Spare tire fuel tank?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MJTH, Sep 14, 2021.
  1. Sep 14, 2021 at 5:31 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
  2. Sep 14, 2021 at 5:37 PM
    C-Rok275
    C-Rok275 Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
    Damn reading comprehension
    stevesnj[QUOTED] likes this.
  3. Sep 14, 2021 at 5:41 PM
    MJTH
    MJTH [OP] PretenderLander
    Joe
    Colorado-Westslopebestslope
    19 OR- Land Yacht, w/ fireplace
    I think tank is also fine. (I may not understand the distinction between cell and tank)
  4. Sep 14, 2021 at 5:44 PM
    MJTH
    Joe
    Travlr likes this.
  5. Sep 14, 2021 at 5:44 PM
    stevesnj
    A cell is usually plastic, with foam cell inserts used for racing typically, a tank is just that.
    MJTH[QUOTED][OP] likes this.
  6. Sep 14, 2021 at 5:50 PM
    MJTH
    Joe
    1000 mile range sounds wonderful.
    justrussell and stevesnj[QUOTED] like this.
  7. Sep 14, 2021 at 5:51 PM
    stevesnj
    Well for a Landcruiser it's just 650 miles. lol
    Malvolio and skeletron like this.
  8. Sep 14, 2021 at 6:01 PM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    No hard. Just put a check valve between your pump and the the hole you tap into the filler neck. No evap leak.
    RushT and MJTH[QUOTED][OP] like this.
  9. Sep 14, 2021 at 6:32 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Couldn’t you just fill your spare tire with gas?
    toucan, DingleTower, Malvolio and 9 others like this.
  10. Sep 14, 2021 at 7:05 PM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
  11. Sep 14, 2021 at 7:35 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    No idea how to help you but I like the idea. A spare tire sized tank full of gas (ten gallons?) should weigh, what, 75 pounds? The fuel 63 pounds and the tank would be light. An electric pump to push the fuel into the existing tank and a fill hose. Nice idea. To bad you can't use the space between the inner and outer bed.
  12. Sep 15, 2021 at 4:12 AM
    MJTH
    Joe
    Now this is the hard hitting, no nonsense advice I was looking for
    tcjacado, skeletron, Malvolio and 6 others like this.
  13. Sep 15, 2021 at 6:08 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    MJTH[OP] likes this.
  14. Sep 15, 2021 at 7:07 AM
    Stocklocker
    17TRDORDCSBAT
    :hattip:
    tcjacado likes this.
  15. Sep 15, 2021 at 7:21 AM
    #35
    TacooSaucee
    TacooSaucee Well-Known Member
    2020 Off-Road DCSB
    Cracked Windshield
  16. Sep 16, 2021 at 7:13 AM
    #36
    dpele
    dpele Pele Prints Vendor
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    Elka 2.0 w/ OME Dakars, 285/70/R17 Duratracs, & more!
    Are you interested in "don't drive it"? lol
  17. Sep 16, 2021 at 10:48 AM
    #37
    Dawelda
    Dawelda Well-Known Member
    West of West Phoenix
    20 Tacoma DCLB TRDOR Desert Sand
    2.5" lift w/33" tires, 10K Winch & bumper, camper shell
    :pccoffee:back in the day...
    I had an '83 Chevy truck and later, I had a '74 Bronco and both had auxiliary tanks and each worked the same way. When the gauge read "empty" I would poke a button and turn a valve under the seat. Then, the same OEM fuel gauge would read full and I would go about my business. It was awesome!
    I've wanted one for this truck since the first time I saw how limited my range was. I would love to get this done and might even work with someone to put a "kit" together for owners or even a parts list and instructions for others? I just need to get out of the temporary apartment and into a house so I can get my shop set back up. It will be next spring! :frusty: Make some plans in the mean time? :notsure:
    I'm a certified TIG welder and machinist and can make almost anything I can't buy/afford. I can fab the tanks, mounts, and parts, etc. But, I don't know shit about cars in general. I'd have done it already but don't know how to make it work seamlessly?
    1. How do you fill it? Both previous trucks had separate fillers. Is this the best option? Where do you put it that doesn't fuck up the body?
    2. If you purchase a sensor, how do you connect to OEM gauge?
    3. In tank pump? External? Power for that? Regulated pressure?
    4. How to you plumb the new source into existing fuel line/system? On/off valve? Switching?
    5. Isn't the vent part of emissions, too?
    So many questions for someone ignorant in the technical specifics of how cars actually work. Both previous trucks had the aux tanks on the side, main in the rear. I haven't seen the under side of my truck in some time, can we place it to help with the balance issue? Central or right side? Or, can it only go in place of spare?
    I know someone here is knowledgeable enough to integrate this without fucking up the OEM systems. If all you need is fab help, talk to me if you like. Post here or message me? Seriously, I hate the short range shit, let's fix it!:curls:
  18. Sep 16, 2021 at 11:00 AM
    #38
    Seth2197
    Seth2197 Well-Known Member
    2020 Tacoma TRD Off-Road Premium DCSB
    I'm no expert but I do have some thoughts on getting this working.
    1. I think putting the extra filler in the bed could be a good solution. Inside of one of the little storage cubbies could be a good place to keep it hidden away.
    2/3: They sell the whole fuel pump assembly (77020-04090). It has the fuel pump and gauge already. Maybe relays could be used to turn one assembly off and turn the other on. I just can't think of a good way to do it. I wish there were relays that went from circuit 1 to 2 instead of being either off or on.
    I think making it legal would be the hardest part. I don't know a ton about the law but I've heard it's really tough on auxiliary fuel tanks
  19. Sep 16, 2021 at 11:03 AM
    #39
    Dawelda
    Filler in bed is likely a good idea as long as static charge while filling isn't an issue?
    Integration into the OEM system is a BIG issue.
    Didn't realize there was a legal component? Not sure that I care much.
  20. Sep 16, 2021 at 11:05 AM
    #40
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I think the easiest method would be to find a tank that will fit in there. It should allow you to add a fuel pump and gauge for the spare tank easily. Run a switch to the pump and have it drain into your main tank. A one way valve at the stock tank should hopefully keep evap codes from popping up. You can plumb into the stock tank like this guy did.
    Fairly low risk. If you mess up worst case you need to buy a new fuel pump assembly and not a new stock tank.
    https://www.tacomaworld.com/threads...-for-accessories-utility-motors.718947/page-4
    Found some 2nd gen threads too:
    https://www.tacomaworld.com/threads...spare-tire-area-parts-and-build-ideas.483271/
    https://www.tacomaworld.com/threads/auxiliary-17-gallon-fuel-tank-idea.477475/
