Spare tire fell from mount
Discussion in '1st Gen. Tacomas (1995-2004)' started by ugmold, Oct 6, 2012.
  1. Oct 6, 2012 at 7:09 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I was driving along (in a non-Toyota at the time) and a nice lady pulled up next to me pointing behind me and said "Excuse me, your spare tire fell off at the light back there" [​IMG]
  2. Oct 7, 2012 at 4:53 AM
    ugmold
    ugmold [OP] Well-Known Member
    There was a recall for the Tacoma to do a undercoating. They did a terrible job, the stuff either falls off or stays wet, so any work you do under there gets you very dirty.
    My friend had an 06, I think, and the frame rotted bad, he had 250k on it and Toyota gave him an incredible trade in for a new one, which he accepted, wish that could happen to me. I don't see to many 03, or smaller Tacoma's around here in Ma anymore.
  3. Oct 7, 2012 at 7:54 AM
    Streetsurfz727
    Streetsurfz727 Well-Known Member
    don't use mine ill sell it to ya for the cheap cheap like a bird.....that is if its not to hard to remove
  4. Oct 7, 2012 at 8:55 AM
    ak47dennis
    ak47dennis Well-Known Member
    dennis
    Pa
    TRD
    I would just replace the whole assembly. I know on CL they show up pretty regular for Chevy and Ford trucks. Be thankful know one was hurt a few months ago in my area a lad was killed when a tire came out of the back of a Chevy pu and went thru here window!!
    I have seen these fail a couple times of the years, on the ones I have seen the cable snaps.
  5. Oct 9, 2012 at 5:32 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    There is a spare mount and whatnot for sale here
  6. Oct 9, 2012 at 5:37 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Looks like it had the same fate haha, I wouldn't trust that setup, IMO!
  7. Oct 10, 2012 at 6:32 AM
    ugmold
    Himmie, for the spare tire carrier?
  8. Oct 11, 2012 at 5:43 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    I'm not certain what your question means. :confused:
    Toyota had a recall for the 1st and 2nd generation Sienna for the spare tire cable. In salt-using states. There were issues with rust and tires falling from the vehicle. It just involved them replacing the assembly, I believe.
  9. Oct 12, 2012 at 6:27 AM
    ugmold
    Yes, that is what I meant, thanks. I sent a note off to Toyota and hope to hear something back. I'll keep you posted.
  10. Oct 12, 2012 at 7:54 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    I have one of those OEM spare tire cranks from my Land Cruiser that I'm not using if you want it. I don't know if the bolt pattern is exactly the same but it should work. It has a chain instead of the cable. It's the entire assembly.
  11. Oct 13, 2012 at 6:14 AM
    ugmold
    Thanks for the offer Box Rocket. I'm going to see what Toyota has to say before I do anything.
    -Ug
  12. Oct 13, 2012 at 2:26 PM
    ugmold
    I tried to get the spare tire carrier off today, fa-getta-bout-it. So tried my idea. Check the picks. Is the mounted right, short side up?
    Also tried to find the gas leak/engine light code again...nothing.
    [​IMG][​IMG]
  13. Oct 13, 2012 at 2:33 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Not bad, at the very least I'd use some red loctite and maybe some slightly longer bolts.
  14. Oct 13, 2012 at 6:00 PM
    ugmold
    Do I have the tire facing the right way? I've never had it down in 120,000 miles, until it fell down. I went by the scuff marks when it first hit the ground.
  15. Oct 13, 2012 at 6:10 PM
    #35
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I don't think it matters which way you put it up there. If it doesn't rattle around you're good.
  16. Oct 14, 2012 at 12:13 PM
    #36
    ugmold
    Took your advice 45acp. Longer bolts, Lock washers, loctite and I filled the notches with some liquid metal.
  17. Oct 25, 2012 at 9:38 AM
    #37
    ugmold
    Update. Dropped it off at Boch Toyota, mainly for the engine code/gas smell, leak. They are going to cover the carrier, but they can't find the gas leak. They want $2,400 to drop the tank and replace. Good thing I don't have the money...lol.
  18. Oct 25, 2012 at 9:45 AM
    #38
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    What code are you reading for the 'gas leak' ?
  19. Oct 25, 2012 at 9:58 AM
    #39
    ugmold
    PO456, tried a new OEM Gas Cap. Can't find anything wet or broken, there Dealership put smoke in the system and found nothing.
    My guess is rust around the gaskets for the fuel pump and all that other emissions stuff.
  20. Oct 27, 2012 at 3:23 PM
    #40
    ugmold
    The local dealer ended up covering the carrier, although it is a slightly different looking unit. I also dropped the truck off in the early am, and after work they hadn't touched the truck, so I waited around for 2 1/2 hours.
    I was thumbs down on the gas tank replacement. Going to try to find a new one.
