spark plugs - why 30k?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Raylo, Apr 11, 2009.
  1. Apr 11, 2009 at 8:05 AM
    Raylo
    Raylo [OP] Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    Not getting close to my first plug change yet but I was wondering why in this day of 100k tune ups Toyota specs a 30k interval for spark plugs in our 4.0Ls. Even my old 1994 Camaro had a 100k interval (with platinums). I changed em out at 50k when they still looked fine and then ran non-plats in it for another 50k and they still looked great, too. So the longer intervals don't seem entirely due to using platinums. Are there automotive engineers here who can tell us what about these motors mandates more frequent plug changes? Spark voltage, combustion temps, oiling issues, what???? All this said, it doesn't look particulary hard to do the plugs.
  2. Apr 11, 2009 at 8:53 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    I don't understand either. I changed mine at 45k miles and they still looked good.
    Gap was .40 on the old plugs.
  3. Apr 11, 2009 at 9:00 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its an easy way to keep an eye on how your engine is running. Takes an hour to change the plugs, and the cost is about $25.00. I dont mind changeing them at 30K. Hell, even if it was recomended to be changed at 100K, I would still change them or at least insprct them every 30. Peice of mind.
  4. Apr 11, 2009 at 11:02 AM
    Raylo
    MD, USA
    Not interested in a debate about how often and why people change their plugs. Since this is different from just about any vehicle I have seen for awhile I am just curious if anyone knows of an engineering design basis for the Toyota 30k spec. If no one knows, no biggie.
  5. Apr 11, 2009 at 11:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have no proof of this, BUT, Some friends of mine and I got to gether to figure this out as well...We think that, Toyota uses these plugs due to the cost, and the resistance values of the plug and how they transfer the spark. upon testing the OEM Denso plugs, they have a slight "V" grove cut into the side electrode, and it seems to produce many sparks in one shot. Most of the Platinum, and Iridium plugs I have seen, dont seem to generate the spark that the OEM's do. Also, from what we have gathered, the OEM ignition puts out a shit load of volts to the plug. Upwards of 50,000v. We think that given that voltage, a Platinum or Iridium plug would not last as long as the OEM plugs. In the past, I have dynoed our trucks with Platinum and Iridium plugs, and found that when useing these types, on the V6 engines, a loss of performance is shown. Interesting thing, however, is that when useing the Platinum or Iridium plugs on the 2.7, they perform very well.
  6. Apr 11, 2009 at 1:32 PM
    2009tacomav6
    2009tacomav6 Well-Known Member
    phx AZ
    2012 4x4
    TRD SC TRD Cat Back KMC 17x9 Addicts
    The standard truck has a 30k mile plug replacement. If you swap them out the the platnium plugs they sell those have a 100k mile replacement plan. I can only imagine that most people would not go in a regap the plug after 30k miles and if they did maybe you can accomplish the same thing, higher efficiency. Of course if you are taking the effort to pull the plug out, why not spend the 5 bucks and put a new one in rather than the old one... Who knows... might be worth a shot, or it could just be a waste... I Think the answer to this mystery is in the same lock box that the JFK question is in...
  7. Apr 11, 2009 at 1:50 PM
    rpoint16
    rpoint16 Well-Known Member
    Tempe, AZ
    2022 TRD Off-Road, Super White.
    Bone Stock
    What he said:D
  8. Apr 11, 2009 at 3:14 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Sometimes we don't get what we want when we post online, do we? Try a better tone and maybe you'll get more help. Luckily, Chris is a nicer guy than I and chooses to assist you.
  9. Apr 11, 2009 at 6:04 PM
    Raylo
    MD, USA
    That was a nice tone. It is always a challenge to get "what you want" on a forum and it is likewise a challenge to refocus a thread w/o sounding like a dick. But if you aren't clear about it attempts to refocus rarely are successful... and we get another thread with 50 opinions on when to change spark plugs. Gack! BTW, this isn't a thread about help. Just trying to understand Toyota's engineering approach. Chris's points make some sense. It is possible that the copper plugs for whatever reason dyno a couple HP higher. But I don't believe the ignition puts out more voltage that other modern HEI systems that use plats. My gut feeling is that since it is relatively easy to change plugs the benefits of the potential modest HP gain and chance to read the plugs periodically outweigh the benefit of a longer tune up interval. And maybe make some additional revenue for dealer service depts? Probably splitting hairs on the benefit tradeoffs though....
