Speaker Replacement with amp
Discussion in 'Audio & Video' started by Early B., Aug 19, 2017.
  1. Aug 19, 2017 at 8:10 PM
    Early B.
    Early B. [OP] Well-Known Member
    Brad
    metro Atlanta
    2014 2.7L, 5 lug Tacoma
    18" tires and rims, 2.75" Procomp lift, Fox shocks in rear.
    First, I have no knowledge at all of car stereos, so please forgive my simple query.
    I want to replace the speakers in my 2014 base model access cab with stock head unit. I purchased this speaker kit:
    https://www.amazon.com/gp/product/B00TRKNODO/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    and this amplifier:
    https://www.amazon.com/gp/product/B01LXJJXXH/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
    I also purchased a speaker adapter kit from *********.com.
    I plan to buy all of the parts, then get a pro to perform the install. I listen mainly to FM radio and never blast the system. I listen to jazz. The goal is to get better quality sound without replacing the stock head unit. The stock system sounds horrible. I don't want to spend a lot of money at one time to overhaul the entire system. Later on, I'll replace the HU.
    Is there anything else I need to purchase to make this work? Speaker cable? Speaker connectors?? Sound deadening stuff? Any advice would be helpful.
    Thanks.
  2. Aug 20, 2017 at 8:58 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  3. Aug 20, 2017 at 1:30 PM
    Early B.
    Brad
    metro Atlanta
    Wow. Seems extremely pricey. There's gotta be a less expensive alternative. Would this work instead?
    https://www.amazon.com/Factory-Ampl...ywords=toyota+tacoma+amplifier+wiring+harness
  4. Aug 20, 2017 at 2:11 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    ********* is overpriced for sure, I just linked it because I knew they would have it. You can do it by cutting the factory wires and running your own for dirt cheap, but most would rather a plug and play solution. That kit you linked is only good up to 2011 Tacoma, but yes a similar kit good for 2012+ is all you need.
