spark knock and ignition issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by davestaco, Dec 1, 2010.
  1. Dec 1, 2010 at 1:21 PM
    davestaco
    davestaco [OP] TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    hello TW.....i am having some problems with my taco:mad:......when i purchased it, it was in-need of a new MAF sensor, and also had a lot of spark knock. and i do mean a lot. so i buy the new MAF and install it and instantly the truck runs much better, but i just noticed today that i still have some spark knock at lower rpms, and it is still taking my truck a good while of cranking to start up. What can i do to get rid of this aprk knock, and get quicker start times?
  2. Dec 1, 2010 at 2:08 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
  3. Dec 1, 2010 at 6:30 PM
    davestaco
    David
    Schofield Barracks
    haha thanks for the limk....i do need a new o2 sensor and a cat. maybe thats doin it. I just want this thing to accually run smooth for a change!!!!!
  4. Dec 1, 2010 at 6:51 PM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    new spark plugs and if that doesn't work try plug wires or you may have a bad coil back, is the cel on?
  5. Dec 1, 2010 at 7:08 PM
    davestaco
    David
    Schofield Barracks
    just put new plugs in no more than a month ago, yes the cel is on but i think i remember him sayin it was the o2 censor or a bad cat.....he said we nee to cut out the 2 cats and put in one longer one. This truck really dosnt run as smooth as i thought it would.....I mean for god sakes my jeep ran and idled, and even started faster and easier than the taco!!!
  6. Dec 1, 2010 at 7:13 PM
    tacomaforlife
    Robbie
    AIKEN, SC
    it takes more than an o2 sensor to do that because mines messed up and i have no cats but i do have a urd sim. but that should not cause it to run bad i would check plug wires or have the cel looked at again to double check.
  7. Dec 1, 2010 at 8:19 PM
    davestaco
    David
    Schofield Barracks
    i dont think my cel has anything to do with my spark knock or start up issues. as you said earlier its probably somewhere in th wires ir something......im thinking about looking into msd ignition and redoing the whole ignition system.
  8. Dec 1, 2010 at 8:28 PM
    davestaco
    David
    Schofield Barracks
    well looks like msd dosent carry anything for toyota......any ideas where i can by performance or high quality ignition parts for my tacoma?.....
  9. Dec 1, 2010 at 9:00 PM
    Mr.Fahrenheit
    Mr.Fahrenheit Dennis = sinneD
    American Canyon, California
    01 Taco 3.4L 5spd TRD
    K&N CAI, HUSKY LINERS, LOW PRO TOOL BOX, GRAY WIRE MOD, OPTIMA RED TOP, GOODRIDGE STEEL BRAKE LINES, FAB TECH LIFT,
    e3 spark plugs.....never tried them but i wanna buy some
  10. Dec 1, 2010 at 10:53 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    So what start up issues are you exactly having? Is the truck struggeling or anything? Or simply just takeing to long? :confused:
  11. Dec 2, 2010 at 7:50 AM
    davestaco
    David
    Schofield Barracks
    i have heard a lot of bad things about them plugs......i do hear there ok in smaller engines tho
  12. Dec 2, 2010 at 7:51 AM
    davestaco
    David
    Schofield Barracks
    long cranktimes, slight spark knock, rough idle......thats the main ones.....im seafoaming next oil change so maybe that will help, but it probably wont haha.
  13. Dec 2, 2010 at 10:43 AM
    thombiz
    thombiz Active Member
    Corpus Christi
    01 Prerunner & '02 Tundra
    Take it to the dealer and ask them to reset the timing. Had something similar with our SC-300 Lexus. The timing was too advanced. When they reset it, the problem went away. If I remember correctly, ours was supposed to be set at 13 degrees before top dead center and it was set at about 21 degrees.
  14. Dec 2, 2010 at 4:43 PM
    davestaco
    David
    Schofield Barracks
    i never thought of that......thanks.....but i aint takin it to the dealer
  15. Dec 4, 2010 at 6:14 PM
    davestaco
    David
    Schofield Barracks
    any one know where i can get new ignition parts?
  16. Dec 4, 2010 at 9:48 PM
    thombiz
    Corpus Christi
    Curious, why do you need new ignition parts?
    The procedure for timing a 2.4 can be found here:
    http://www.yotatech.com/f2/tacoma-ignition-timing-29107/
    I saw somewhere else a very similar procedure for the 3.4 V6 so the 2.7 should be identical. Trust me, check and set the ignition timing.
    I have been researching this some more. My problem is my 2001 2.7 Tacoma is located in Atlanta and I'm in Texas so I can't just go out and look at what I have. It seems , at some point in the Tacoma line, Toyota switched from distributors to a crank firing sensor and coil packs on the 3.4 V6. Not sure about the 2.7. I can't seem to find any info for adjusting the crank firing sensor and coil packs if that is what you have. I appreciate your frustration, so I'm trying to find you some reliable information.
  17. Dec 5, 2010 at 8:32 AM
    thombiz
    Corpus Christi
  18. Dec 5, 2010 at 11:47 AM
    davestaco
    David
    Schofield Barracks
    thanks for the help....i talked to my mechanic and he said he dosnt think it could be the timing, but im still gonna check it out.......i was looking for new parts cause i would like to beef up this truck a bit...i was looking ind the msd-6 off road ignition
