Spark plug replacement schedule
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LTC T, May 5, 2015.
  1. May 5, 2015 at 9:21 PM
    LTC T
    LTC T [OP] Member
    Tacoma TRD
    I just bought a 2007 Taco with 84K on it. It's running fine but getting 16 mpg. My neighbor has 2015 Taco and he tells me that the tacos with the 6cyl 4.0L engine require spark plug changes every 30,000 miles. Recently changed the oil and went with synthetic oil, changed the engine air filter. Is he correct about the every 30K spark plug replacement?
  2. May 5, 2015 at 9:24 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Yes he is correct about the spark plugs being changed.
  3. May 5, 2015 at 9:33 PM
    LTC T
    LTC T [OP] Member
    Tacoma TRD
    Thanks! Just thought it odd that they have to be changed that often. Does it improve gas mileage? Do you know how difficult is to change them out?
  4. May 5, 2015 at 9:39 PM
    MrCrobb
    MrCrobb Well-Known Member
    Connor
    San Diego/San Jose
    06 TRD Sport
    Snug Top Camper Shell, Black Anzo headlights, OME 884 + Dakars
    It should help your gas mileage, depending on when they were changed last... It's not too difficult to replace them. The most important part is torquing everything to the correct specs. It took me a few hours to replace mine, there's a good DIY write up on it
  5. May 5, 2015 at 9:39 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    30,000 is correct. However it pretty much only applies to emissions.
    Once you are out of warranty I see no reason to change before 50,00
    Mine looked great at 50,000. But I went ahead and replaced them anyway.
    I went with denso plugs, but will likely run NGK time around.
    Not that Denson is bad, they are great. I have just liked NGK since I started using them years ago in my motorcycles.
  6. May 5, 2015 at 9:41 PM
    MrCrobb
    Connor
    San Diego/San Jose
    06 TRD Sport
  7. May 5, 2015 at 9:51 PM
    LTC T
    LTC T [OP] Member
    Tacoma TRD
    Thanks!
    MrCrobb likes this.
  8. May 6, 2015 at 8:59 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    mine came out at 30,000 and replaced and they all looked fine, just a bit bigger gap than new
    but what is important is regular changing prevents them from seizing in there and borking the threads
    don't know for sure if it changed anything driving-wise other than to say it was perfect before
    and perfect afterward and was fun to do
  9. May 6, 2015 at 12:31 PM
    TacomaZL
    TacomaZL Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    Yeah, V6's have every 30,000, but 4 cylinders are every 120,000....no idea why the huge difference between the two. (Although I'm not a mechanic)
  10. May 6, 2015 at 2:25 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    4 cyl engines use iridium plugs and the 6 cyl use copper.
  11. May 6, 2015 at 3:30 PM
    DPC08
    DPC08 Well-Known Member
    FL
    09 DCSB
    Getting there...
    When I changed mine, I noticed the NGKs developed a larger gap than the Densos did.
  12. May 6, 2015 at 3:33 PM
    Aw9d
    Aw9d That one guy
    I noticed this as well. My Denso's were gapped around .42 and my NGK's were around .45-.46
    Plus the NGK's looked like they were more worn out the then Denso's.
  13. May 6, 2015 at 3:43 PM
    RearViewMirror
    Craig Christ
    When you go to the dealership the Denso's will be what you get for a replacement.
