Spark Plug Install
Discussion in '1st Gen. Tacomas (1995-2004)' started by S-Runner '01, Aug 15, 2008.
  1. Aug 15, 2008 at 2:06 AM
    S-Runner '01
    S-Runner '01 [OP] Elderly Gentleman - Junior Member
    Jerry
    Yakima "the Palm Springs of Central Washington"
    BSP '01 S-Runner
    Garmin 260W - GPS Scanguage II K&N FIPK Kit Delta Low Profile Toolbox Fumoto Oil Drain Valve New Toyota Front Mats B&M Short Throw shifter New Tokico Gas Shocks Compustar Anti Theft Alarm System Redline Elite Hood Struts Phase Linear DVD/MP3/CD Player Professionally Detailed
    Where can I get a step by step instructions to change my spark plugs?
    I bought a set of plugs thinking I could just put them in and go but looking at my engine it looks like it's going to be more of a job than I was expecting.
    My engine is a V6 3.4L and I can't even see the plugs on the passenger side.
    What all am I going to have to take off to get at the plugs?
    I've changed my own plugs dozens of times in all the cars that I've owned over the last 50 years but I'm stumped this time.
    Can someone point out where I can get step by step instructions?
    Jerry
  2. Aug 15, 2008 at 5:03 AM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    These tacomas dont actually have sparkplugs lol just joking
    i would look at 4x4wire.com they have some write ups on how to do things to tacos may have one on sparkplugs.
    But basicly you need to remove your intake and you will see your coil packs there will be 3 of them remove these and the plugs are down in the engine. For the driverside i always just use a long extension.
    There not to much fun to change on these trucks but its do able.
  3. Aug 15, 2008 at 8:59 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
  4. Aug 15, 2008 at 9:07 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    changing the plugs on the 3.4 is cake bud! on the passenger side....remove the intake tube, then you have easy access to remove the coil packs(if your truck has them...if not, pull the wires and there are the plugs), driver side.......you need to move a bracket or 2 outta the way, but other than that, pull the wires there also. you will need at least 2 rather long extensions and a spark pluf socket with a rubber boot in it, and dont forget to put a little anti seize on the new plugs.
  5. Feb 12, 2010 at 7:41 PM
    truthseeker
    truthseeker Member
    Southern Oregon
    2002 Prerunner 4cylinder auto
    I need help, I went to replace the spark plugs on my 4cyl 2002 prerunner and found they are underneath something I have never seen before. My last truck was a 1970 Datsun, so things have changed a bit!
    What do I have to remove to get to them?
    Its the 2.7 any photo's?
