Speaker Upgrade Reccomendation Needed
Discussion in 'Audio & Video' started by Rocketball, May 23, 2010.
  1. May 23, 2010 at 8:27 AM
    Rocketball
    Rocketball [OP] If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    Been doing a lot of research and reading, but I'm still very confused and need some reccomendations.
    I have an 08 DC Sport with a Pioneer P-4901B single DIN HU (no amp) and need to upgrade my speakers. One of my OEM rear speakers is buzzing, so it's time to change them out. I am partial to Pioneer, but would consider other manufacturers as well.
    Crutchfield has been some assisitance, but I'm not very knowledgeable in audio systems/parts. I'm not looking to do any rewiring, just want to keep things simple.
    I'd like to stay within $300 for everything, and I will do the install.
    Thanks in advance. :)
  2. May 23, 2010 at 9:57 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Get something extremely efficient if you won't be running an amp. The idea is that you have a limited amount of power and you want it to go as far as possible. A less efficient speaker will need all the power the headunit can put out and possibly even more; leading to clipping.
    But if you get a really efficient speaker that will play louder off less power you wont need to push the internal amp nearly as much. This will lead to better sound quality when cranking the system up.
    Sensitivity and Efficiency are used interchangeably and are measured in db at 1watt/1meter. Sometimes manufacturers list the rating but at 2.83V/1meter which is misleading. A 4ohm speaker getting 2.83V is actually getting 2watts of power and will "look" like it's 3db more efficient than it really is. So if it's a 4ohm speaker, measured at 2.83V you need to subtract 3db to get the REAL sensitivity rating.
    I realize that's a lot to digest and probably is more than you asked for but it's important. I'd look for something with 89db or better efficiency.
    Most important thing though is to buy a speaker you think sounds good. :)
  3. May 23, 2010 at 10:15 AM
    Maintenance Man
    Maintenance Man Well-Known Member
    Justin
    Atlanta, Ga
    05 Tacoma Pre-runner SR5 2.7L
    Leer camper shell; afe stage ll intake; 265's bridgestone dueler tires; rockford's power series 6.5's; tint on all windows; semi de-badged; weathertech digitial mats; grillcraft grill; blacked out headlights with eyelids; blacked out badges; and more to come.
    Rockfordfosgate power series are a great speaker ran from headunit power only. That's what I have in my 05 Taco
  4. May 23, 2010 at 1:24 PM
    CoreyJ
    CoreyJ Well-Known Member
    Laurel, MS
    TRD Off Road
    Pioneer TS-D6902R for front doors.
    Pioneer TS-D1702R for the back.
    Fits the brand you you are partial too. As well as they are great speakers. They will run about $330 for both pair via crutchfield, but do a search online and you can usually find them a tad cheaper.
    These are some of the most well balanced speakers I have ever heard. Especially at these price points.
    Don't forget to find the appropriate speaker spacer plates for them.
  5. May 23, 2010 at 3:17 PM
    orvis
    orvis Well-Known Member
    Winnipeg, Canada
    06 TRD off road
    I would go for the JL's for that set up but that's just my opinion
  6. May 23, 2010 at 4:44 PM
    ItalynStylion
    Steven
    DFW, Tx.
    I'm not a 6x9 kind of guy; but those aren't bad. They have a proper tweeter in the middle and are fairly efficient.
    Way to be non specific....
  7. May 23, 2010 at 5:03 PM
    orvis
    Winnipeg, Canada
    06 TRD off road
    my bad, I would go with the JL Audio TR650-CSi, front and back, you should be able to find them cheaper than what crutchfield has them for, with a little bit of mdf you can get the front ones to fit and you shouldn't go too far over your $300 mark. your HU will have enough power for those speakers and they will still be able to handle an amp if you decide to upgrade later, plus they sound a hell of a lot better than those pioneers.
    better?
  8. May 23, 2010 at 5:13 PM
    CoreyJ
    Laurel, MS
    TRD Off Road
    Thats totally subjective to each listener and also completely false in my opinion. The entire JL Evolution TR line of speakers sounds like they are in a tin can.
    The Pioneer D series, in my opinion (which is shared with a lot of people who have actually listened to them) are among the most balanced sounding speakers in their price range, and I am confident they will spank the floor with those JL's in most listening tests.
  9. May 23, 2010 at 5:22 PM
    orvis
    Winnipeg, Canada
    06 TRD off road
    I can't actually say I've gone that low end so you're probably right, I definitely like JL's high end stuff over pioneer's, but most of my stuff is alpine, JL a focal now.
