Spark Plugs
Discussion in '1st Gen. Tacomas (1995-2004)' started by MBLACK, Jul 20, 2007.
  1. Jul 20, 2007 at 10:17 PM
    MBLACK
    MBLACK [OP] Member
    Hello everyone. 52k on my original plugs now. I think it is time to throw in some new ones. Any suggestions for the 04/2.7 Liter? I have not done any reasearch on plugs yet.
  2. Jul 20, 2007 at 10:44 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Get either Denso or NGK plugs. Our trucks don't play well with other spark plugs. Whatever you do don't get Bosch plugs, I've heard numerous horror stories about some of those plugs breaking off in there. No need to get Iridium plugs unless you're boosted. You can try getting them from sparkplugs.com or trdparts4u.com. I used the latter many times getting various parts with great prices and customer service.
  3. Jul 24, 2007 at 4:42 PM
    bowzerdoo77
    bowzerdoo77 U.S.M.C.
    North Ogden Utah
    1997 REG CAB 4x4
    None
    yep just go with denso's that the dealer has they are about 5 bucks a plug and you cant go wrong with oem.. I have also heard the same thing about bosch and breaking off so hope that helps
  4. Jul 25, 2007 at 1:32 PM
    MBLACK
    MBLACK [OP] Member
    Thanks guys. I guess I'll go with the OEM.
    I was just curious if there was anything better out there.
  5. Sep 9, 2007 at 12:39 PM
    thenrie
    thenrie Well-Known Member
    Stafford, VA
    2000 Tacoma, SR5, TRD, 2.7L (LEV), 4wd, 5sp m
    Magnaflow cat and cat-back exhaust, AFE Stage 2 cold-air intake system, 2.5" lift via Skyjacker leaf packs, Bilstein 5100s.
    I had a guy tell me he was runnning the Sure Fire (something like that) plugs in a '97 2.7L, and was marking 25mpg highway in a 4x4 ext cab, 5spd man. He has a K&N filter and intake system with a "tornado" (?) inserted in the intake tube as well. He said the plugs are the hipo plugs with four grounds to the electrode, making a larger, more even spark. These plugs run about $8 each. Do they really make a difference in mpg?
  6. Sep 9, 2007 at 1:29 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Can't answer about the plugs, but don't waste your time and money looking for a tornado. It is "snake oil" and takes up space in the intake that could be used for air, and does not work, it actually robs power and costs fuel over a stonck set-up.
  7. Sep 15, 2007 at 4:29 AM
    krlang
    krlang NewEnglander
    Commonwealth of Massachusetts
    03 2WD 2.4L Tacoma Reg Cab
    Chrome Bumpers F&R, Grille & Corner Lights, Wheel Skins, Red/Clear LED taillights, Remote start, PDL, Cruise, K&N, All Kenwood, DNX-5120 6.1" NAV/TRAFFIC/DTV/DVD/XM/BLUETOOTH/USB/IPOD/SUB/rear cam, Tint, Air Band radio, Class 3 Hitch with 4/7 pin harness, Transmission Cooler, Red Top Battery, "Deck Plate" mod.
    I spent the $8 on the Denso iridium for my 2.4l 2WD, I figured anything could help.
    If I take it easy on the pedal, (55-65mph) I can get 25.5 mpg out of it.
    If I push it to 80 it drags it down to 22-23
    Iridiums, K&N, regular unleaded
  8. Sep 16, 2007 at 11:52 AM
    thenrie
    Stafford, VA
    I ended up just going with the recommended NGK plugs. The taco sure needed it. The electrodes on the Bosches I took out were worn and the pickup runs much better now. I changed the engine oil and put in the Mobil 1 High Mileage 10w-40. I just ordered a Magnaflow exhaust system and an AFE cold-air intake system from Auto Parts Warehouse. Once I get them installed, I'll post my results.
