Spare Tire Mount???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kuneff, Dec 5, 2009.
  1. Dec 5, 2009 at 4:18 PM
    Kuneff
    Kuneff [OP] Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    When you crank the spare tire back up under the truck does it just tighten up against the frame cross member? Or is there something mounted to the frame crossmember that the tire tightens against???
  2. Dec 5, 2009 at 4:44 PM
    RustyYota
    RustyYota Active Member
    Dave
    Rust Belt, NY
    TRD Auto
    Toolbox in the summer tenau in the winter, 3in toytec lift, 33'' BFG muds, Tint
    There is a sort of bent peice of sheet metal that fits the contour of the inside of the rim if i remember right. I havnt had my spare out since July so dont quote me on that
  3. Dec 5, 2009 at 5:15 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yep, that little mis-configured piece of sheet metal just kinda keeps the spare from moving side to side once you crank that cable pulley up tight..:cool:
  4. Dec 5, 2009 at 5:36 PM
    Kuneff
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    OK, So I guess I don't really need it... Right?
    :D
  5. Dec 5, 2009 at 8:27 PM
    RustyYota
    Dave
    Rust Belt, NY
    TRD Auto
    I guess if its not flopping around while your driving and the tire itself isnt rubbing on the cross member you should be all good. if you wanted to get fancy you could cut a couple of wood 4x4s (or bigger) into little blocks and drop them in the rim before you crank it up to make a spacer, maybe even notch them to fit the cross member this may not work but who knows
