Aftermarket speaker suggestions
Discussion in 'Audio & Video' started by WAZZU12, Aug 22, 2016.
  1. Aug 22, 2016 at 10:30 PM
    WAZZU12
    WAZZU12 [OP] Active Member
    97 Tacoma
    What aftermarket speaker should I get?
  2. Aug 22, 2016 at 10:32 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Price range?
  3. Aug 22, 2016 at 10:33 PM
    WAZZU12
    97 Tacoma
    $250 and under
  4. Aug 22, 2016 at 10:34 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    What cab configuration do you have? Regular, extra, double?
  5. Aug 22, 2016 at 10:34 PM
    WAZZU12
    97 Tacoma
    Extra
  6. Aug 24, 2016 at 1:54 PM
    prayzhm
    prayzhm Active Member
    Bob
    2004 Tacoma Dbl Cab TRD
    Crutchfield has got a lot of options just just type in your model vehicle and they give suggestions. I just bought some Pioneer 6x8's for the front doors and a couple of no name ones for the back doors (I've got a Dbl cab) and it set me back a little under a hundred dollars ($97 to be exact). Haven't installed them yet but I'm sure they'll sound great with the JVC deck I bought from them. They also include pretty good instructions.
  7. Aug 24, 2016 at 1:54 PM
    Aw9d
    Aw9d That one guy
    Go to an audio shop and listen to a few brands to see what you like. Just make sure you set the EQ to flat on the head unit when you test, use the same song.
  8. Aug 24, 2016 at 1:59 PM
    Madjik_Man
    Colorado Front Range
    For $250 I'd buy a nice pair of speakers and an amp to power them.
  9. Aug 24, 2016 at 2:07 PM
    Aw9d
    Aw9d That one guy
    $250 won't really get you a 'nice' set of speakers and an amp. It will get you a set of 'decent' speakers and an amp.
  10. Aug 24, 2016 at 2:19 PM
    Madjik_Man
    My Polk Audio db651s speakers are pretty nice. Granted they aren't Focals but they are nice. Powered with a Sound Ordinance 2-channel amp, they sound great.
    I spent $130 for the three components. Granted the amp was on sale but the one I have is now selling for $100.
    I'd much rather have that set up, replete with about $75 worth of sound deadener and ensolite in the doors, than a pair of $300 Focals that are unamplified and put into tin can doors.
  11. Aug 24, 2016 at 3:15 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    95 extended cab sr5
    cxr turbo, fic6, methanol injection, king coilovers, jba uca, skyjacker leafs, rear 12" 5125s, no-slip rear locker, 35" grabber x3, magnaflow muffler, retrofit headlights, trans cooler, bed lined exterior, etc...
    Factory radio?
  12. Aug 24, 2016 at 3:19 PM
    devinzz1
    devin
    95 extended cab sr5
    4 speakers and an amp for $250 wont get you out of the lower end products.
    And like already said. Sound deadening goes quite a ways itself.
    Aw9d likes this.
  13. Aug 24, 2016 at 3:29 PM
    Madjik_Man
    I ran w/o back speakers for over a year and was fine.
    Only got them because Crutchfield had the same pair on sale for $60.
  14. Aug 24, 2016 at 3:31 PM
    Aw9d
    Aw9d That one guy
    I never run back speakers. Kills sound staging.
    t4daddy likes this.
  15. Aug 24, 2016 at 8:20 PM
    BartMaster1234
    BartMaster1234 American Auto Horns
    Tyler
    San Francisco, California
    Flux Capacitor
    Turns out not many speakers on Amazon come in 6in variations (biggest speaker size without having to maul the inner door and cab for a '98), so I went for Rockford Fosgate P16's full ranges. Also replaced the single din factory radio with a Kenwood DDX373BT Double Din Touchscreen. I was trying to avoid getting a sub for now and these are a great alternative. Lots of bass and range.
  16. Aug 24, 2016 at 8:38 PM
    odellkevin
    odellkevin Member
    Navarre, FL
    98 PreRunner Xtra Cab V6 TRD
    This might be a silly question, but has anyone considered installing 6.5" subwoofers in the back walls of an xtra cab? When I had my rear speakers out, there seemed to be a tremendous amount of air space in there. Would it rattle? Would sound deadening / insulation help?
  17. Aug 24, 2016 at 8:40 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I've seen people put them under the bench seats in the storage compartments in the Xtra Cabs.
    Example
    Example 2
  18. Aug 24, 2016 at 9:11 PM
    odellkevin
    odellkevin Member
    Navarre, FL
    Yeah, I've seen those as well, but I keep a bunch of stuff in those cubby holes. I've been searching the Google-sphere for the last hour for Xtra cab tacoma subs and all I get is dozens of different boxes or the cubby hole mod. The holes where the xtra cab factory speakers go is huge, you could probably even trim the plastic and fit 8" subs in there, it's probably about 4" or 5" deep. Someone has had to have tried it before, but I can't find any info either way.
  19. Aug 24, 2016 at 9:17 PM
    Aw9d
    Aw9d That one guy
    You might be able put an 8 Inch sub in there. You'll need to make a fiberglass box for them. Someone has fit 8 subs in the 2nd Gen on here. Pretty sure 1st gens can do it. If not 8 a 6.5 will work for sure.
  20. Aug 25, 2016 at 9:17 AM
    WAZZU12
    97 Tacoma
    Thanks for this! I will def check it out!
    Yeah I saw someone else do it, may have to look into these.
