SPC UCA Bad ball joints after 20k
Discussion in 'Suspension' started by CMillTacoma, May 23, 2022.
  1. May 27, 2022 at 8:18 AM
    #41
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I have about 35k on mine and still solid. I grease with an NGLI #2 every 5k and before/after road trips and any major off-roading.
    Premature wear is usually attributed to improper maintenance.
    71tattooguy, JayRolla and wi_taco like this.
  2. May 27, 2022 at 12:08 PM
    #42
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Any front end clunk, first thing to check is that the alignment cam bolts are torqued to spec.
    19mm hardware, 110ft#'s
    22mm hardware, 130ft#'s
    90% of the time, that will do it. SPC bushings do have an issue with a pop or clunk noise which SPC will warranty, so if the noise continues after you torque all 4 LCA bolts, then that may be the issue.
  3. May 27, 2022 at 12:12 PM
    #43
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    This is not a metal on metal clunk, this is a rubber rebound sound when hitting big bumps. Mostly from the drivers side but also on passenger side. Sounds like a bushing or mount that is loose but hasn't ripped the bushing all the way through. Going to replace the front body mounts (by Radiator), but while I have all the tools out wanted to see what else it could be. No sway bars, new coilovers.
  4. May 27, 2022 at 12:34 PM
    #44
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Curious where are those torque numbers from? FSM specs LCA bolts at 100 ft/lb (19mm), UCA through bolt at 85 ft/lb (19mm), and UCA BJ to knuckle at 81 ft/lb (22mm). Want to make sure we all have the correct information.
    https://www.tacomaworld.com/threads/the-torque-spec-guide.318116/
  5. May 27, 2022 at 12:53 PM
    #45
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    19mm hardware is on 05-15 Tacoma LCA bolts/nuts. I've found 100 isn't enough, so 110 has been good. 22mm hardware is found on 16+ Tacoma LCA bolts/nuts, and that is spec.
    wi_taco[QUOTED] likes this.
  6. May 27, 2022 at 12:54 PM
    #46
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Go ahead and put your torque wrench on everything. Body mounts are 32ft#'s.
  7. May 27, 2022 at 12:55 PM
    #47
    JoeCOVA
    Joe
    Colorado Springs
    I would love to hear the emerical evidence to support a substantiated difference in 10 ft/lbs...
    wi_taco likes this.
  8. May 27, 2022 at 1:03 PM
    #48
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Just expirence, no actual science behind it. Gives the hardware an 1/8th to 1/4 turn at best.
  9. May 27, 2022 at 1:07 PM
    #49
    JoeCOVA
    Joe
    Colorado Springs
    Ok that makes a little more sense to me. I’ve seen a common practice to add 1/4 turn after hitting the spec.
  10. May 27, 2022 at 1:48 PM
    #50
    aturk
    Tony
    Charlotte, NC
    I will do that. I have some energy suspension bushings to swap in there for the front body mounts.
  11. Dec 27, 2023 at 1:23 PM
    #51
    YE2KA
    YE2KA Well-Known Member
    JB
    19 Cement Grey Tacoma Offroad
    What is a clear symptoms of ball joints going bad? My tire wear seems normal no shaky steering wheel. I do have a slight thump sound when turning into bumpy turf.
  12. Dec 27, 2023 at 1:58 PM
    #52
    wi_taco
    Adam
    SE Wisconsin
    Not sure there is a one-size-fits-all symptom. Mine failed after about 1 year and something like 10k miles. Started by giving a little bit of click-clack sound from time to time which went away after I pumped more grease in (which by the way you should do more often than 5k for sure). Then I started noticing my steering feeling a little "off" like it wanted to wander but couldn't notice anything so figured it's mind playing tricks. Then with more mileage it became clear as day when my front tires were cupped so bad I almost had to trash them and buy new ones. Ended up rotating them and running in reverse direction which burned off tread life excessively but caused them to return to mostly being level.
    908tacoma and YE2KA[QUOTED] like this.
  13. Dec 29, 2023 at 8:02 PM
    #53
    JoeCOVA
    Joe
    Colorado Springs
    Any kind of movement in the balljoint.
    YE2KA[QUOTED] likes this.
  14. Dec 30, 2023 at 12:55 PM
    #54
    YE2KA
    JB
    I'm assuming while the truck is jacked up and no weight on vehicle?
  15. Dec 30, 2023 at 6:27 PM
    #55
    JoeCOVA
    Joe
    Colorado Springs
    Ya thats how you can easily test it, though if it was wiggling with weight on it I'd be nervous.
    eurowner likes this.
  16. Dec 31, 2023 at 9:37 AM
    #56
    eurowner
    eurowner Duke Sky
    Scoty
  17. Jan 2, 2024 at 5:45 PM
    #57
    YE2KA
    JB
  18. Jan 2, 2024 at 6:33 PM
    #58
    UMC
    UMC I will not comply
    Thomas
    South Fork of the American river.
    13 TRD Sport DCLB 4x4
    37's & rear locker
    Who does their oil change every 10k? Toyota recommended 5k to 6k right?
  19. Jan 2, 2024 at 6:50 PM
    #59
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The upper ball joint doesn't really carry weight. If you can get a pry bar under the UCA and leverage off the tire, that's one way to check for play. (May not work if your tires are bigger than 35")
  20. Jan 2, 2024 at 7:04 PM
    #60
    wi_taco
    Adam
    SE Wisconsin
    You can get one that's accurate enough for this job at Harbor Freight with a magnetic base for like $30 or less with coupons/sales. That's what I did, and that's how I proved the excess radial play.
    Up/down play doesn't matter with these according to SPC because the spring washer takes up that slack (though I agree, up/down play does actually matter a bit). It's the side-to-side play you have to measure because it's small but carries big consequences.