    I found my K2's sounded like shit when I get them but it turned out all I had to do was play with the setting for about half an hour, now I want a set for my taco
  10. May 23, 2010 at 5:26 PM
    CoreyJ
    Laurel, MS
    TRD Off Road
    Well, I install for a living so I get to listen to speakers at all price points.
    Pioneers D series (TS-Dxxxx models) are the most impressive speakers pioneer make by far, and are among the best in their price range. But they don't compete with speakers over $300 per pair.
    JL's low end are far from impressive. But personally, I don't like the C2 line either, and the C5 line only marginally. Great amps and subs.
    I am interested in giving a gun listen to Alpines new R series when we get them in. As well as the new R series flat subs. Otherwise, I can't really stand anything they make.
  11. May 23, 2010 at 6:56 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Yes, I think that was a much more helpful post and actually added something to the thread. You've earned your rep for the day. :)
    Corey, who do you work for?
  12. May 23, 2010 at 6:58 PM
    CoreyJ
    Laurel, MS
    TRD Off Road
    Currently..........Best Buy. Was at a local mom and pop store for 6 years before ending up here.
  13. May 23, 2010 at 7:35 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Hey man, we all gotta pay the bills. No shame in it. Your bestbuy probably turns out cars that sound good since you're there. :cool:
  14. May 23, 2010 at 9:38 PM
    CoreyJ
    Laurel, MS
    TRD Off Road
    I do what I can with the product they give me to sale. Those Pioneers I mentioned to him we can order, but they aren't in the store. They sound better than the Infinity Kappa's and Alpine R series we have.
    BBY does pay the bills. I make double here what 2 local higher end shops pay their installers.
  15. May 23, 2010 at 11:12 PM
    orvis
    Winnipeg, Canada
    06 TRD off road
    I tried installing for a while but it didn't pay enough, plus I like it better as a hobby.
    I hope to have some pics of my stuff up by the end of the week.
  16. May 24, 2010 at 12:20 AM
    Leadgolem
    Leadgolem Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
  17. May 24, 2010 at 7:29 AM
    StZu
    StZu Where the White Women At?
    Richard
    Dallas Texas
    08 Prerunner Texas Edition
    I was on a very tight budget when building my system, who the hell am I kidding I am always on a tight budget.
    I am running infinity 5020's in the front.
    Infinity Reference 5020cs 5.25" Two-Way Component System (Silver/Black)http://www.amazon.com/Infinity-Refe...1?ie=UTF8&s=electronics&qid=1274711024&sr=8-1
    and some pioneer TWS- g16's in the rear
    http://www.amazon.com/Pioneer-TS-G1...1?ie=UTF8&s=electronics&qid=1274711066&sr=1-1
    and a Boss 1200 under the passenger seat
    http://www.amazon.com/Boss-BASS1200...2?ie=UTF8&s=electronics&qid=1274711139&sr=1-2
    All of this is being powered by an Alpine CDA105
    Alpine CDA105 / CDA-105 / CDA-105 CD Receiver MP3/WMA Playerhttp://www.amazon.com/Alpine-CDA105...1?ie=UTF8&s=electronics&qid=1274711199&sr=1-1
    So for 425.00 I have a sound system that is more than adequate for my needs.
    The 5.25 infinity's really sound good to me, but I would suggest going and having a listen to them before buying, they can be pretty harsh and some people do not like the sound of infinity's.
    Hope this helps
  18. May 28, 2010 at 7:33 PM
    KennyC
    KennyC New Member
    MD
    2010 Tacoma DBL CAB L.Bed V6 4x4 Sports Pkg.
    Has anyone installed or know anyone who installed the Image Dynamics CTX65CS speakers in their Tacoma? I'm seriously considering buying these speakers. They're only about $200/pair and I've read nothing but good reviews on them. They supposedly offer a more preferred sound than JL Audio speakers. Yes, this is subjective, but the reviews seem pretty consistent. Check-out www.tacotunes.com. The speaker manufacturer's website is http://www.imagedynamicsusa.com/.
  19. May 29, 2010 at 6:47 AM
    Rocketball
    Scott
    Westminster, MD
    I appreciate all the info. Thanks.
  20. May 29, 2010 at 2:54 PM
    DevL
    DevL Well-Known Member
    Heard plenty of negative reviews. Most centered on being boomy, lacking detail, and becoming muddy. Then again I say reviews are worthless. You have to listen to speakers and decide for yourself. Others treviews will never cut it.
