Spark Plugs 4.0
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hardtaco, Nov 14, 2016.
  1. Nov 14, 2016 at 3:54 AM
    hardtaco
    hardtaco [OP] Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    Please tell me what I need to know about changing out my spark plugs in my 08 4.0....
    What should I buy ? I looked at the locations over the weekend, and I didn't see a whole lot of obstacles in the way as far as getting to them. Anyone know the torque specs of the spark plug itself, as well as the bolt that holds each coil pack onto the plug ?
    Thanks and my apologies if this has been covered a time or two.
  2. Nov 14, 2016 at 4:20 AM
    wtjl240
    wtjl240 Well-Known Member
    Jeff
    Spring Hill, TN
  3. Nov 14, 2016 at 7:32 AM
    beetlevegas
    beetlevegas You are no Vader. You are just a child in a mask!
    JP
    Las Vegas NV
    2011 silver Tacoma TRD 6 Speed double cab
    stuff
    The guys in my shop all use the plugs out the 4 banger's. Its a 90K plug. I thought they was crazy but I have been running the same plug for 15k with no problems.
  4. Nov 22, 2016 at 5:03 AM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    Last question guys......
    Is it best to change these out with the engine cold or warm ?
  5. Nov 22, 2016 at 5:44 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Doesnt matter. I prefer not burning myself so... lol.
    I went irridium on my plugs and I like em.
    The left side is easy to do. The right side is a pain unless you have tiny hands. But over all its not hard. Took me 45 minutes and that included taking pictures and marking my okd plugs. Some thread said it takes like 4 hours or something HAHA. That must include a case of beer in there somewhere.
    Nopro, RedRed and beetlevegas like this.
  6. Nov 22, 2016 at 10:49 AM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    It's an easy job. Take your time and do NOT over tighten the plugs. The last one on the driver side is kinda of a bitch unless you remove a few wires in front of it. You will want an angle socket adapter.
    ChadsPride and brightshizzle like this.
  7. Nov 22, 2016 at 12:15 PM
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    Put some duct tape on your socket so you won't be fishing it out of your spark plug tube. Best advice someone on here gave me a long time ago.
  8. Nov 22, 2016 at 1:40 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    It certainly does matter. Change plugs when the engine is cold. Hot aluminum is weaker and more likely to strip the threads while torquing than with a cold engine.
    Camel51, Shark18, Partzguy and 9 others like this.
  9. Nov 22, 2016 at 1:42 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I ruined a lawn mower head by not following this advise.
    Partzguy likes this.
  10. Nov 22, 2016 at 3:02 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    Truth. Always change spark plugs when the engine is cold.
    Shark18, Partzguy and Markcal like this.
  11. Nov 22, 2016 at 3:08 PM
    Markcal
    Markcal Well-Known Member
    I just did my spark plug replacement and wish I was given this advice before hand, but live and learn.
    R0dzilla75[QUOTED] likes this.
  12. Nov 22, 2016 at 4:29 PM
    magnetic4x4
    magnetic4x4 Well-Known Member
    2013 Magnetic Gray DCSB XSP-X 4x4
    If you have a magnet you can stick down in the hole, there's another way to do it that might work even better. Pull the rubber holder out of the spark plug socket (mine never really wanted to stay in). Then you can loosen all the plugs on one side, go back and pull them out with the magnet and slide your new ones in. You'll be able to tighten the new plugs without leaving the socket or the rubber piece behind when you go to the next one. I do all my tune ups at work this way. I also use a universal joint and a 2ft extension so I don't have to reach over the fender as much while doing it.
    MTopp likes this.
  13. Nov 22, 2016 at 5:44 PM
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    Apply Anti-Seize to the threads of the new plugs. That's not optional. You can get small packets of it at the counter at any autoparts store.
  14. Feb 13, 2017 at 10:53 AM
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    Changed mine just a bit ago. Reading Chris4x4's write up would have helped me a little... but I did it in about an hour. Did not remove air filter housing, I just loosened the hose clamp on the air box and turned it sideways... I was able to reach all passenger side easy like that.
    Driver's side I should have followed his advice and removed some of them hoses. I just removed the metal bracket and worked around the hoses.
    ChadsPride likes this.
  15. Feb 13, 2017 at 1:03 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    I bought the Denso plugs last time on ebay for $20.
    14TACO4X4 likes this.
  16. Feb 13, 2017 at 1:16 PM
    14TACO4X4
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    I went to O'Reilly's and got 6 for $30, with a little packet of antiseize.
    QChawks likes this.
  17. Feb 4, 2018 at 12:26 PM
    ShuggieTaco
    ShuggieTaco Well-Known Member
    2011 Tacoma
    1.5" level front
    So I’ll ask this thread too. Some folks on another thread told me not to use iridium but to use copper. I was told the ones that came from factory are platinum denso and NGK. I just replaced with iridium NGK’s.
    BassAckwards likes this.
  18. Feb 4, 2018 at 7:09 PM
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    Cold! Hot you might strip the threads.
    TacomaSalad and Partzguy like this.
  19. Feb 4, 2018 at 7:10 PM
    docbrown
    Tampa, FL
    05 Tacoma SR5 4X4
    Copper. On the 2nd gens the Iridiums are a waste of money and do not preform as well as the copper plugs.
  20. Feb 4, 2018 at 7:18 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Copper plugs on the 4.0. Iridiums on the 2.7
    balljoint likes this.
