Speaker spacers for 6x9 focal
Discussion in 'Audio & Video' started by Overlander, Jul 24, 2014.
  1. Jul 24, 2014 at 7:01 PM
    Overlander
    Overlander [OP] Well-Known Member
    Building some speaker spacers for my new focal access 690ac. I have some high density plastic left over from work but it is 1 7/16" thick. Would like to mill it down to 1 1/4" instead of the standard 1" as the focals are deep (3 3/16s). How much room do I have before the inner door panel will not fasten to the inner door skin?
    Will also be installing some cld tiles, ccf, and mlv for sound and resonance deadening. Thanks in advance.
  2. Jul 25, 2014 at 9:16 PM
    Overlander
    Thinking of getting the alpine ktp mini amp with the stock base level 06 head unit feeding the front 6x9s with matching 6.5s. Think I should use a jl audio clean sweep? Any advice with what I will need for wiring would be appreciated. Thanks.
  3. Jul 25, 2014 at 10:42 PM
    Overlander
    Mr Marv says 1" for front an rear clearance. Thanks for the quick reply Marv.
    Any advice on the alpine ktp 45wx4 amp with head unit setup? Would I be better served with a full blown and wired amp?
    Keeping a low profile inside the cab is important to me. Vehicle gets left in the wilderness often.
  4. Jul 27, 2014 at 6:45 PM
    weendoggy
    weendoggy Well-Known Member
    Aptos, CA
    2014 TRD ACOR 4x4
    Access Original Tonneau Cover; Toyota Side Tube Steps; Focal ISS690 front speakers; Clarion XC1410 mini amp; Gentex 453 rearview mirror with Homelink, Compass, Temp and Autodim; Prodigy P2 trailer brake controller, Heated Seats from www.cobraheat.com, BriteAss Fogs, Phillips Extreme LED H/L. Heated mirrors from @Up2NoGood. 5100 Bilstein all four corners.
    No advice on the Alpine but I used the Clarion XC1410, which is similar. You can see what I did in this post http://www.tacomaworld.com/forum/audio-video/328388-2014-access-cab-door-speakers.html I'm also using the Focal 690 speakers in my AC. You can easily put the amp under the front seat and nobody will know.
