spark plugs
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4421.frank, Jul 18, 2010.
  1. Jul 18, 2010 at 12:47 PM
    4421.frank
    4421.frank [OP] Well-Known Member
    Southside chicago
    02 double cab prerunner supercharged
    nasty dent on driver's side bed panel, shabby seats, cigarette burned interior roof, missing berf bar pad, cracked rain visor, removed hood scoop, unmentionable stain on back bench?
    What are the some of the better pre-gapped spark plugs for our truck?
  2. Jul 18, 2010 at 12:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    All should be checked for Gap. Though they say they are "Pre gapped", very few are actually set to what they should be.
  3. Jul 18, 2010 at 12:59 PM
    scocar
    scocar hypotenoper
    Every discussion I have seen about this always comes back to "Use the stock Densos," but I see you have an SC and don't know if that is a factor.
  4. Jul 18, 2010 at 2:35 PM
    4421.frank
    Southside chicago
    what is the correct gaping?
  5. Jul 18, 2010 at 2:40 PM
    scocar
    scocar hypotenoper
  6. Jul 18, 2010 at 3:04 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    If you're boosted you'll need different plugs than what's outline in the owner's manual. I'm sure someone in the know will chime in on this for you.
  7. Jul 18, 2010 at 3:35 PM
    AKTacoma
    AKTacoma Dedicated Crew Chief
    Houma, Louisiana
    08 Tacoma DCLB
    I know it says its a Tundra forum, but this dude's talking about his Tacoma, check it out:
  8. Jul 18, 2010 at 3:54 PM
    kumaWRX
    kumaWRX Well-Known Member
    Jase
    Oahu, Hawaii
    2004 TRD Offroad PreRunner 3.4L V6
    SAW 2.0 Coilovers, Wheeler's 3-leaf AAL, Toytec 1" lift shackles, Bilstein 5100 rear shocks, aFE Stg. 2 intake, Doug Thorley headers, Magnaflow muffler, 16x8 ProComp 7089 wheels, Toyo Open Country A/T tires, Pamalu bedliner, Bakflip G2 bedcover
    Only use Denso or NGK, there are no better plugs than these.
  9. Jul 18, 2010 at 5:05 PM
    BajaTaco96
    BajaTaco96 Well-Known Member
    Silver Springs, FL
    1996 Toyota Tacoma 4wd, 3" suspension lift
    K&N, ToyTec 3" front spacers, 3" Fabtech AAL's, Flowmaster exhuast, no cat, Exedy Stage 2 clutch
    I run the Iridium NGK's and love them. Can't go wrong with them IMO.
