Spark plugs...
Discussion in '1st Gen. Tacomas (1995-2004)' started by sirsaechao, Feb 24, 2010.
  1. Feb 24, 2010 at 9:35 AM
    sirsaechao
    sirsaechao [OP] Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
  2. Feb 24, 2010 at 2:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    either at the dealership or urdusa.com. are those the iridiums?
  3. Feb 24, 2010 at 4:15 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    The shouldn't be because the dual grounded plugs are what's needed in the 5vz-fe. Have you tried rockauto.com?
  4. Mar 9, 2010 at 12:05 PM
    sirsaechao
    Tim
    Commifornia
    Should I get the standard K16TR11 or the Platinum PK16TR11 about $4 difference? Also is there a site or how to or diagram for a 5VZ FE? Thanks.
  5. Mar 9, 2010 at 2:07 PM
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
  6. Mar 9, 2010 at 7:45 PM
    Tacoguy
    Tacoguy Well-Known Member
    Alex
    Chicago
    03 Tacoma PreRunner V6 3.4 TRD
    Bed Liner, Running Boards, Cargo Net, Deck Plate Mod, K&N Air Filter, NGK Iridium Spark Plugs
    You just missed out. I just bought 6 of the Denso K16TR11 for $16.49 shipped to my door from ebay. :D
  7. Mar 10, 2010 at 7:41 AM
    sirsaechao
    Tim
    Commifornia
    I saw that on eBay. Just wondering what the biggest advantage of the standard K16TR11 vs Platinum PK16TR11? ~$4 difference between the two. I also see Iridiums but I don't think I want to get those unless they are significant advantage over the standards and Platinum. Thanks.
  8. Mar 10, 2010 at 11:26 AM
    Tacoguy
    Alex
    Chicago
    Basically the only advantage of the platinums over the standard copper is change interval. I actually used iridiums for a while (about 8k miles). During that time, I noticed that the car overall just did not seem the same. Gas mileage was worse and overall the truck seemed sluggish.
    After going back to standard copper plugs, immediately the car had more power. I definitely felt the difference. Gas Mileage was near the same, a bit better.
    So I would personally just got with stock copper dual prongs.
  9. Mar 10, 2010 at 11:44 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    Yup, whatever you end up getting, better be sure to get the ones with the dual grounds if you have a gen1 v6.
  10. Mar 10, 2010 at 12:43 PM
    sirsaechao
    Tim
    Commifornia
    I went with the standard. The illustration looks single but description says dual ground electrode and comes gapped at 0.44...do I need to change this at all or just install with with some anti seize?
  11. Mar 10, 2010 at 12:57 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    If it's the dual then double check the gap and install it w/ anti-seize.
  12. Oct 23, 2012 at 2:47 PM
    biggecko
    biggecko Well-Known Member
    Tarek
    Apex,nc
    2000 TRD SR5 pre-runner v6 3.4
    nerf bars, deckplate mod, billys 5100 all the way round with an aal in back
    not to make yall feel bad but my local carquest got my all 6 the next day for 14.03 :D
