Spark Plug changeout after 30K How do they look?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Adreenaleen, Nov 12, 2011.
  1. Dec 10, 2011 at 3:49 PM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Has anyone ever indexed their spark plugs using the index washers?
    If so, can you share the best electrode position for these engines?
    PK
  2. Dec 10, 2011 at 4:23 PM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    295/70/17 Cooper STT Pro, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    45k on my truck, bought it with 1 mile on it. Honestly haven't even thought about changing plugs, maybe at 50k. I heard the same thing about these new engines, plugs don't have to be changed as frequently as older engines. I pulled them during the summer and they still looked brand new.
  3. Dec 10, 2011 at 4:37 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    If you buy OEM replacement plugs from the dealer all 6 are gonna be Denso.
  4. Dec 11, 2011 at 12:44 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    x2...
    changing out my plugs did not make a difference in gas mileage. and based on the condition of the plugs that i replaced it wasn't necessary. but, i had already bought the plugs so i went ahead and did so anyways. i think it was close to 35k when i swapped mine out.
  5. Dec 11, 2011 at 5:22 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    That 30K miles change for spark plug seems unnecessary based on all these nice looking plugs I keep seeing. I'll change mine at 60K.
  6. Dec 12, 2011 at 9:59 AM
    Nacho Muchacho
    Nacho Muchacho Member
    Southern New Mexico
    10 TRD Off Road 4x4
    Toytec OME lift 885 coils and TSB add a leaf. Light Racing upper control arms. CBI Sliders w/ kickouts. 265 75 16 Duratracs. Toyota bed mat and weathertech digifits
    60k spark plug interval may be acceptable for densos. But all 3 of my ngks were out of tolerance (wore quicker) at 30k. It was less than 10 bucks for the plugs at the dealer. If you're getting 1 less mpg for 30 k miles, that's more than $200 in gas wasted.
    EDIT: Thought I'd include the calculation
    Assume $3/gal, 20 mpg initial mpg, 19 mpg with worn plugs
    ($3/gal)*(1gal/20miles)*(30k miles)=$4.5 k
    ($3/gal)*(1gal/19miles)*(30k miles)=$4.74 k
    And the difference grows if either your fuel price is greater or your initial mpg is lower (I normally only get around 18 split city and highway).
  7. Jan 30, 2012 at 4:01 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    The emissions warranty requires that you change them at 30K.
    As far as NGK on one side and Denso on the other: engines move down an assembly line with a person working each side. Both Denso and NGK are suppliers, sometimes both sides don't have the same brand of parts.
    I put in some iridium plugs at 30K but I am so anal I will probably do it again at 60K even if I don't need to.
