Spare tire safety chain?
Discussion in '4th Gen. Tacomas (2024+)' started by Taco001, Jan 30, 2025.
  1. Jan 30, 2025 at 5:35 PM
    Taco001
    Taco001 [OP] Well-Known Member
    24 OR
    Hello all,
    I recently replaced OEM tires and replaced the little eco spare that comes on the OR model. Now im worried that little 2mm thick chain may give out at some point since now ive modified this and with additional weight of the OEM full size tire.
    Am I justified for being worried about my spare coming loose at 70mph?
    Has the capacity and performance of that little chain been used for sometime without issue? What happens when we add 20lbs more weight on the spare, will it still hold?
  2. Jan 30, 2025 at 5:39 PM
    Bishop84
    Bishop84 Well-Known Member
    It's not a bad worry but at the same time you don't want to have to deal with a secondary chain on the side of the road at 2 am.
    I'm sure its ok and if you're worried, check it once a season for fatigue by dropping the tire.
    shakerhood likes this.
  3. Jan 30, 2025 at 5:40 PM
    Clearwater Bill
    Billy
    Largo Florida
    You're about 3.5 hrs early for a great Friday thread.
  4. Jan 30, 2025 at 5:55 PM
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    I’d imagine you are fine. My SR5 has a full size spare.
  5. Jan 30, 2025 at 9:29 PM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    yup, so does my sport...
    something I will never use...
    im sure its the same chain....
  6. Jan 31, 2025 at 3:40 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Is the chain smaller than the 3rd gen ? If it was me I would add a metal cable of some kind as an extra safety feature. Loop it through the rim and secure it to something under the truck that won’t give out . With a lock at the end .
  7. Jan 31, 2025 at 4:41 AM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    It’s only holding 70lbs. Doesn’t take much chain to do that
  8. Jan 31, 2025 at 5:23 AM
    HoosierBuddy
    HoosierBuddy Well-Known Member
    Phil
    2012 Base Regular Cab 4WD Manual
    2" Lift
    Uhh...not so fast. A wheel hub can (reportedly) experience a 50g load when you hit a pot hole. The spare wheel won't see anything like that, but it will be more than 1.0.
  9. Jan 31, 2025 at 5:46 AM
    Taco001
    24 OR
    Yes the g forces from dips, bumps and holes can increase the amount of load by several times. Im going to install a safety chain or cable this weekend and report back with photos in case anyone wishes to see what i did. Im surprised they didnt supply that little winch with braided cable.
  10. Jan 31, 2025 at 7:38 AM
    FunknNasty
    FunknNasty Well-Known Member
    San Jose
    2022 Pro
  11. Jan 31, 2025 at 7:50 AM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
  12. Jan 31, 2025 at 7:55 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
  13. Jan 31, 2025 at 12:04 PM
    OpeCity
    Long Beach, CA
    That’s the unsprung wheel. You never get even close to double digit Gs in the body of a truck even on the roughest road you can imagine. So call it 3 Gs when you absolutely crunch the truck.
    doesn’t take much chain to hold 210lbs
    JoeMongo likes this.
  14. Feb 4, 2025 at 6:33 PM
    DailyTacoMD
    DailyTacoMD Well-Known Member
    Jeremiah
    2006 2.7L AC 4x4 5spd
    Couldn’t you just go to depot/Lowe’s and buy a length of similarly sized chain with a rated break strength that exceeds your estimated needs and cut to length to replace the oem chain? Though I doubt it’d be an issue because as someone else pointed out, it’s possible to have a full size spare or remount the oem wheel + full size spare. I doubt Toyota has a different part# for the tire mount attachment for trucks with a full size spare…
