Spark Plug Decision
Discussion in '1st Gen. Tacomas (1995-2004)' started by S-Runner '01, Feb 27, 2009.
  1. Jul 5, 2012 at 6:47 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Can those dual tip densos be used in the 2.7 four cylinder engine?
  2. Jul 5, 2012 at 8:11 AM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    not trying to be a smart ass, but just use the type the owners manual tells you to use. the 3.4 has a slave coil system (3 coils fire the motor) that is why you need those on the motor, not on the ball at all with the needs of the 2.7 but on our trucks it is the safe bet to use what the factory tells you to use.
    and again it can be said its wasteful, but I don't push plugs past 30,000 miles.
  3. Jul 6, 2012 at 10:59 PM
    trigama3
    trigama3 Member
    rs9000 with my ride controller. BFG rugged terrain 2012 tread style.
    First time I changed my plugs form the factory. It had 3 densos on the driver side and 3 NGKs on the passenger side. WTF :eek: toyota oh thats right the plants in Tennesee uh-yep uh-yep.
    has anyone tried those e-3 plugs
  4. Jul 7, 2012 at 12:33 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    What the hell are you talking about? All 1st gen. Tacos were assembled at the now closed NUMMI plant in Fremont, CA.
  5. Jul 7, 2012 at 8:15 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    This ^^. It's NORMAL to get 3 Denso and 3 NGK plugs from the factory. You're quick to cast aspersions from a position of ignorance but, then again, you're just a FNG uh-yep uh-yep.
    E-3s are snake oil. Those of us who've taken the time to learn The Truth about Spark Plugs stick with OEM (Denso or NGK).
  6. Jul 7, 2012 at 9:10 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    The reason for this is that the heads were assembled in different plants (left vs. right) and the manufacturer (Toyota) didnt specify the type of plug therefore Toyotas come stock with different plugs in each head..
    Now you know.....this is a FACT!
    Change plugs every 30K with OEM and you cant go wrong!
  7. Jul 7, 2012 at 3:56 PM
    sportsterchop200
    sportsterchop200 Well-Known Member
    NE Georgia
    03 TRD Tacoma 4x4
    OME 881, Bilstein 5100 @ 0", OME 10mm JK spacer, Stock rear on 265/70-16
    I just changed mine and used factory plugs (Denso) bought from the dealership.
    I also changed my spark plugs wires, bought NGKs online.
    At the same time I also cleaned my MAF and throttle body thoroughly and tightened up my throttle cable (lots of slack).
    All combined my truck runs, and idles, ideally right now.
    Can't wait to see the next fill up to see what a full tank yields in terms of mpg
    __________________
    Sorry for the off topic but how do you tighten the throttle cable? Is there a thread I'm not finding?
  8. Jul 7, 2012 at 5:28 PM
    Madjik_Man
    Colorado Front Range
    It's the last blurb in this write up.
    It's super easy.
    And FWIW it was two 12mm nuts on my truck, not 14mm as it says in the write up.
    http://www.top4runners.com/ja/cleantb.html
  9. Jul 7, 2012 at 5:51 PM
    sportsterchop200
    NE Georgia
    03 TRD Tacoma 4x4
    Thanks, I already cleaned everything else and added the gasket. +1mpg so far. The plugs will be comming soon.
  10. Apr 4, 2017 at 6:00 AM
    fireofficer001
    fireofficer001 Member
    Pat
    2010 Tacoma 4x4
    Good day like to get plugs and wire set for 2010 Toyota Tacoma 4.0L-V6. I been looking NGK wire set but they just say 3.5l v versur 4.0 will they fit and do all recommend. Also what plugs Densos ? 2 electrode ?. any help would be great. Pat
