Spark plug power loss,please help!!!
Discussion in 'Performance and Tuning' started by TACOsupremacy, May 5, 2012.
  1. May 6, 2012 at 11:04 PM
    TACOsupremacy
    TACOsupremacy [OP] Well-Known Member
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Im pretty sure it in the right order..did do it one by one..and i cleaned my maf sensor about a week before doing the plugs
  2. May 6, 2012 at 11:06 PM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    !!? I do have a maf cal..and a urd intake. Ive been having second guesses about removing it..i think it could be that too
  3. May 6, 2012 at 11:07 PM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Thanks i will try that first!!!!
  4. May 6, 2012 at 11:13 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    I would try that. I have been in the truck with him before when it happens. Its only one the freeway when his truck does it but on the street its fine. It goes into like a safe mode and kills all power from the motor and we had to stop turn it off for a few and then it would be fine for a little while. It got wose the higher in elevation we went and through the hills when it was under high RPM.
    With your case it sounds more like a vacuum hose is off. That normally the issue when this happens.
  5. May 6, 2012 at 11:29 PM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Cant be any vacum hoses i checked like 3 times today..but we'll see
  6. May 6, 2012 at 11:31 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    There is a super small vacuum hose that's easy to forget that goes behind the air intake assembly. I'm assuming you have an OEM intake so you're gonna have to pull a lot off when you changed the plugs.
  7. May 6, 2012 at 11:33 PM
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    Bet its something small affecting your fuel ratio...
    Dirty throttle body... Bad PCV valve.
    Good luck OP! Keep us updated.
  8. May 6, 2012 at 11:35 PM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    No actually i have a URD intake, so theres alot of space to work on that side. Im sure there are no hoses lose or off i double checked and re checked again..
  9. May 6, 2012 at 11:50 PM
    Bishop2Queens6
    SoCal
    2009 DCSB SR5 4x4
    This can be a really dumb/obvious question, but were the correct coil packs and plugs placed into the correct cylinder...? Something so simple may be overlooked.
  10. May 6, 2012 at 11:53 PM
    boshak
    AG
    CA
    He said he did one plug at a time so he's pretty certain on the correct order.
  11. May 6, 2012 at 11:54 PM
    Bishop2Queens6
    SoCal
    2009 DCSB SR5 4x4
    Maybe check the integrity of the plug itself, not only a loose connection, but a bent and/or dirty tab.
  12. May 6, 2012 at 11:58 PM
    boshak
    AG
    CA
    He swapped plugs twice :p
  13. May 7, 2012 at 12:23 AM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Plus isnt the length of the coil so short that it can only reach that plug? Well thats what it seemed like anyways, but yeah i did it one at a time and went thru two sets :mad:
  14. May 7, 2012 at 8:55 PM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Are you supposed to disconnect the battery before you change plugs?
  15. May 7, 2012 at 10:12 PM
    #35
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I never do.
  16. May 7, 2012 at 10:52 PM
    #36
    boshak
    AG
    CA
    I don't. Did you take it to the shop? What's the verdict?
  17. May 7, 2012 at 11:02 PM
    #37
    Muscles
    Muscles Well-Known Member
    Kyle
    San Diego
    05 PreRunner TRD
    K&N Air Intake
    subbed, for when i attempt to change my plugs haha
  18. May 7, 2012 at 11:03 PM
    #38
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Probably don't need to, but I live by the rule to disconnect the battery for anything electrical. I know after I mess with the plugs or MAF it dies out on me on the first crank and then the second time starting it runs like crap for like 30seconds. I would try disconnecting your battery for like an hour or so.
  19. May 8, 2012 at 12:24 AM
    #39
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Well when i took it the shop i told them everything whats going on. They checked everything, test drove it and it happened to them, all they did was disconnect the battery for a couple minutes then started her up again, then it ran fine after the first 5min. They told me by doung that your jus restting the ecu..i guess?? So hopefully tomorrow everything goes well
  20. May 8, 2012 at 12:55 AM
    #40
    06yoda
    06yoda Well-Known Member
    Tanner
    Clovis, CA/ Emmett, ID
    1996 Landcruiser FZJ80
    I thought one bank was supposed to have ngks and the other denso. I believe they are different length. You prob didn't tighten the plug itself Enough.