  10. Apr 11, 2009 at 6:15 PM
    jfr02
    jfr02 Well-Known Member
    2012 dcsb 6spd sport
    the hundred thousand mile tune up was just marketing i was a tech at a caddy dealership for about 7 years and a independent shop for about 6 years i know on my old 99sr5 i changed them at about 45k and it made a difference no fluid,spark plugs,or filters should be left on your truck for 100k it's not good practice prementive maintenance is the best way to keep your truck going
  11. Apr 11, 2009 at 7:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It doesnt. I have been looking more into this and talking wiht one of my buddies about it. Like mentioned in my post, We "think"...., Not quite sure altogether. I do know that, for some reason or another, our trucks are affected by the type of plug used, more so than other vehicles. Im going to be meeting up with an Engineer friend of mine in the next month, so this may be a good thing to bring up to him. I'll post back if he has any ideas. :)
  12. Apr 12, 2009 at 5:18 AM
    Raylo
    MD, USA
    Sounds good Chris, let us know. I are an enguneer, too, just not the right kind. Never had a course in engine design. Another thought that occurred is that perhaps they factor in the possibility of extra hard duty like towing in deciding on spark plug choice and service interval. Who knows what lurks in the minds of Toyota engineers?
  13. Apr 29, 2009 at 11:09 AM
    T0y0ta05
    T0y0ta05 Well-Known Member
    Pennsylvania
    05 Silver Sport DC Tacoma
    Bone stock other than new floor mats.
    My truck currently has 40K on it and I'm looking to replace the spark plugs as well. The funny thing is I asked the dealer to do this when I had it in for the 30K and they said it wasn't necessary. Checking the manual says otherwise, but I took their word at face value. In any event, which brand are others buying to replace their OEM plugs or are most just going to the dealer? The manual lists part number which I'm sure matches up to an after market plug. I presume we should use like for like here and not install platinum or irradium plugs?
  14. Apr 29, 2009 at 11:14 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    30k - copper based plugs......100k - iridiums.
  15. Apr 29, 2009 at 11:16 AM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    I generically replace them every 50k and even so, they still look pretty good. My brother who used and abused his didn't change his until 150,000. There wasn't much left of the electrodes needless to say...
  16. Apr 29, 2009 at 11:35 AM
    T0y0ta05
    Pennsylvania
    I would be surprised your brother didn't notice a difference in performance long before 150K?
  17. Apr 29, 2009 at 11:43 AM
    OU812
    OU812 ban the term murdered out
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    Nothing yet, brand new!
    Like Chris said spark plugs are cheap and not hard to change on our engines. I did mine in an hour and will have to change them again soon. I'm at 51k now.
    As far as the reasoning behind the interval I have to say they have a method to the madness. Those engines that specify 100k intervals may take years or a decade before they reach that point.
    I have seen firsthand plugs seized in heads due to lengthy intervals. Especially on aluminum heads. This may have something to do with Toyota's 30k interval.
  18. Apr 29, 2009 at 11:46 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I had a 2002 Accord with 100,000 mile plugs, but I changed them at 60,000 miles and noticed an improvement in performance. I plan on changing the plugs in my 2.7 Tacoma at 50,000. If the 4.0 is using copper plugs, I would absolutley change them a 30,000. JMO.
  19. Apr 29, 2009 at 1:11 PM
    sweater914
    sweater914 Well-Known Member
    North Dakota
    '09 I4 5spd Access Cab Timberland Mica SR5
    Don't know the technical reasons behind the 30000 change, however for the folks using NGK or Bosch Iridium plugs change them at 30000. I've noticed that the center electrode will erode with time and open up the gap significantly. It's easy to spot, usually the center electrode will start out thick at the base and taper to a finer point. The plugs I've pulled the taper is gone. I didn't affect day to day performance but it's not optimum.
  20. Apr 29, 2009 at 2:01 PM
    Blackened Taco
    Blackened Taco Well-Known Member
    Tony
    Virginia
    2005 AC 4WD TRD Sport Tacoma Speedway Blue
    3 inch suspension lift, 16 inch TRD FJ Cruiser black alloys, 33 X 12.5/16 Swamper Trxus M/T, Line-Xed Toyota skid plate, TRD exhaust, TRD cold air intake, Full tint to match factory tint, In channel wind deflectors, Custom wired hidden XM, Black shorty antenna, Black background headlights, Sockmonkey TRD decals, Kenwood 5120 HU with navigation, Boston Acoustic SL60 front compnonent speakers, SL65 rear speakers, Grillcraft lower mesh grille, Black badging, AromorTech Offroad rear bumper and rear shackle flip kit Access tonnosprt cover, 12 volt power adapter wired in under the dash for standard plug in items. Recently added Devil Horn Toyota Logo, Thanks Andres.
    Do not replace the standard plugs in a Tacoma with platinum or otherwise. Longevity is the least of the concern when it comes to the plugs on a Tacoma. As Chris mentioned the standard resistor plugs put out a different heat range and spark. The vehicle is designed for this plug to do the job. Using a differnt type of plug affects more than just the spark. Over the long run damge to the cylinder walls can occur as well and certainly a lack of performance. When initally using a different type of plug you may not feel it but will see a difference in fuel economy and also the potential of a higher emmisions rating. Using a colder plug such as an irridium or platinum is going to cause a wash out inside of the cylinder since it is not burning as hot and this translates into poor fuel economy and performance. I beleive that Toyota uses the resistor type plugs for emmissions reasons more so than anything else.
