Spark plug change
Discussion in 'Performance and Tuning' started by LQQKatmy06, Mar 29, 2008.
  1. Mar 29, 2008 at 10:40 AM
    LQQKatmy06
    LQQKatmy06 [OP] Carolina Alliance
    T-VILLE, NC
    06 SR5 V6 DC LB TRD Sport 4x4 AUTO. 3" TOYTEC 885 coils w/AALs, ALL-PRO UCAs, 285/70/17 NITTOs, KMC HOSS in BLACK
    Just did the 30,000 plug change, the drivers side is a *itch took twice as long as the pass side. I had the NGK on drivers and Denso on pass side, the guy at the Toyota parts counter thought I was crazy and never heard of them being different from side to side. Went back with the Denso on both sides.
  2. Mar 29, 2008 at 11:45 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i'll be changing mine, just in time for the meet, in 300 miles. did you go back with the standard copper plugs?? how worn down were the stock plugs when you pulled them out??
    i had been thinking of going to the iridium plugs.....but i dont mind changing the plugs every 30k.....so i think im gonna stick with the coppers.
  3. Mar 29, 2008 at 12:23 PM
    LQQKatmy06
    T-VILLE, NC
    Went back with the copper, could of ran the plugs for another 30,000 but I always used 93 up until gas went crazy here.
    Higher octane burns colder so its not as hard on plugs. After you change your plugs you might wish you went with the iridium, Im already not looking forward to the next change.
    I had to connect 2 6" extensions together to reach plugs and get above plastic cover on top of the motor to turn my ratchet with no obstructions.
  4. Oct 22, 2008 at 6:23 AM
    spaghettiedy
    spaghettiedy Well-Known Member
    Pittsburgh
    09 DC LB Sport in Black 4x4
    Gray Weathertechs, LG Wet Okoles, Tacome OEM Bedmat
    Tacomaman - Were your plugs different on both sides as well? I read this on another post as well.
  5. Oct 22, 2008 at 6:37 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah, they were. ngk on one side/denso on the other. its they way they are installed at the factory........when they come down the line, one guy has ngk/one guy has denso. its kinda weird.......it was even like that in the 06 i got a couple of months ago. i went with standard denso copper plugs on the 06 i had and on the 04 i have now. easy change.
  6. Oct 22, 2008 at 10:30 AM
    Ahaszard
    Ahaszard Active Member
    St Augustine, FL
    08 Black TRD Off Road Rugged Trail
    My 07 FJ Cruiser had the same. Denso on passenger side and NKG on driver. I have not check the Tacoma yet.
  7. Oct 25, 2008 at 1:39 PM
    TS22
    TS22 Member
    South Florida
    2019 Tacoma DC 4x4
    My 06 Tacoma was this way also...I replaced them all with NGK. The guy who did them for me said he had never seen anything like that before.
  8. Nov 3, 2008 at 6:35 AM
    isusww
    isusww Well-Known Member
    I'm going to change mine this week. I'm going to use the NGK Iridium's all around. Anyone know of a good place to purchase them from? The website doesn't show a part # recommended for an '05 V6. I've found that the Iridium IX have a part # of 6619.
  9. Nov 4, 2008 at 11:10 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    I did the NGK irridiums a month ago. I bought them from Advanced auto parts. Paid (I think) $63 that included tax. The NGK platinum & irridium were the same price. I looked online at different places, they were more expensive than Advanced. Plus online you would have to pay for shipping.
  10. Nov 30, 2008 at 8:46 PM
    Rojo
    Rojo Active Member
    Texas
    12 TRD OffRoad 4x4 DCSB - Super White
    K&N, 2.5 lift/leveled, TRD FJ Wheels, 285/75R16
    I'm about to do the plugs on my 02 as well and have been looking at the NGK Laser Platinums and the NGK Iridiums. I've noticed that the LPs have the twin ground that is required and the Iridums just have a single. Does this really matter? Are there some twin ground Iridiums out there?
  11. Dec 1, 2008 at 4:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Use the OEM twin ground copper plugs for best results.
  12. Dec 16, 2008 at 8:42 AM
    Bearskill
    Bearskill Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    Hey. Im about to change my plugs, I don't think my plugs came pre gapped. Just to make sure, whats the gap for an 06 prerunner, 4L V6?
  13. Dec 16, 2008 at 9:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    .039 to .043
  14. Dec 18, 2008 at 9:29 AM
    Bearskill
    Sac
    Anyone use the Autoligh iridium XPs? They were the best ones Kragen had. But now everyone I ask wonders why I didn't go NGK or Denso. Does the brand really make that big-o-diff? Are the Autolights a crappy brand? Should I take them back and get diffrent ones or put them in and see how it runs. Don't want to blow $50 bucks if I don't have to.
  15. Dec 18, 2008 at 9:31 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the denso's and ngk's just run better in the tacomas. you can run those autolite's and see how they do, but i'd stick with denso or ngk......just my .02.:)
  16. Dec 21, 2008 at 5:47 PM
    busatodd
    busatodd BUSATODD
    whiteland
    2016 limited mgm
    3rd gen 5100 bilstiens set at 0 with ome 888s, LR UCA, 5160 bilstiens in back with icon 3 leaf aal with 1" block. Fuel savage wheel wrapped in nitto ridge grapplers 285/70/17
    is it nessesary to replace the plugs at 30,000? i have an 05 with 34,000. is 30k what the book suggest?
  17. Dec 21, 2008 at 5:49 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah.....its recommended to change the plugs at 30k on the v6, and 100k for the 4cyl's(they come with iridiums from the factory).
  18. Dec 21, 2008 at 5:52 PM
    busatodd
    busatodd BUSATODD
    whiteland
    2016 limited mgm
    would you put the iridiums back in it? without haveing to look it up, do you know what i need to set the gap is?
  19. Dec 21, 2008 at 5:54 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    on both my tacomas.......i just went back with regular copper core denso's.....alot cheaper than iridiums, but then again, i dont mind replacing them every 30k. and gap should be right around .039 to .043. i set all mine right around .040, and i havent had any problems with them.
  20. Dec 22, 2008 at 8:44 AM
    Bearskill
    Sac
    I have yet to go to the dealer, but I have hit up two Kragens, an Auto Zone, and a Napa. Nobody has Denso in stock or can even order them.....? I guess I will try to get them off line cause I don't want to go to my dealer. They suck.:mad:
