Spark Plug Change
Discussion in '5 Lug' started by CaliforniaTaco, Mar 10, 2011.
  1. Mar 10, 2011 at 1:16 PM
    CaliforniaTaco
    CaliforniaTaco [OP] Well-Known Member
  2. Apr 26, 2011 at 8:37 AM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
  3. Apr 26, 2011 at 8:43 AM
    medic2230
    Murph
    Bama! Roll Tide
    Which engine? 3RZ? Or did they redesign the 2.7?
  4. Apr 26, 2011 at 6:09 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    There's a sticky for the 3rz in the 1st gen forum... I'm assuming the 2rz is about identical as well.
  5. Apr 26, 2011 at 6:37 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    It's pretty easy to change them on the 2tr-fe. Service manual calls for Denso SK20HR11 or NGK ILFR6C11. I used Denso's from the local dealer or rockauto.com, can't remember which.
    Disconnect battery.
    Remove the air intake tubing that goes between the throttle body and filter box.
    Unplug the coil pack closest to the front of the engine.
    Unscrew the retaining screw for the coil pack.
    Gently remove the coil pack.
    Use spark plug socket and ratchet extension to remove plug.
    Check gap on new plug. Service manual specs 0.039 to 0.043 in.
    Lightly coat the threads of the spark plug with anti-seize compound.
    Carefully install new plug. Be careful not to cross or strip the threads!
    Torque to 13 ft*lbs.
    Reinstall coil pack.
    Repeat for the other three plugs. Then reinstall the air intake.
  6. Jun 8, 2014 at 6:19 AM
    frastc
    frastc New Member
    Bill
    New Hampshire
    06 Tacoma
    Leer Cap, receiver hitch lots of window decals
    Ditto for 206 4cyl
  7. Jul 4, 2014 at 5:42 PM
    jackbower6864
    jackbower6864 Member
  8. Aug 23, 2014 at 4:12 AM
    SQU1D
    SQU1D Member
    NoVA
    06 2.7 Liter
    Just did it on my 2006 2.7
    It was much less complicated than I expected. I've never swapped spark plugs on anything other than my lawn mower until then and it still only took me about an hour and a half. I used the Haynes service manual as a reference as well as the V6 thread.
    That got me a sense of probably undeserved confidence which led me to swap the plugs on my wife's Nissan Murano. Boy was that different from my truck. That job took me about 6 hours.... no kidding.
  9. Aug 23, 2014 at 4:20 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
  10. Nov 7, 2014 at 5:34 PM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    :thumbsup:
    Doing a little research tonight Rob. I need brakes and rotors up front plus the rear wheel bearing, drivers side, needs to be replaced. At 73K on the clock this is my first real maintenance except for fluids.
