the hole for the wire to fit in and put a short bolt through the large hole you drilled and fit it with some washers and locktite.
    Kinda shaped like this except make the rectangle notch smaller for the wire size. Not the most elaborate setup but it would work I think.
  17. Oct 6, 2012 at 12:34 PM
    ugmold
    I bit like what I am doing. top and bottom pc. Top will fit into the hole, after a bit more grinding. hole will be drilled in center for cable, then I will have to cut a notch to the hole.
    The bottom, hole for cable, another notch to the hole, but on the opposite side, bolt the two together......can I has cheeseburger now?
  18. Oct 6, 2012 at 1:04 PM
    pippen
    Pippen
    Eastern NC
    04 PreRunner Ext.
    Ah yes that will work good too! +rep for being the first to acknowledge cheezburger cat, you may can have cheezburger now :D
  19. Oct 6, 2012 at 6:56 PM
    ugmold
    I want to send Toyota a picture of the damaged piece, anybody have a contact email?
  20. Oct 6, 2012 at 7:01 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    Toyota did a recall for that issue on both generations of Siennas (in salt using states). We didn't have either of ours done though. Heh. Perhaps they will need to do one for Tacomas too!
