Spark plugs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bamahoyt, Jan 26, 2011.
  1. Jan 26, 2011 at 12:49 PM
    Bamahoyt
    Bamahoyt [OP] Well-Known Member
    Ted
    Knoxville, TN
    2014 TRD Sport DC LB 4x4
    My truck's gas milage has really dropped off lately and the last couple of days it has gotten harder to start. Anyone think it could be the spark plugs? If so, are NGK's from advanced a good may to go at 4.99 each or is there a better/cheaper option. I run NGK in my Motocross bikes so just wasn't sure what you guys think about them in our Tacomas. Can get denso's for 2.99 but not sure I want to go that cheap.
  2. Jan 26, 2011 at 12:55 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    get the OE toyota ones
  3. Jan 26, 2011 at 12:57 PM
    Bamahoyt
    Ted
    Knoxville, TN
    Don't have a dealer within 60 miles and how much are they?
  4. Jan 26, 2011 at 12:58 PM
    PLC721
    Patrick
    Chandler, Az
    not sure lemme check
  5. Jan 26, 2011 at 12:59 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I thought NGK and Denso Coppers were stock anyways? NGK on one side, Denso on the other... LoL
  6. Jan 26, 2011 at 1:00 PM
    PLC721
    Patrick
    Chandler, Az
  7. Jan 26, 2011 at 1:01 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Toyota uses both NBK and Denso's on the Tacoma.
    These can be purchased at any auto parts store...unless you are ok with getting ass raped by buying your plugs from a dealer when it's the same damn plug.
    I opted to replace all six with Denso's as they were a little cheaper than NGK at Advance Auto Parts.
  8. Jan 26, 2011 at 1:02 PM
    PLC721
    Patrick
    Chandler, Az
    i got mine for 3.25 each so i really dont think i got ass raped.
  9. Jan 26, 2011 at 1:04 PM
    macgyver
    Brad
    Canton, GA
    Thats a pretty good deal. From what I have heard people are paying a lot more than 3.25 per plug at the dealer. I can't remember exactly what I paid for the Densos but I recall it being in the $3-4 range.
    I used to run NGK's in my turbo accord BKR7E's they were a good plug and cheap too.
  10. Jan 26, 2011 at 1:11 PM
    Bamahoyt
    Ted
    Knoxville, TN
    Thanks for the link. Helps a lot
  11. Jan 26, 2011 at 1:13 PM
    PLC721
    Patrick
    Chandler, Az
    no problemo
  12. Jan 26, 2011 at 1:31 PM
    Bamahoyt
    Ted
    Knoxville, TN
    Do you think that my hard starting lately could be partially because of my plugs?
  13. Jan 26, 2011 at 4:10 PM
    bmwtech330
    bmwtech330 Member
    winston salem
    2011 TRD SPORT DC 4x4
    6 bed D-rings, 35% front tint, X-PEL threshold, tailgate anti-theft screw clamps and nitrogen in the tires.
    I wouldn't say for sure that the plugs are the culprit of the long crank condition. But i changed plugs on a 2007 tacoma 4.0 that had 60k on the original plugs. Before I changed them it would crank and crank before it would start, after I replaced all 6 plugs with OEM plugs the truck started right up. The service interval is 30k I think, so what could it hurt? Its easy and cheap.
  14. Jan 26, 2011 at 5:05 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    My Denso's were in way better shape than my NGK's were. I recommend the Denso's...
  15. Jan 26, 2011 at 5:09 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    my NGK's were in better shape then my Denso's. my NGK's also held their gap better, the Denso's were way off.
  16. Jan 26, 2011 at 5:21 PM
    judd94
    judd94 Well-Known Member
    Ponchatoula, LA
    17 4Runner TRD Off Road Premium
    Mods in Progress
    Gas mileage sucks in the winter for everybody due to wonder winter gas. Its a different mixture and you'll notice a slight difference in performance. That could be your problem
  17. Jan 26, 2011 at 5:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Interesting. Thats the first I have heard of this. All the 1GR's I have swapped the plugs on, All of them had the NGK's WAY out of spec, while the Denso's were in spec.
  18. Jan 26, 2011 at 7:50 PM
    PLC721
    Patrick
    Chandler, Az
    ready for mine on saturday?
  19. Jan 26, 2011 at 7:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sure.....right after I finish the 2 trucks that need to be lifted.
  20. Jan 26, 2011 at 8:10 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    i just re-checked my old plugs and your right, the Denso's did hold a better gap. i must of got them mixed up. the Denso's were at .044 and the NGK's were all the way at .054 :eek:. the plugs had 68,000 miles on them :eek:
