spark plugs
Discussion in '1st Gen. Tacomas (1995-2004)' started by Chaseb, Jun 8, 2012.
  1. Jun 8, 2012 at 5:15 PM
    Chaseb
    Chaseb [OP] Member
    Florida
    04 tacoma sr5
    3 inch body lift, flowmaster exhast, 33inch daytom a/t, blacked out windows, 2 12inch kicker subs
    i plan onchangeing my spark plugs this weekend....ive never done it before but im reading on here that your suppossed to "gap" the new plugs.....what happens if i just put the plugs in the way they came in the box?
  2. Jun 8, 2012 at 5:20 PM
    nfs257
    nfs257 Well-Known Member
    Menifee, Ca -> Tucson, Az -- April
    09 DCLB PreRunner MGM SR5 Debadged
    Trac Performance built Prerunner
    They should be pre-gapped but not gaurenteed. If the gap is to small or to big then the engine will not run right...
  3. Jun 8, 2012 at 5:51 PM
    scocar
    scocar Going Full Vanilla!
    Dick
    Erehwon
    The Silver Steed of Righteousness
    Animal husbandry, Bullshit detection, Very runny cheese
    In fact, check them before you leave the store.
    I caught 2 of 6 at the dealer that had both ground electrodes misaligned. Like, way off sideways, not away form the middle electrode. But all the ones I ended up with were all gapped correctly right out of the box.
    You need this kind of gauge (assuming V6, not sure what the 4-banger uses):
  4. Jun 8, 2012 at 6:04 PM
    Rackster
    Rackster Well-Known Member
    Kevin
    Connecticut
    '04 E/cab 4x4 2.7 Auto SR5
    I recommend going with the OEM replacement plug and not an aftermarket plug. As others have noted, the plugs come pre-gapped and some with a protective sleeve. Although I've never found a plug improperly gapped in the past 15 years or so, I still check every plug I put in to make sure the gap is correct. I also check the gap of the plugs I take out to see if there was uneven wear from cylinder to cylinder. If you were the one that gapped them when they went in (or confirmed gap setting before installation), then they should be the same coming out. Also check the spent plugs for other tell-tale signs of engine problems. Haynes/Chilton manuals generally have a color picture page to help you troubleshoot issues. They also have tips to keep you from crossthreading or removal/installation suggestions.
    Good luck!
    Kevin
  5. Jun 8, 2012 at 7:00 PM
    Chaseb
    Chaseb [OP] Member
    Florida
    04 tacoma sr5
    alright, thanks for the info!
  6. Jun 8, 2012 at 9:02 PM
    fidencio74
    fidencio74 Well-Known Member
    Fidencio
    Escondido, CA.
    2018 TRD Sport 4x4
    Stock for now
    What is the number on the gauge? .043
  7. Jun 8, 2012 at 10:52 PM
    scocar
    Dick
    Erehwon
    Yes. I tried hard to make it show...
  8. Jun 8, 2012 at 11:58 PM
    austinramsay
    austinramsay Well-Known Member
    Austin
    Yuma, Arizona
    2001 Tacoma TRD Doublecab
    How do you gap a spark plug anyways?? I know how to do a good amount of mechanical work but ive never gapped a spark plug :facepalm: haha
    edit: nvm just looked it up on youtube :)
