Spark plug came out but not the threads
Discussion in '1st Gen. Tacomas (1995-2004)' started by 930dreamer, Jan 18, 2016.
  1. Jan 18, 2016 at 9:52 AM
    930dreamer
    930dreamer [OP] Well-Known Member
    04 Tacoma Prerunner
    I was changing the plugs on my 04 Prerunner but couldn't get the #2 plug out. I broke a 3/8" extension in the process. Picked up a strong magnet from HF and got the socket out. Soaked the hole with PB blast over night and tried again with a 1/2" drive socket. Yup plug came out but not the threaded portion. :(
  2. Jan 18, 2016 at 9:53 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I feel your pain bra
  3. Jan 18, 2016 at 9:53 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Have you tried an easy out?
    scottalot likes this.
  4. Jan 18, 2016 at 9:54 AM
    930dreamer
    04 Tacoma Prerunner
    I'm headed to Toyota for a new truck.
  5. Jan 18, 2016 at 9:55 AM
    Boone
    Boone, NC
    Airbags deployed
    That's one way to take care of the problem.
    Jessrin, 1R0NMAN811 and scottalot like this.
  6. Jan 18, 2016 at 9:58 AM
    930dreamer
    04 Tacoma Prerunner
    Jk, wow this sucks but the shop is warm, I'm guessing I need to remove the valve cover for starters?
    mayor08, alphabravo and scottalot like this.
  7. Jan 18, 2016 at 10:03 AM
    Andres
    Andres Well-Known Member Vendor
    Andres
    Hawthorne, CA
    2013 Toyota Tacoma TRD off-road
    Fenwick1993, cosmicfires and robssol like this.
  8. Jan 18, 2016 at 10:04 AM
    Andres
    Andres
    Hawthorne, CA
    Oh and don't forget to use anti-size lubricant next time you install those spark plugs.
    ThunderOne and Krazie Sj like this.
  9. Jan 18, 2016 at 10:08 AM
    MKMotorsport
    MKMotorsport Well-Known Member
    AZ
    '15 DCSB TRD/OR
    All-Pro skid'd, UGMx1.3, 7pin delete via rock
    Interesting to see an NGK failed like that. Thought only Champions did that....
    robssol likes this.
  10. Jan 18, 2016 at 10:12 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Corrected you...
  11. Jan 18, 2016 at 10:17 AM
    MKMotorsport
    AZ
    '15 DCSB TRD/OR
    LOL, mah bad. Either though (Denso and NGK make good plugs..). Unexpected. How many miles on that plug?
  12. Jan 18, 2016 at 10:23 AM
    930dreamer
    04 Tacoma Prerunner
    Not sure as I bought the truck in Oct2015, do I need to remove the valve cover?
  13. Jan 18, 2016 at 10:58 AM
    RustyVT
    RustyVT Well-Known Member
    Vermont
    98 4Runner limited, 12 S60 T6
    OME overload springs, airlift bags, Hayden 679, 33x12.5 X-ATs
    Removing the valve cover wouldn't get you very far I don't think, as the tube the plug sits in will still be there. Doesn't really free up any more space, you could try and remove the tube as well, But I think there's a special tool for that.
  14. Jan 18, 2016 at 11:11 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Best bet before tearing half of your engine apart:thumbsup:
    Just curious. How many miles on the plugs?
  15. Jan 18, 2016 at 11:12 AM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    Be carefull you don't break the extractor off in there. I've had good luck using an impact gun with one of the square extractors just don't use a real high setting. The vibration combined with the penetrant might just get it out.
  16. Jan 18, 2016 at 11:13 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    Holy shit, have not seen that in awhile. Send the pics to "Denso" & see what they say or try something similar to this:
    RedRed likes this.
  17. Jan 18, 2016 at 11:15 AM
    Andres
    Andres
    Hawthorne, CA
    Op should try removing it by hand first using ball peen hammer, extraction tool and liquid wrench.
    Liquid wrench should be used and let it sit for about 30 min. before trying to extract the threaded piece.
  18. Jan 18, 2016 at 11:15 AM
    Andres
    Andres
    Hawthorne, CA
    Exactly my recommendation!
  19. Jan 18, 2016 at 11:17 AM
    Texasbrons
    Texasbrons Well-Known Member
    Pleasant Hill, MO
    2016 Tacoma Off Road TRD Quicksand
    Changed my DisplayOff image ---Twice!!
    ^^^^this^^^^ Pid of bolt/pipe extraction kit
    I had the threads come off of mine once and that got it out just fine.
  20. Jan 18, 2016 at 11:17 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    If you do go with one of those EZ Out / Speed-Out tools, be sure to wipe a good magnet down the length of the tool a few times, until it'll hold up a small nail, before you start working it into what's left of the plug. That way any shavings will cling to the tool rather than dropping down into the cylinder.
    $.02
    Good luck.
    cliffyk, Dalandser, File IFR and 3 others like this.
